kroozzy
DIY - HiFi Racks - Stands - Cabinets
On 08/10/2018 at 12:37 PM, ellisr63 said:
Pardon the mess...this is my t-channel rack
nicely organized
Built a few years ago now but still serving me well.
About 75 KG on the top rack so made very strong with laminated 18mm Russian birch ply and domino joints holding it all together .
Lots of ventilation for all the tubes......
Thank you for the compliment.
While your suggestion for bolt-spikes is valid, I don't think that bolts ground to a point and pennies as protectors matches my design. Plus once the stand is assembled there wouldn't be anything to attach the bolts to. Here's the design drawing from my first post:
1-Stereo-Stand.png&key=d1cb75d81fa03a90ffbb0bd07dd342ea3a91e70d3ab488934aa39b417ae78fb1
Now I understand. My idea would only work if you were making the shelves to sit on top if another shelf.
On 13/10/2018 at 4:33 AM, FrostEOne said:
Here's a couple finished pics at a different angle, pretty close to glass smooth,  Quite happy with how these came out, going to allow them to dry a couple more days before turning them over to do top sides.
f0ad8c97-9a5d-4cb2-bdbb-75d42c4c6af1-ori
556c58d5-39a9-4187-9ae2-55c5c87fdca1-ori
Wow!!!... love the perfection of glossy finish work you have done.
Here is the progress of my work...still working on it 😓
Very nice work....:thumb:
Thank you for the compliment HiFi-Man, what you see there is the result of 3 weeks work, 19 thin coats of Epifanes varnish lightly sanded with 400 grit between each coat.
Looking good HiFi-Man!  Wish we had your weather, headed towards winter here, hi of 49F (9.5C) today.
Edited by FrostEOne
temperature conversion
On 06/10/2018 at 9:35 AM, FrostEOne said:
Found out something new to me today and I am totally impressed!
Noticed back when looking for 00 and 0000 steel wool local availability, that Lowes lists Scotch-Brite as steel wool.
Been thinking about that in the back of my mind since, so today I tried a piece of brown Scotch-Brite (comparable to 00 steel wool) under my sanding block.
Using it under the sanding block kept it flat, achieving way more surface contact.
Works faster than steel wool and keeps the surface much flatter as well.
Going to put the 14th coat of varnish on now, pics late today or first thing tomorrow.
Update - Using steel wool or scotch-brite for this wasn't the way to go, left too many imperfections. Sanding with a block between each coat keeps the work much flatter and guarantees the high spots are removed.
Read more
Your spike idea got me thinking, I could make some 2" (51mm) spikes for my uprights and receiver disks for the shelf tops, then stack the shelves without bolts.
I think that could be an interesting concept!  Now need to locate some solid stainless big enough.
Yes, we got a really nice weather here...slowly switching to summer.
Here is another pic of the day :)
I'm not that good when it comes to finishing job. Would like to maintain the two colour tone. The legs & bracings need to be given a light colour stain (Oak or Walnut). Just applied Mahogany stain on shelves and one coat of satin wood polish.
Do you do sanding using light grain paper/0000 steel o wool between each coat?
Edited by HiFi-Man
I really like that mahogany stain.  I have tried steel wool & scotch-brite, but sanding does the best for me. Keeps the work flatter and ensures the high spots are knocked off. In my case, we're looking at around 20 thin coats of spar varnish thinned 50/50 with mineral spirits. I wipe it on with a lint free cotton rag, very thin coats.
 I was thinking of doing that when I was working on my current design too. Try it out and post up your pics, and thoughts!
When you do a 2 color setup...how do you stop the stain from bleeding?
I'm guessing masking tape
I think you'll struggle to avoid the strain bleeding into the pine as it's very soft and porous. You be better to disassemble first.
That's what I was thinking too, but it looked like it was assembled permanently already.
Covered the joint area of legs with masking tape. Still its a tuff job from preventing it from being absorbed by the legs.
Applied the stain on shelves (Karri wood panel) step by step, each very light coat with extra care.
Its already assembled permanently. I think the best way was to apply stain on legs first, polish it and then apply stain on shelves. but its already late now. Or applying stain before assembling them together. I'm a beginner and learning lessons from mistakes :)
Yes.
Thank You all for pointing these and let me learn more :)
Edited by HiFi-Man
1 hour ago, HiFi-Man said:
That is classy HiFi-Man, looks real good!  The oak supports and pine uprights match quite well. My only critique is I would have made the top cap the uprights, but that's a personal preference.
