Paul_B
FS: AudioQuest, Aspen, Speaker Cables Full Range 3m / 10ft pair $1250 (RRP $3580)
Item:  AudioQuest, Aspen, Speaker Cables full range 3m / 10ft pair $1250 (RRP $3580)
Location: Clayton or Devon Meadows happy to post anywhere.
Price:  $1250 (RRP $3580)
Item Condition: Used but in excellent condition I have original receipt from Amber Technology who are the importers.
Reason for selling: I'm now running mono blocks so need shorter speaker cables
Payment Method: Pickup - Cash, direct deposit, COD Only
SOLID PERFECT-SURFACE COPPER+/PERFECT-SURFACE COPPER (PSC+/PSC) CONDUCTORS:
Aspen uses a carefully finessed combination of high-purity Perfect-Surface Copper (PSC), and extreme high-purity Perfect-Surface Copper+ (PSC+) conductors in a Self-Shielding Double Counter-Spiral HyperLitz design. Solid conductors prevent strand interaction, a major source of distortion. Surface quality is critical because a conductor can be considered as a rail-guide for both the electric fields within a conductor, and for the magnetic fields outside the conductor. The astonishingly smooth and pure Perfect-Surface nearly eliminates harshness and greatly increases clarity compared to OFHC, OCC, 8N and other coppers. The superior purity of PSC+ further minimizes distortion caused by grain boundaries, which exist within any metal conductor.
DIELECTRIC-BIAS SYSTEM (DBS, US PAT #S 7,126,055 & 7,872,195 B1):
Insulation is an electrical barrier, and also a “dielectric” because it is inside the conductor’s magnetic field. All insulation slows down and smears the signal inside. When insulation is unbiased, it causes different amounts of delay for different frequencies and energy levels, a real problem for very time-sensitive multi-octave audio. AudioQuest’s DBS creates a strong, stable electrostatic field which saturates and polarizes (organizes) the molecules of the insulation. Saturated (full) insulation absorbs less and therefore releases less out-of-phase energy. Minimizing nonlinear time delays results in clearer sound emerging from a “blacker” background. The DBS battery packs will last for years. A test button and LED allow for the occasional battery check.
DOUBLE COUNTER-SPIRAL GEOMETRY:
Aspen and the other AQ “Tree” Series cables have an inner circular array of positive conductors spiraling in one direction. Around this inner group, the negative conductors spiral in the opposite direction, which makes possible the significant performance advantage of the positive and negative conductors crossing each other instead of being parallel. However, the critical need for positive and negative to have a fixed non-changing relationship is ensured as the negative and positive groups are in fact two tubes with a perfectly consistent relationship. The result is an astonishing clarity, like focusing a camera lens you had no idea was so far out of focus.
CARBON-BASED NOISE-DISSIPATION AND CROSSTALK-DISSIPATION SYSTEM (INSULATION):
The negative conductors in Aspen are covered with partially conductive Carbon-Loaded Polyethylene. This remarkable material damps radio-frequency garbage from being fed back into the amplifier. The sonic benefit is exactly the same reduction in “hash” and improved dimensionality that comes whenever RF interference is reduced in an audio circuit. Another carbon layer also damps interaction between positive and negative conductors, and an external 3-layer carbon-based NDS System additionally absorbs external interference.
SPREAD-SPECTRUM TECHNOLOGY (SST):
Any single size or shape of conductor has a specific distortion profile. Even though radially symmetrical conductors (solid or tubular) have the fewest discontinuities, any particular size still has a sonic signature. SST is a method for significantly reducing the awareness of these character flaws by using a precise combination of different size conductors. The different SST-determined conductor sizes used in Aspen allow an exceptionally clear, clean and dynamic sound.
BIWIRING:
When possible, running separate conductors or separate cables to the treble and bass halves of a speaker will considerably reduce distortion. BiWiring helps by keeping the large magnetic fields associated with bass energy out of the treble cable, allowing the delicate upper frequencies to travel a less disturbed path, like keeping the big waves out of the water when you swim. Although Aspen is an ideal Full-Range cable, it has also been designed to make it possible to truly Single-BiWire. Many multi-conductor cables claim to be good for BiWiring, but unless there is real magnetic isolation between the bass and treble conductor groups, dividing such cables into bass and treble can actually be worse than keeping them together.
