paulk
SOLD: FS Vincent SP20 Anniversary Edition Hybrid power amp
Item: Vincent SP20 Anniversary Edition Hybrid power amp.
Price: $1250     paid $1730  RRP $3499
Item Condition: 9/10 like new approx 8months old
Reason for selling: going all valve
Extra Info:   Bought this amp on speculation when Eastwood Hifi were clearing stock at very reduced prices due to a change in distributor.
          What piqued my interest in this model, SP20, was the combination of valve input stage  and solid state output.
            I have enjoyed this hybrid valve amp so much I have to decided to give all valve a go.
           This amp has great bass weight and definition allied to a top end that is not harsh but has that beautiful valve airiness. But most importantly, this amp brings out the emotion in music.
             The first 10 watts are class A with all that brings but still retains composure at loud volume levels.
              Also included are various input valves including original russian, RCA (nos) and Amperex.
                 Eastwood Hifi assured me any warranty claims would be fully covered by the new distributor.
                 I have original shipping cartons and receipt. Buyer pays for shipping.
                 Only to happy to answer any questions.
                  Thanks for looking.
Regards Paul
Edited by paulk
PM replied to. Thanks
Looks like a nice amp for not a lot of money, love the windows, so you know it’s not a big SS block.
Yes, it's not a heavy weight but still pretty solid at 28kg.
I have one of these too, paired up with an SA31MK Pre and they sound great together, GLWTS
It's worth noting too that this is somewhat of a collector's item, only 125 worldwide.
Thanks thathifiguy.
I forgot they were built in limited numbers to celebrate Vincent's 20th anniversary.
I think they are an up spec sp331mk with alot of upgraded parts.
Might want to redact your name and address from the invoice pic. :)
Nice amp and even nicer price. GLWTS :thumb:
Just removed the receipt photo on the recommendation of a fellow SNA'er.  Probably a good idea, but rest assured it will be supplied on purchase.
    • By leqt1969
      Item: Audio Valve Baldur 70 Monoblocks
      Price: $5500 ono
      Item Condition: Excellent
      Reason for selling: too much power for avantgarde speakers
      Payment Method: Pickup - Cash, Paypal
      Advertise on behalf of a friend in Bexley NSW who doesn’t have SNA account.
      Bought brand new about 3.5 years ago and rarely used. Still has original boxes.
      2 set of tubes. Rca tubes and original set of tubes.
      Description: Push-pull, class-A, triode monoblock power amplifier. Tube complement: two 2AU7, 12AX7, two 6N6P; four 6AS7G.
      Maximum power output: 70W into 8 ohm load at 1% distortion (18.5dBW).
      THD at rated output: 0.3% (50W, 100Hz–10kHz).
      Power bandwidth: 10Hz–50kHz ±3dB.
      Damping factor: 20. Input sensitivity: 0dBm (775mV).
      Dimensions: 12.8" (325mm) W by 11.8" (300mm) H by 15" (385mm) D. Weight: 35.25 lbs (16kg).
    • By tiztrain
      Item: Emotiva XPA-2 Gen3
      Price: 1300
      Item Condition: XPA (10/10)
      Reason for selling: Downsizing
      XPA-2 Gen3 - Very powerful power amp - in perfect condition
      Greatly reviewed.
      Powered these power hungry Polk RTi12s.
      Bought towards the end of 2017 and come with the receipt and a 5 year warranty
      Also selling the following:
      - Polk CSi5 centre speaker
      - Polk Monitor 60 speakers
      Have not listed but could do a deal if interested.
    • By Luke0711
      Item: Emotiva BasX A-700: 7-Channel Power Amplifier
      Price: $700
      Reason for selling: Moved and changed set up.
      Hey Guys,
      I’m selling here a great EMOTIVA power amp.
      Model: BASX A 700
      It is a powerful 7 channel amp.
      In great condition and without any issues.
      I paid $1399 for it.
      Here the like:
      https://www.stereophonic.com.au/emotiva-basx-a-700-7-channel-power-amplifier/
      Some specs:
      The BasX A-700 is a seven channel power amplifier. The BasX A-700 combines classical audiophile amplifier architecture - based on a heavy-duty linear power supply, and a carefully designed high current, short signal path, Class A/B output stage, with advanced, microprocessor-controlled monitoring and protection circuitry, to deliver superb sound quality at a truly reasonable price.
      Power Output (two channels driven)
      110 watts RMS per channel; 20 Hz - 20 kHz; THD < 0.1%; into 8 Ohms
      210 watts RMS per channel; 1 kHz; THD < 1%; into 4 Ohms
      Power Output (all channels driven)
      80 watts RMS per channel; 20 Hz - 20 kHz; THD < 0.1%; into 8 Ohms
      Power Bandwidth (at rated power; 8 Ohm load)
      20 Hz to 20 kHz (+ / - 0.07 dB).
      Broad Band Frequency Response
      5 Hz to 80 kHz (+ / - 1.8 dB).
      THD + noise
      < 0.02% (A-weighted); at rated power; 1 kHz; 8 Ohms
      Signal to Noise Ratio (8 Ohm load)
      > 120 dB (A-weighted); ref rated power.
      > 100 dB (A-weighted); ref 1 watt.
      Minimum Recommended Load Impedance
      4 Ohms; which equals one 4 Ohm load or two paralleled 8 Ohm loads.
      Damping Factor (8 Ohm load)
      > 500.
      Speaker Output Connections
      Audiophile grade, 5-way binding posts.