Thanks, that's a good suggestion. Thinking about adding a cap slowly...brass or tan leather with black thread stiching.
Did'nt complete the finishing process but helping someone I know in Australian HiFi and AV show 2018, Melbourne. Aries Cerat units on the Rack :)
In last photo, total 170kgs on the rack.
Edited by HiFi-Man
Looks real fine sitting there with equipment on it!  Leather would be interesting, lot one could do with leather, but not sure I'd cover that nice wood though..
I'm pretty much "old school" still run the Yamaha NS1000M I bought in 1975.  What is that speaker to the left of your rack?
Edited by FrostEOne
additions
After 6 weeks wait, my 3-Post Sound Anchor speaker stands have finally shipped.  Scheduled to arrive Wed 10/24, was beginning to think I'd have the stereo stand finished before these arrived.
b2c5f36a-6943-484a-9be0-c29f80e4c33b-ori
Won't be covering the entire legs with leather or a brass cap on top as you suggested is a good option too.
I'm also an old school guy, using McIntosh 240 & Tannoy Arden as my main system.
Those speakers in photo are Aries Cerat Symphonia Limited Edition speakers which is exhibited in Austrian HiFi and AV show 2018, Melbourne.
Edited by HiFi-Man
Aries Cerat's Symphonia Aries Limited Edition 3-way horn loudspeakers $125,000 US/pair.
Way too steep for my blood!
Edited by FrostEOne
    • By robes
      Item Condition: Very Good Shipping Options: Pickup available but audition is not available. Suburb or Town: Ryde State: New South Wales Payment Method: Cash on pickup Reason for selling: NLR Further information:
      Kef's LS50 speakers with stands, ready to go to a good home
      Both items are in very good condition as pictured.
      Not sure as to the model of the stands.
      PLEASE READ
    • By mashley
      Item Condition: Excellent Condition 9+/10 Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Potts Point State: New South Wales Payment Method: PayPal, EFT only Reason for selling: No longer required Further information:
      Now surplus to my needs are these Concorde SP24 Steel Speaker Stands in Black.
      They've been in storage for about a year.
        These have a triangular base making for easy levelling adjustments.   They have been carefully looked after and have only slight signs of use.   They can be filled with sand or lead shot for extra damping if required.   Height of the stands is 24 inches (61 cm).   They come in the original box and packaging with spikes and cable guides.   The box measures 690 x 300 x 130 mm and weighs 10kg.   Example postage from Auspost calculator: to Melbourne 3000 $25.50 to Brisbane 4001 $25.50 to Hobart 7000 $33.50 to Perth 6000 $37.25.   Delivery might be possible if you are in inner Sydney suburbs or close to M4. Please ask.   They will be listed on eBay after a few days.   Photos:
    • By Dazznor
      Item Condition: New Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition.,Shipping is included in price. Suburb or Town: New Farm State: Queensland Payment Method: Paypal, EFT, Cash Reason for selling: Made the stands for the purpose of selling Solidly welded from heavy 14 gauge steel to provide strength and excellent acoustic characteristics. The side vertical beam has been welded for neatness and strength while others variations do not.
      Dimensions: Top platform 15.25" w x 13" d, front height 8", Tilt 5°.
      I've made these for the JBL L100 but I believe they also correct Klipsch Heresey 4 and others. Check with above dimensions first.
      Powder coated in satin black.
      M6 Nuteserts in the base for attaching additional items for advanced acoustic isolation. (Gaia III shown in picture, not included in sale of item ).
    • By earthwolf82
      Item Condition: Good Shipping Options: Pickup available but audition is not available. Suburb or Town: Kilsyth South State: Victoria Payment Method: PayPal, cash Reason for selling: Not needed anymore Further information: No longer in Melbourne, but can be picked up from my old address. Would prefer paypal payment.
    • By dipster
      Price: $150 Item Condition: Used. Some paint chipped at the back of the top plate. Otherwise really good. Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition. Suburb or Town: Darlinghurst State: New South Wales Payment Method: Cash on Pickup Reason for selling: Not using I paid $279 for these in 2011.
      Includes carpet spikes, but no gel isolation pads. These can be purchased separately if you need them.
      Haven't seen much use which is why I'm selling them.
      You can pick them up from Darlinghurst or I can drop them if you're not too far. I drive up to Roseville a couple of times per week, anywhere along that route would be easy.
      There's a bit of paint chipped at the back of the top plate. I've tried to show it in one of the photos.