TERMINATIONS:
Aspen is prepared by Cold-Welding AudioQuest’s 1000 Series Hanging-Silver Multi-Spades or Bananas. The plugs are plated directly over pure Red Copper by submerging (hanging) the spades and bananas into a vat of extreme-purity silver, resulting in a very thick Direct-Silver Plate. There are no intermediary performance degrading materials. Aspen’s breakouts (where the cable divides into positive and negative legs) are also special: Because a metal breakout would disrupt the cable’s magnetic fields, Aspen’s breakouts are magnetically invisible ABS.
DIRECTIONS:
Because all drawn metal is directional, all audio cables are directional. AudioQuest analog and digital audio cables are all controlled for correct directionality. The best sound is made possible by following the “Amp” and “Speaker” labels on Aspen’s breakouts.
09602840-96E0-4905-A130-50B3B3FCEA87.thumb.jpeg.ea6865d0bc19e8a4e80a25ee45fc509c.jpeg4452C91E-5F64-4E1E-A106-0637FEABC9B3.thumb.jpeg.fc0d324760ee323e70c86e775ca71d49.jpegA2D16B23-2978-442F-B0F6-7E67D7EC818D.thumb.jpeg.f6eb7559c0b9dc186559d561f7084f86.jpeg81FC103A-1D0C-4113-92F5-F53704513FA7.thumb.jpeg.efb5132dc4c12b2094ddd3a1020c3c51.jpeg58B8C5EE-F2AD-4391-A28D-36C6BD8A0682.thumb.jpeg.234412bf76005d959f00d700665f5ea6.jpeg
Edited by Paul_B
PRICE DROP
    • By ssb102
      Item: 4x Fanless ROON ROCK Servers
      Price: Varies, see below
      Item Condition: Excellent
      Reason for selling: Surplus!
      It's 2020 and it's high time i cleared my backlog of projects.
      I have FIVE Fanless Roon Rock Boxes for sale.
      All totally silent with SSDs running the latest version of ROON ROCK
      Small enough to fit on a bookshelf and use far less power than a full PC or laptop so you can really leave them running.
      Your wife/girlfriend/dog/cat wont even notice.
      3x WYSE Zx0
      (2 Units) 8GB + Ethernet + Wifi $120 ea
      (1  Unit) 16GB + Ethernet + Wifi $150 ea
      (1 Unit left! ) 8GB + Ethernet + Wifi $120 ea
      1x Dell Optiplex FX160 with 32GB SSD
      $200 $150 PRICE DROP
      Intel Atom platform
      Gigabit Ethernet  (via USB 3.0 adapter, FREE)
      Wifi optional extra
      ALL BOOT INSTANTLY AND WORK FLAWLESSLY.
      These SSD sizes are more than adequate to hold the ROON database because with ROON your music is stored elsewhere.
      Priced fairly these are an excellent way to get started with ROON.
      Reasonable offers considered. Discounts for multiple purchases or pickup.
      Lowballers and timewasters will be sent a copy of the Betoota Advocate.
      ARSE mug not included.
      Shipping available just DM me for a quote.
    • By Vladas
      Item:
      MASTERSOUND INTEGRATED TUBE AMPLIFIER BOX R
      Parallel Single Ended in "Class A" Integrated - Made in Italy
      Power: 2 x 35 Watt
      Tubes complement: 2 x ECC802 - 6 x EL34
      Input: 3 line + Phono MM
      Output: 1 line
      Load imped.: 4-8 ohm
      Bandwidth: 18 hz / 25 khz 0 db
      Output Transformer: MastersounD
      Automatic Bias
      Supplied with remote control - R version
      Negative feedback: 0 db
      Dimensions: 43,6 x 40,9 x 18,5 cm
      Weight: 24 Kg
      Made in Italy
      Price:  $3000 (RRP - $5200)
      Item Condition: Brand New - still in the box
      Reason for selling: Change of financial situation
      Pure Class A  2x35 Watt PSET (Parallel Set) which is used in the very high end tube
      amplifiers like Aries Cerat $30K USD. This gives you uncompromising power to run in pure class A almost any 89+ db speakers.  Lack of power is Achilles weak spot of most tube amplifiers and I believe PSET is the best solution used by the very high end manufacturers. Legendary Mastersound brand - makes PF100 tube amplifier $50K USD. Fabulous musical EL34 tubes. To my knowledge, this model is absolutely the best value for integrated tube amplifier in that price range; made in Italy but priced similarly to comparable Chinese models. Includes very good phono pre-amplifier - same as in the flagship models.  This is Box R version with remote control (cost $330 AUD extra).
