On 12/08/2018 at 4:35 PM, gonefishing999 said:
@TLL I can get 27 the same as oppomod uses in tcxo and ocxo .
I need to order 10 pieces to get ocxo if anyone wants to make this.
10 12 weeks for delivery. I wii be ordering this week.
I will design circuit boards this week to fit both clocks.
Peter,
Looking at Oppomod site, their clock upgrade requires the LPS upgrade to power it. Does yours, as well, or can it pull power from the stock SPS?  Also, does your board work with the 103, or only the 203?
Finally, did you hear improvement via I2S board to the Holo before upgrading the clocks, or were they installed at the same time?
Thanks again,
Michael
This may be a silly question, but does the Oppomod I2S board get 'true' DSD out of the Oppo? PS Audio say that their DACs only accept DSD from their transports verified by their own handshake. How does the Oppomod board handle this?
@Lukoo yes true DSD  stereo no multi channel.
To get the best sound the clock needs changing .
Peter
@gonefishing999 thanks Peter. So if I put an Oppomod I2S board in my UDP-203 and connect it via HDMI cable to a PS Audio DAC, will I get the full DSD experience? Is there no problem with the PS Audio 'handshake'?
I guess the clock upgrade can be added at a later stage?
Excuse my ignorance, thank for your insight.
Lukas
Lukas
There's a lot of posts on the PS Audio forums suggesting that it works fine
https://forum.psaudio.com/t/getting-oppo-dsd-output-to-the-direct-stream-dac/2744/261
Excellent, thanks for that!
I think I've seen one picture of the i2s mod installed.
Is it easy to do? And do you have to chop a bit of the vent to fit the hdmi plug?
Check first page pics there.
would it be possible to install the oppomod I2S module into the Oppo BDT-101CI player? The connector is slightly different - the same type but more number of pins. What do you think about it? Thanks
Edited by DenisD
No only made for 103 or 203
