Lucie Audio
8pm Wednesday 18th July, visitors welcome.
Willis Room, City of Whitehorse Offices
Maroondah Highway (Whitehorse Road), Nunawading
Melway Map 48 Ref G9
Contact: 9437 1249
When it comes to choosing or designing a loudspeaker there are two rules to consider: Rule #1; There is no such thing as a perfect loudspeaker. Every design is a series of compromises. Rule #2; One has to accept that there will be compromises and decide on a design which reduces these compromises.
This month's presenter has developed a speaker system which further reduces the compromises associated with the conventional passive loudspeaker. Rick Bond from Lucie Audio will be demonstrating his speaker system which utilises active crossovers with room equalisation by means of his DSP pre-amplifier. "Our pre-amp is built around the capabilities and feature set of the MiniDSP 2x4HD processor board. This gives us the power to process the stereo audio stream in real time to perform room corrections and digital crossover functions. Correction technology is powered by Dirac Research AB, world leaders in this field".
The process maps out the frequency and impulse response characteristics of the speakers in the room in a 3D grid around the listening position. After completing a frequency sweep with a microphone connected to the computer, a desired frequency response curve and an optimised impulse response are measured; the data and a set of filters are generated to map the two together. This data is then uploaded to the unit and stored in one of four configuration slots. This provides great flexibility in that up to four combinations of tonal response, crossover parameters and optimal listening position can be stored and readily recalled via the unit's remote control.
"To get the best from the MiniDSP hardware, we developed an active analogue volume control board. Maintaining volume control in the analogue domain provides the best approach to the gain structure".
Rick will be demonstrating his system with two sets of book shelf speakers and a matching subwoofer. He has developed these two distinct speakers to cater for the tastes of the listener. The Lucie Model One Loudspeaker is a 6.5" Point Source design. The full range driver is sourced from Dayton Audio for its zero crossover distortion. Excelling at delivering the nuances in the midrange, this design is recommended where primarily acoustic music is appreciated in a small to medium, focused listening environment.
The Lucie Model Two Loudspeaker is a traditional two-way compact speaker with drivers from SB Acoustics and Scan-Speak. Recommended and pre-set crossover slopes from the DSP Pre-Amp are set at 6db per octave and centred at a fairly high 4kHz. First-order crossover slopes are chosen for their phase neutrality, made possible by the smooth and extended response of both drivers. This bass reflex (ported) design has a greater power handling and more driver excursion, better suited to bass-heavy music. The system extends the response well below the frequency of the cabinet, giving exceptional performance for a fairly compact enclosure.
Cabinet materials are chosen for their high density and sustainability. Narrow grain carbonised Bamboo or Baltic Birch ply are laminated, no veneers are used, precision CNC cut then hand assembled and finished. Due to the laminar sheet construction inner wall profiles are able to be uniquely contoured to minimise internal reflections and cabinet resonances.
This will be Rick Bonds first public presentation at an audio event. A relative new-comer to the HiFi scene, this young man has developed a complete active system that puts DSP technology within the reach of many audiophiles.
Nick Karayanis
Program Co-ordinator
Ken Tripp
Wise and Wonderful Webmaster
Melbourne Audio Club, Inc.
http://www.melbourneaudioclub.org.au
StereoNET's own [mention=152455]coffeemachinist[/mention] - Good luck Rick!
Was fortunate enough to have Rick demonstrate his exciting new concept and can highly recommend an audition!
Just wanted to follow up and say thanks for coming last night to the several SNA members I spotted in the crowd. I thoroughly embraced the chance to waffle on about my gear for a while and spin some tunes. Hope you enjoyed!
-Rick
Rick, do you have a webpage for Lucie Audio where we can see your speakers yet?
regards Ian
Hi Ian,
A pertinent question! As of right now, no - but it's in the works. It's early days and I wanted to focus on the products first and foremost, as there's not much use having a website, marketing material and sales platform while the products go unfinished.
But - I have been posting updates on my favourite social media platform Instagram - lots of behind the scenes and work in progress stuff if you're interested. You can find it at www.instagram.com/lucieaudio
Also I'll post below my notes and technical background of my designs - and of course I'd be happy to answer any questions you may have.
