JerryTostevin
SOLD: FS: Bryston B135 SST² Stereo Amplifier
Item: Bryston B135 SST² Audiophile Stereo Amplifier
Price: $3,999
Item Condition: mint
Reason for selling: moving sale
If you know about quality amplifiers then you likely already know the Bryston brand.  The Bryston B135 SST² Integrated Amplifier is without question one of the most sonically transparent and reliable audio products available. It offers performance levels equal to the finest separate audio components.  If you would like to know more about this exceptional amplifier, you can have a look at the Bryston online brochure here - http://www.bryston.com/PDF/brochures/B135_BROCHURE.pdf
For more, you can read detailed reviews here:
https://www.soundstagehifi.com/index.php/equipment-reviews/621-bryston-b135-sst2-integrated-amplifier
http://i.nextmedia.com.au/avhub/australian-hifi_reviews_2014_2014-04_bryston_b135sst2_amplifier_review_test_lo-res.pdf
Key Features
  • 135W into 8 Ohms (180W into 4 Ohms)
  • Over 30,000 MFD of filter capacitance per channel
  • Three ultra-low-noise power transformers
  • Separate ground paths for Digital and Analog
  • Gold plated switch, contacts, and connectors
  • Pre-out/main in connectors
  • Convection cooled and housed in a fully aluminum chassis
  • RS-232 serial data port for remote control via Crestron, AMX or similar control systems
This amplifier was purchased in December 2014, is in as-new condition and carries the balance of the Bryston 20-year warranty (original proof of purchase receipt will be provided).
If you are buying from interstate, the amp is ready to be shipped to you by the courier of your choice in the original box.  I will gladly work with the buyer to ensure the item gets to you promptly.  The amplifier weighs 13.6kg (without the box) and measures 43 x 12 x 41 cm
This amplifier retails for $7,000 new.  Pick up an absolute bargain.
Other items that I currently have for sale:
PMC Twenty.24 Loudspeakers
Audiolab 8200CD CD Player
Audiolab 8200T DAB AM FM Tuner
Edited by JerryTostevin
Price reduction
    • By MFidelity
      Item: schematic for Electrocompaniet ECI 5 (not ECI5 MKII)
      Price Range: $20 or ONO
      Item Condition: New or Used
      If you can help to find a full schematic, I need to know R620 R621 resistors value.
      (thanks Rockeater. That is the first thing I did but they direct me a local dealer in Melbourne that never reply any email.
      thanks Aab. I will Geiger a try. Will let you know the result.  Will contact you.
      sorry I am new here don’t know how to PM and reply....)
    • By afie
      So currently I have nothing setup, but have narrowed down on speakers and am looking for what avr/power amp/dac are required to make work everything I desire.
      Id like to be able to have a 2ch setup for a main tv/kitchen/living area, with speakers to play:
      - music currently on a hard drive (internal and external);
      - tv/movies through streaming apps like Netflix through a Fetch box or a Xbox1 or a Chromecast;
      - streaming apps/Youtube through casting from an iphone.
      Sound quality of music is the priority, but I do find it much easier to hear spoken words on tv with separate speakers.
      I have been looking at Ascension speakers from Adelaide and talked to the guy there last year.  The likely model will be around 150 wrms at 8 ohms. I will call him again to discuss, but if I remember correctly from what he recommended last time, an AVR to drive such speakers is expensive relative to the speakers just to offer extra channels that I don't need. Would a suitable alternative be a 2ch power amp plus a second device to hand all the digital inputs?
      Emotiva BASX A-300 or AMC: 2N100MKII-2 are both 150w 8ohm power amps for about $800, but an AVR that can do 150w at 8 ohms are about $5k - what am I missing here? Ive looked into this several times over the last year and I feel like I am just going round in circles.
      Any help would be appreciated. Cheers.
    • By iceman
      Price: $1300 Item Condition: As new, barely used Shipping Options: I can ship this item Suburb or Town: Canberra State: Australian Capital Territory Payment Method: Bank transfer Reason for selling: Due to space limitations for speakers, I moved to a headphone only set up and there do not require an amplifiers and speakers Further information:
       They have won a HiFi Pig award.
      https://hifipig.com/graham-slee-proprius-mono-power-amps/
      Item Measurement Power output (rms) measured 26 Watts into 8 Ohms; 45.5 Watts into 4 Ohms (ref 1% THD+N at 1kHz) Power bandwidth at rated power into 8 Ohms 10Hz - 47kHz (-3dB), 20Hz - 25kHz (-1dB) Power bandwidth at rated power into 4 Ohms 12Hz - 40kHz (-3dB) Total harmonic distortion and noise at 8 Ohms 100Hz: 0.043%; 1kHz: 0.047%; 5kHz: 0.061%; 10kHz: 0.085%; 20kHz: 0.125% Total harmonic distortion and noise at 4 Ohms 100Hz: 0.066%; 1kHz: 0.071%; 5kHz: 0.094%; 10kHz: 0.129%; 20kHz: 0.181% Signal to noise ratio in dB "A-weighted": 87dB; 22Hz-22kHz "Q-pk": 80dB Bias type Class Ab; Bias current: 60mA (approx.) Input sensitivity for rated output 575mV rms Short circuit protection Fuse and power supply shut-down (short circuits should be avoided to prevent component stresses) Fuse F2A 5mm x 20mm (glass "quick-blow" fuse rated at 2A) Power supply 48V DC, 120 Watt - self adjusting to AC mains 100V - 240V, 47 - 63 Hz; IEC cord supplied Size (approx.)
      Amp W105 x H55 x D205 mm; Power supply W65 H40 D170 mm Photos: Advertisements without photos of the actual item will not be approved.
    • By olegau
      Price: $350 Item Condition: good working order Shipping Options: Pickup is available,Audition is not available, but in-person pickup can be arranged with limited personal contact Suburb or Town: Melbourne State: Victoria Payment Method: Cash on Pickup Reason for selling: too many amps Further information:
      The amp was checked and serviced recently.
      Frequency response: 4Hz to 100kHz
      Damping factor: 1000
      Input sensitivity: 0.25mV (MC), 2.5mV (MM), 150mV (line)
      Signal to noise ratio: 70dB (MC), 75dB (MM), 97dB (line)
      Speaker load impedance: 4Ω (minimum)
      Dimensions: 440 x 121 x 347mm
      Weight: 10.1kg
      Year: 1991
      Price: GBP £400 (1991)
    • By zakblue
      Price: $1300 Item Condition: Excellent Shipping Options: Pickup is available Suburb or Town: Balwyn State: Victoria Payment Method: Paypal, EFT, Cash on Pickup Reason for selling: NLR
      These were purchased from this SnA member here:
      75W per channel with 4xEL34 tubes on each amp.
      Lightly used to power my left and right mains for HT duties.
      Happy to demo for serious buyers. Weight is 30kg each.