      Links below shows additional information about The Box and Mastersound brand in general:
      http://www.mastersoundsas.it/1/reviews_4451773.html
      https://soundapproach.com/mastersound-box-r-integrated-amplifier-class-a.html
      https://www.technologyfactory.eu/en/mastersound/integrated-amplifiers/mastersound-box/a-5384-10000401
      https://forum.audiogon.com/discussions/axpona-2018-integrated-mastersond-box
    • By russell66
      Item: Klipsch Synergy Home Theatre Speakers
      Price: $600ono
      Item Condition: Very Good all working well, some minor marks.
      Reason for selling: No Longer Required
      Excellent sounding home theatre package. Klipsch are well known for their cinema speaker designs.
      Fitting out many cinemas and shows with these speakers.
      They excel with soundstage, dynamics and detail.
      Package consists of ...
      2 x Synergy F10 Floor-standers
      2 X Synergy B20 Bookshelf's
      1 X Synergy C1 Centre
      1 X SW 350 Sub Woofer
      Post is available at your cost and risk.
    • By fffastfaz
      Item: Chord Shawline USB Cable 1M
      Price: $275.00 incl postage
      Item Condition: Brand new
      Extra Info: Cable is brand new and cost $350.00
    • By 81Vintage
      Item: Custom Rega Style Turntable, AudioMods Tonearm, IsoDrive PSU
      Price: $3300 Price Drop $2850 inc shipping Australia Wide, can do a little less if you can collect in person to save packing and freight.
      Item Condition: Excellent, Used
      Reason for selling: New Project/Custom Build
      This is a complete custom build from the ground up based on a Rega P series design. Raw cost of materials and items was over $6000.
      Plynth milled from single block of billet alloy on CNC router (around 15kg) Finished in red automotive paint Followed same dimmensions as a Rega P3 plynth. 5x Maglev feet (tried with 3, 4 and 5 configurations and 5 was the best) IsoKinetic IsoDrive Power Supply with 33/45 speed selection IsoKinetic 25mm Acrylic Platter IsoKinetic IsoSub Groovetracer Machined Subplatter IsoKinetic Phosphor Bronze Bearing Sleeve IsoKinetic Ruby Bearing + Spindle Oil (lifetime supply left in bottle) IsoKinetic Puck/Stabiliser IsoKinetic Red Thing Silicone Belt + Spare New One in Packet IsoKinetic MTB-D Motor Thrust Bearing + Motor Isolation Mod for Premotec Motor Premotec 50hz Synchronous Motor Audiomods Series 4 Tonearm with Series 5 bearing, lift and arm hold. Full VTA Adjustment - no VTA adjuster.  All original weights and headshell weights/spacers included to adjust to any cart. Custom Acrylic Dust Cover to accomodate arm height No cart included, but I did have an Ortofon MC25e on it and it was stunning.
      *I have covered the hole bottom left corner where a power button would have gone if I didnt use the external motor PSU and controller with a samurai silver coin from WA mint. So the turntable is dubbed "The Samurai"
      For interstate buyers, it will be professionally crated and foam lined for shipping with tonearm back in original transport box. Shipping Australia wide with insurance included.
      For those that want to know where to from here - my next build will be in the similar vein...but using the MK6 Audiomods tonearm for primary, 200mm monster delrin platter,  ceramic bearing sleeve, larger billet plynth with 2 armboards for future arm addition and external motor and controller.