The technical foundations of Lucie lie in room correction and efficient amplification, and their liberation in getting the best out of some fairly unconventional loudspeaker designs. Central to this is the premise that most commercially available speaker designs are based on a series of assumptions relative to the end user's room acoustics and tonal preferences, which are only by occasional chance completely accurate. The uncomfortable fact in sound reproduction is that the listening environment is so often the deciding factor in overall enjoyment of the system, and it is a topic that is seldom addressed when choosing one piece of equipment over another.
Tone controls or EQ are very unfashionable topics in modern hi fi, and I'm not sure why that happened - often the recommendation is to buy this or that because it has this or that tonal balance, but this is fraught with peril for so many reasons - why not have freedom to tune the system as a whole, together with the room!
The use of DSP allows just this - to achieve the best possible result in terms of tonal balance, soundstage and accurate presentation of instruments and voices.
The DSP pre-amplifier -
Our pre-amp is built around the capabilities and feature set of the MiniDSP 2x4HD processor board. This gives us the power to process the stereo audio stream in real time to perform room correction and digital crossover functions. Room correction function is powered by Dirac, world leaders in this technology. The Dirac Live platform combines powerful and flexible capabilities with an easy to follow measurement process.
In brief, this process maps out the response characteristics of the loudspeakers in the room in a 3D grid around the listening position, using a series of frequency sweeps recorded by a supplied measurement microphone connected to a PC running the measurement utility. After completing the measurements, the summed frequency response is displayed, and a target or desired frequency response curve can be superimposed over the measured data and a set of filters generated to map the two together.  This data is then uploaded to the unit and stored in one of four configuration slots, which can be easily activated via the unit's remote control or via the software utility. This provides great flexiblity in that up to four combinations of tonal response and optimal listening position can be stored and readily recalled.
To get the best from the MiniDSP hardware, we developed an active analog volume control board to provide the best approach to gain structure, ie. maintaining volume control in the analog domain, before power amplification. A custom linear power supply for the volume control and DSP boards ensure top audio performance.
Power amplification -
Our power amps are built on modular designs from Hypex in the Netherlands. Hypex are at the forefront of a new era of ultra high performance Class D amplification. Amplifiers based on their Ncore technology developed by Bruno Putzeys are now appearing in the highest echelon of products from boutique manufacturers like Mola Mola, to mainstream brand offerings such as the NAD Master series. Modular design allows us to configure number of channels and power output according to individual needs.
Specifications of Ncore amp modules are superb across the board, and their characteristics focus on neutrality and resolving power -  Ncore is the first Class-D amplifier not just to nudge the best linear amplifiers, but to surpass them in every aspect relevant to sound quality.
Loudspeakers -
Our philosophy with loudspeakers is to stray somewhat from established design norms, made possible by harnessing the power of DSP and active crossovers available in the pre-amp, and multiple channels of amplification in our power amp. Central to this is the goal of eliminating phase issues across the mid range, where our auditory system is most sensitive.
Analog dividing networks or crossovers found in conventional hi-fi speakers are used to split up the full spectrum of audio into smaller chunks that can be effectively handled by transducers designed for low, mid or high frequencies.
These sometimes very complex networks of passive components (inductors, resistors and capacitors) have a significant influence on the overall character of a speaker design. Careful attention must be paid to their properties, individually and as a whole, if the combined acoustic energy of the drive units and crossover network is to be rendered accurately in the time domain, and at equal amplitude independent of frequency. Of crucial importance is the sum of the signal when it is originating from two separate sources, for example in the overlapping range between high and low frequency drivers.
The best drivers available can be made worthless by an improper crossover or cabinet design, but even when optimised, a passive crossover design will entail several compromises and assumptions about the influence of the listening room, for example how much baffle step compensation or bass boost should be added to cancel cabinet losses - this is a variable and dependent on final placement in the room, yet it must be baked into the crossover design.
So for us, active crossovers and room equalisation allow a key advantage - to dispense with the cost and complexity of analog crossover networks wherever possible, and give access to a wider range of drivers with some tempting advantages, taming the characteristics that would otherwise make them unfeasible in passive designs.
Cabinet materials are chosen for their quality - sustainable, high density and naturally beautiful timber laminates, precision CNC cut and hand assembled and finished. Due to the laminar sheet construction, inner wall profiles are able to be uniquely contoured to minimise internal reflections and cabinet resonances.
