AlurkA
Accuphase DAC-50 add on card
Haha @a.dentDP-750 it is then.... thanks heaps. I currently have a PS Audio Direct Stream Junior which I am quite happy with sound wise. But now I have ventured down the Accuphase path was looking at pairing my Accuphase integrated with an Accuphase DAC or DAC/Transport. The price of the DAC-50 is much easier to swallow when compared to to the standalone gear.  Was wondering how much of a compromise it may be.
Not exactly addressing the OP’s question, but this thread piqued my interest in doing a similar comparison. I thought the results might be of interest to others.
Source: Accuphase DP560
Alternate DACs: DAC30 (fed by coax spdif), DP560 (single ended analogue out via included Accuphase interconnects), DC801 (via HS-link, with output via balanced Cardas golden cross)
Each feeding into Accuphase E560 - Cardas golden cross biwire - proac response D38s
Perhaps unsurprisingly, each step up in (original) price yielded improvements in sound quality - mostly in terms of transparency and noise floor, but also with (consequent?) improvements in tone, soundstaging, attack and decay. Not that the differences were earth-shattering - I could live with any of them.
I also suspect that the quality of the transport may be a limiting factor - the DP560 as a transport sounds much better than my largely unmodified Mac mini (SSD, 16GB ram, Audirvana+, Weiss Minerva FireWire to spdif conversion), particularly in the upper registers. I suspect the differences I heard in the comparison using the DP560 as a transport would be much less if I used my Mac.
Hi @Weissman  Thanks for the information. This is the kind of information I am after. I am considering the DAC-50 in the short term. Have also been told the DP-430 is an excellent source. CD and DAC. I don’t do a lot of listening to discs and am thinking ultimately the DC-37 is the end game for me. The DP-560 has SACD support but I have none of these but am sure it’s DAC capabilities are also up there. Offers more flexibility than a pure DAC.
I’m glad it was useful. Over the next couple of days, I’ll try to do a comparison of the DAC30 and the dac section of the DP560 by feeding both with my Mac. Would that be helpful? I figure it might give you a reference point for how much a compromise using the DAC50 will be while you use a Mac as source.
That would be fantastic, thanks heaps.
Hi. I spent a bit of time on Sunday comparing the DAC30 and the dac section of the DP560 with my Mac mini as source. I used a generic USB cable and Audirvana+ playing the tunes.
Short answer is that I could clearly hear the difference between the two which I wasn’t really expecting - I thought the Mac might been too much of a limiting factor.
They both sounded good, but there was a noticeable flattening of the soundstage, less extension in the highs and a bit less definition in the lows with the DAC30. Still enjoyable, and I would probably be happy if I wasn’t able to compare it to a better dac, but there was definitely a notable difference.
@Weissman Thanks for taking the time out to do this...gotta luv this community.  You'd kinda hope there would be a difference given you are comparing a $1000 component to a far more expensive one.  I am running my previous DAC, Cambridge 851D at the moment as my Direct Stream Junior is off to get its bridge replaced. Its been a similar experience for me.  The 851D is pretty good but the DSJ has a better sound stage, a touch more detail in the highs, Vocals are sweeter and bass is more controlled and detailed.  Immediately after swapping them over I didn't really notice the differences as much as I do a day later listening funnily enough.
Like you I run a mac mini, Media Centre 24 (instead of Audirvana) via a Curious USB is used to my DAC.  From here XLR to an E-470 out to my Dyns.  I am a fan of using a computer based source but the lure of SACD and original discs is drawing me to the DP-430 and DP-560 as I get the best of both worlds.  Decisions Decisions.
One thing to consider if you end up going the disc player route is that the DP560 will plat data discs (ie DVD-Rs with dsd or pcm data files on them), meaning you could burn hi-res downloads to disc and play them. I don’t think the DP430 can.
I haven’t tried this myself yet but but it was one of the key reasons I went for the DP560 as I expect it will become more difficult over time to buy high res on physical media.
I don’t envy your choice though. It’s hard to weigh up a number of different factors with little or no chance to audition the components
I’m hoping the local accuphase dealer may be able to help me out trialing the various components. Price as always comes into play. None of this gear is cheap!!
If you're serious about buying a DP-560 I'm seriously considering trading mine to upgrade to a DP-750. Not that I'm unhappy with the DP-560 but I have a C-2850 so the DP-750 would match better aesthetically with the same Persimmon cover.
Maybe we could work out a mutually agreeable price on a barely run in DP-560.