Lucie Model One loudspeaker (names TBC!)
The simplest expression of the Lucie loudspeaker philosophy -  a single point source driver delivers the full audio signal. Zero crossover distortion or phase errors. A large, light and strong paper composite diaphragm with powerful neodymium motor give neutral and transparent vocal rendition and a precise and vivid soundstage. Excelling at delivering accurate and nuanced midrange, this design is highly recommended where primarily acoustic music is appreciated in a small to medium, focused listening environment.
Single driver full range, bass reflex (ported) enclosure
Size: 18 litres (medium bookshelf / stand mount)
Frequency response: 65hz -18khz (-3dB-0dB)
Crossover- nil
Impedance - 8 ohm nominal
Lucie Model Two loudspeaker
A traditional two-way compact loudspeaker with state of the art low distortion drivers from SB Acoustics and Scan-Speak. Extending linear frequency response above and below the Model One, the design physically time-aligns the acoustic energy from the low and high frequency drivers to maintain neutrality and phase coherence through the crossover range. Recommended and pre-set crossover slopes are 6dB per octave centred at a fairly high 4khz, meaning the low frequency driver is handling more midrange energy. First-order crossover slopes are chosen for their  phase neutrality, and made possible by the smooth and extended response of both drivers outside their designated passband. Wider directivity and thus a broader sweetspot are delivered by the cloth dome tweeter and shallow cabinet wave guide. Qualitatively, these design choices deliver an accurate and neutral, yet non-fatiguing loudspeaker with excellent directivity. With more driver excursion and power handling on tap and a lower resonant frequency, this design is better suited to bass-heavy music without reinforcement via a subwoofer.
Two-way full range, bass reflex (ported) enclosure
Size: 16.5 litres (medium bookshelf / stand mount)
Frequency response: 35hz -25khz (-3dB-0dB)
Crossover- nil, active via DSP (two channels of amplification required for low frequency and high frequency), passive available as an option.
Impedance - 4 ohm nominal
Lucie Subwoofer
Built to extend the frequency response of the bookshelf cabinets to the very lowest octaves. The sealed construction and large, low distortion driver give extremely linear bass performance, and the use of a Linkwitz Transform equalisation in the DSP system extends response well below the resonant frequency of the cabinet, giving exceptional performance for a fairly compact enclosure.
Sealed enclosure, single 12" driver
Size: 30 litres, floor standing
Frequency response: 20hz - rolloff frequency (eg. 120hz)
Built-in amplifier power - 500 watts, class A-B with linear power supply
Material options available for loudspeakers: Baltic birch ply or narrow grain carbonised bamboo, solid laminated construction (no veneers used)
Finishes: Natural oiled or Black Japan, others possible via consultation
Cheers, Rick
Any pics of your speakers?
Sounds similar in principle to the Kii three,, but they use multiple drivers to create a cardioid response.
13 hours ago, coffeemachinist said:
Hi Ian,
Loudspeakers -
Crossover- nil
Lucie Subwoofer
Cheers, Rick
Rick, thanks for your very informative reply and the instagram page!  Love that CNC layered enclosure construction, way to go I reckon! Wouldn't mind an audition one day, I'm in Northcote as well.
Curious about class D amplification, I'm still not convinced of it's sound qualities. A couple of SNA'ers, andyr and djb have setups with miniDSP and conventional class AB amplification, andyr's is especially impressive, Maggies tri amped with Hugh Dean's NAKSA amps. Jon de Sensi also has an excellent setup with four way active Linkwitz open baffles with DSP and his Open Audio Designs (custom 4 channel per mono block amplification)
regards Ian
Yep, I deliberated long and hard about the question of whether to go down the path of in-cabinet electronics.
For the reasons outlined below I decided that for me it wasn't the way to go.
  • For the argument of de-cluttering the cable runs, I figure once you have run 240V power to each cabinet, you might as well just have a four core traditional speaker cable rather than power and signal from source to speaker one, then processed signal from speaker one to two. Unless you go wireless - and we are not there yet to implement that at a quality level I'd be comfortable with.
  • DSP capable plate amps certainly are around, but none that would allow me to maintain volume control in the analog domain, via remote - a key advantage of our pre-amp in my view.
  • The Hypex amps generate quite a bit of heat, even our substantial heat sink gets warm. I don't like the idea of sitting them in non ventilated wooden boxes and feeding in 240V.
  • I like the idea of giving customers flexibility to BYO amplification - some people will have power or integrated amps they know and love, but want to add DSP to the mix. This approach achieves that.
  • I'm proud of the work we've done on our electronics enclosures, and would hope our customers appreciate them and put them on display, while being compact and visually unobtrusive.
  • This approach gives maximum opportunity to expand or upgrade the capabilities down the line, without having to design and manufacture a completely new amp/DSP module.
Hope that makes sense!
Cheers, Rick
Hi Ian,
Welcome to stop by any time! I think an audition would impress - could also loan you our prototype Hypex amp if you want to try it out in your system. I find the ncore's  to be as close to the idea of 'straight wire with gain' amplification that I've ever heard. Not saying that's the holy grail necessarily, but it's captured my interest for sure.
9 minutes ago, coffeemachinist said:
Hi Ian,
thanks for the offer!
regards Ian
2 hours ago, coffeemachinist said:
Hi Ian,
I'd love to have a listen too. Where are you located ?
Edited by Sir Sanders Zingmore
    • By ArthurDent
      Hulgich Audio & Holton Precision Audio
      8pm Wednesday 21st August
      Contact: 9437 1249
      This month we have two interstate companies joining forces to present their Hi Fi products at the MAC. Both have exhibited together at the Melbourne International Hi Fi Show, winning "Best of Show Overall" for 2017 as well as "Best New Comer".
      Hulgich Audio is a new speaker company based in Adelaide headed by Nicolas Hulgich (pronounced Eu-Lich), who has spent more than twenty years in both Australia and his native Argentina building speakers with a variety of designs. He will be presenting to the club his statement speaker the 'Duke', with his in-house FTM (Feel The Music) speaker cable and interconnects.
      The 'Duke' is a 3-way floor stander designed as a dual enclosure. The upper enclosure houses a 1.2 inch dimple dome tweeter, and a 6 inch midrange made of papyrus fibres. The lower bass enclosure is a ported design that houses a 10 inch woofer also made of papyrus fibres. Hulgich has designed the 'Duke' to have a huge sweet spot and a large sound stage. By applying 'Low Diffraction Baffle Technology' (LDBT) that insures a smooth frequency response whether sitting off or on axis, and 'Coherent Sound Technology'( CST) which provides driver time alignment and phase integration.
      Nicolas will be playing his music with a modified OPPO 103 Multi-disc player and a AudioGD R8 Ladder Dac. Amplification is provided by Holton Precision Audio. Based in northern Tasmania, Anthony Holton has been designing and building high end amplifiers that have been demonstrated internationally at the 2018 Paris and Munich Hi-Fi Shows
      Anthony will be demonstrating two stereo amplifiers on the night, the Holton One-Zero-Zero Supreme (2x120W into 8 Ohms), and the Five-Zero-Zero Supreme (2x500W into 4 Ohms) with the matching Gain Block One Preamp. On static display will be a Phono Pre, while a 'DC Blocker One' will be used to look after the AC mains. This audio grade conditioner removes DC and filters the noise from the mains.
      With two presenters for the night, we are certainly going to have twice the value when it comes to sound quality. Not to be missed.
      Nick Karayanis, Program Co-Ordinator.
      Ken Tripp
    • By ArthurDent
      Mark Doehmann and Tivoli Hi-Fi Presents
      8pm Wednesday 20th March, visitors welcome.
      Contact: 9437 1249
      This month's Melbourne Audio Club meeting will be a collaboration between two presenters. Mark Doehmann the turntable engineer / designer and Tivoli Hi-Fi, Melbourns longest running high-end retail outlet. Both will have a system to demonstrate from their portfolio of hi-fi products.
      Mark is best known for his high-end turntable designs, having broken new ground in class leading performance by pushing the envelope and challenging the status quo. He has a well-respected track record for innovation and design for both turntables and tonearms. He will present on the new features and sounds of his Helix 1 and model 2 turntable.
      Ypsilon Audio is a brand that has established it's self in the high-end scene, which Mark has introduced to the Australian market. There latest product the Phaeton, is an integrated hybrid design with a single-ended Class A performance with the power of a push-pull, at 110W into 8 ohms. Accompanying the amplifier will be a pair of German Physiks Omni direction speakers.
      The second system from Tivoli Hi-Fi will also feature a pair of Omni Directional speakers. The brand is well known for its futurist looking active loudspeakers; these will be from B&O. At the time of this article, Tivoli was still finalising which B&O model they will bring on the night. They will have a music server from Cocktail Audio, in fact two models the X30 and the X45, a streamer and CD ripper for us to listen too.
      The Hi -Fi industry comprises a large diversity of people, who are pursuing their passion to improve our audio experiences; this month's meeting will be a night not to be missed.
      Nick Karayanis , Program Co-ordinator
      Ken Tripp
    • By ArthurDent
      The ATC SCM19A Active Speaker
      8pm Wednesday 20th February, visitors welcome.
      Contact: 9437 1249
      The Acoustic Transducer Company, ATC for short, is one of a handful of pro-audio companies to have crossed over successfully into the Hi Fi arena. The company was founded back in 1976 by Billy Woodman, an Australian acoustician who developed the famous 3 inch soft dome mid-range driver for professional monitor speakers. Many audiophiles would be very familiar with the domestic range of ATC speakers, with numerous reviews in many magazines.
      JAG Imports will be presenting at the club the latest active speaker from the new 'Entry Series', the SCM 19A. The least expensive active floorstander in the range, this two way model stands just under a meter high and carries a 182 Watt power pack that is installed in the bottom half of the tower. The 150mm Mid/Bass driver is powered with 150 watts while the 25mm Soft Dome Tweeter receives 32 watts. The Mid/Bass employs ATC's new 'ground-breaking' Super Linear Technology, said to reduce third harmonic distortion by 10-15dB between 100Hz and 3KHz. The tweeter employs a unique dual suspension system suppressing diaphragm rocking modes.
      Keep in mind that because it is an active design, a number of compromises have been eliminated from their passive twin. With the implementation of an electronic x-over in the amp module, the passive crossover network components have been removed and thus are no longer subjected to vibrations from the internal back wave of the drivers. The biamplified system is able to power the drivers without the significant power losses of a passive network. Separate active circuits can individually control magnitude and phase allowing both to be optimised, and minimising speaker cabling allows you to control the bass driver by maximising the damping factor.
      The SCM19A is an important addition to ATC's extensive domestic lineup. The combination of power handling, ruggedness and lack of colouration are qualities that make ATC speakers a leading product.
      Ken Tripp
    • By logarhythm
      Item: See below
      Price: See below
      Item Condition: New like
      Reason for selling: Analogue dreams
          Gustard U12 USB / SPDIF XMOS convertor 32 bit 384k (New in opened box) $180 posted
      Open DRC DA8 - DAC, room correction and 4 way electronic crossover and by Minidsp (New like, had a fiddle but has not been set up - with original box) $SOLD (will cost you $460 delivered from minidsp)
        Photos from web: OpenDRC DA8
          Gustard U12:
    • By ArthurDent
      A Raspberry Pi Music Night
      8pm Wednesday 16th January, visitors welcome.
      Contact: 9437 1249
      This month's Melbourne Audio club meeting will be entirely presented to you by your committee members. They will present to the club a selection of music from their favourite CDs. It could be a track from their 'desert island discs' or a recent purchase.
      To ensure that we get through as many different tracks, I've requested that each track be no more than 5 minutes long. This will get us through plenty of music before the coffee break. While it's good to have a music program of varied tastes, the audio system to play it on, will be just as interesting.
      Chris M will start off the night with his 'Raspberry Pi' Music Server. This super versatile palm-sized computer was developed in the UK to promote teaching of basic computer science in schools. Now in its third generation, many DIY groups have developed several different uses for this computer, everything from a Home Weather Station to a Media Server for your television.
      The 'Pi' has its own Wi-Fi output as well as four USB2 connections. Chris operates the unit from a tablet with a modified program called Moode. His music selection will be sourced from a USB drive while his latest DAC, XMOS U8 which uses an AKM chip from their 'Velvet Sound' generation, will take care of the sound. An OPPO multi disc player will also be available on the night for the other members to play their discs.
      This would be a good opportunity for all members who are new to the club, as well as the regulars, to discover some new sounds. I'm sure the guys on the committee will do their best to present a thoroughly satisfying night of music.
      Ken Tripp
