bhobba
KLE Innovations USB Cable
I ordered some power and speaker cables, to go with the new Grandinote amp and DAC I am getting from Mike Lenehan, from Keith at KLE.  He said no problem, I will bring some over and you can see how they go.  Also, he mentioned, I have been thinking about a USB cable for a while, do you mind if I borrow your Mac-book as a source to develop it.  I said sure.   When finished, and bring the Mac-book back, can I bring it over, as well as the other cables, and see what you think.  I said sure - should be interesting.
Before going on I need to disclose I know Keith, having been with him at many GTG's, he is a fellow member of the Queesnslnd Audio Club, and have been with him during many listening sessions tweaking the Lenehan Audio ML5's, and hearing what his cables do.
OK - power cables easily better than the standard ones I had in my system.  Very analogue like and more revealing - sort of like a layer of grunge removed.  But its hardly a fair comparison, as I said the cables I had were simply standard HW store stuff.  The speaker cables were more interesting.   They were replacing 10 year old Lenehan Audio Ribbonflex.   Sound stage widened, much more harmonically rich and analogue like, more depth.  Spoke to Mike and it didn't surprise him, things have moved on a lot in his cables - his new ones are a lot better.  Trouble is at the moment Mikes cables have trouble with the Grandinote amp that Mike needs to sort out.
But now  to the USB.  In the future when I have the Grandinote I will not be using USB - with that DAC you either stream or direct connect a USB Drive.  At the moment I am using a small Curios from an ISO Regen into a Direct Stream.  Generally the Curios has the edge on other cables.   Well I was stonkered - here Keith's Cable was up there.   Again more analogue like, the sound stage widened with greater depth.  It was more organic.   Was it better - maybe the Curious had some better detail - I don't know.  Rawl99 calls texture and a organic type sound better harmonic resolution so maybe that's what it had.  What I can say for sure is its one fine USB Cable.
Like all things in Audio best to listen to it first to make up your mind - and do it blind if you are into that sort of thing.
And please if you think cables make no difference watch the following where Rob Watts explains things that you can barely measure the difference between even with the best state of the art equipment are clearly audible, things other engineers say obviously would make no difference:
Also some say - regarding power cables - with all the cable before how can the last bit make any difference?  Does a filter in the cable make no difference?  As Rob mentioned above about experiments with cables - power and otherwise - RFI effects of different cables, again barely if at all measurable, make clearly audible differences.
And if you want to hear it for yourself all the cables will be at the GTG on the 4th of August at Mike Lenehans.
Bill
Edited by bhobba
The KLEI power cables are simply CSY industrial cables that sell for around $10 per metre max.  I've been told that he uses a 4-core and KLEI ties 3 of the cores to negative and uses the fragile screen for ground.  I used to sell them before finding out that they were non-complying with Australian standards.  As to the USB cable KLEI has little experience in this field and I suggest bhobba that you are advertising or easily impressed.
Mods, please note that I sell neither power cords nor USB cables.
I have been assured by the maker, and Rawl99 who has a honors degree in electrical engineering has confirmed it, they are fully compliant.   Where you are getting your info from beats me.
I paid for these cables (except the USB which because I will probably move to the Gradinote which does not require USB cables I may not get) - I did not get them for free - and it is not an inconsiderable amount.  I do not pay money like this for no reason.
Have you considered the reliability of whoever is telling you this?
And BTW please read what I am suggesting.   Just listen to it and do a blind test if you want.  Blind tests for one person are dead easy and will tell immediately if it's hooey or not.
Mike Lenehan tried to build some power cables and built some prototypes.   He failed miserably - a simple Yarbo beat them.   Believe me - I have heard this cable against the Yarbo and it was no contest.   That's just my view of course - have a listen yourself and make up your own mind - its that easy.
Bill
Edited by bhobba
What do you mean ?
5 hours ago, Sir Sanders Zingmore said:
What do you mean ?
Would it be capacitance?
Hope not :fear:
There were some previous well-documented discussions on the design and legality of the cable, including a number of photos showing a disassembled cable and the construction method.
Investigations suggested that she's a length of multi-core SY industrial cable wired in accordance with Keith's 'Eichmann Ratio' which is based around thicker negative/neutral conductors (hence the multi-core SY cable with several conductors bunched for the neutral wire) and finished off with custom-ordered plugs from Wonplug in China.
Hope not :fear:
It would have to be capacitance, although as far as I understand the foils in Mikes new cables are not laid upon each other so capacitance should be ok.
The more accurate phrase would be "the Grandinote amp has trouble with Mikes cables" rather than vice versa.
6 hours ago, Sir Sanders Zingmore said:
What do you mean ?
At the moment they do not work - maybe high capacitance we do not know as yet.   He is investigating.   Keith's cables sound pretty good though - so since my cables were getting old decided to get some new ones.  Will be taking them down to Mikes today so they can be put into the system for the GTG and thoroughly burnt in.  These include 3 power cables - the amp is literally two monoblocks with two power cable inlets.
Bill
Edited by bhobba
What do you mean ?
What do you mean when you say they do not work?
theres no sound? The sound is no good? The amps blow up?
I have no idea how they are made - Keith has some white papers on his site - but that's all I know.
Now if anyone is worried they are illegal, posting here to warn people is OK.   The maker and some people I know to be professionally qualified, including engineers and electricians, claim otherwise.  What do you do in that case?   The maker believes he is legal, professionals I know say its legal, but some people here do not.  That really is as far as it can go on a forum like this.   Those people that believe its illegal should go to the authorities such as consumer protection, not jump up and down about it on this forum.  If it is illegal then the damage done to Keith's reputation will be great - he may even go bankrupt.   This is a thing that should not be discussed here - its a legal matter - and should be handled that way.
All that will happen is each side will retreat to their entrenched positions and nothing will be gained except a thread of little value.  This is a legal matter - if true it would be fraud, and all sorts of things.   We are not the appropriate place to take action on such issues.
Its a product freely available in the market place and that's how it should be discussed here.
Bill
Edited by bhobba
Yes - no sound.   The distributer bought them to Mike and he connected them up - nothing - zilch.  He is using some interim cables right now.   Even with those it is still the best I have heard.
Bill
Edited by bhobba
11 minutes ago, bhobba said:
I have no idea how they are made - Keith as some white papers on his site - but that's all I know.
Bill
Surely it’s just a matter of getting them certified. Job done, everyone happy
Now if anyone is worried they are illegal, posting here to warn people is OK.   The maker and some people I know to be professionally qualified, including engineers and electricians, claim otherwise.  What do you do in that case?   The maker believes he is legal, professionals I know say its legal, but some people here do not.  That really is as far as it can go on a forum like this.   Those people that believe its illegal should go to the authorities such as consumer protection, not jump up and down about it on this forum.  If it is illegal than the damage done to Keith's reputation will be great - he may even go bankrupt.   This is a thing that should not be discussed here - its a legal matter - and should be handled that way.
Bill
Bill, so you're suggesting that people cannot discuss the technical merits, design aspects, legalities etc of any product?
It makes no difference whether we are discussing the design elements of a product from a huge multi-national company or a smaller boutique supplier - by putting a product out onto the market, you are open to assessment and comment. It is incumbent upon the designer/manufacturer to cover all bases from a design and legality perspective. People should have the option of considering all available info on any product prior to purchase.
Re: the white papers... Sorry, but I take those with a grain of salt. Once bitten, twice shy, given the justification he used for the 'PureSilver TM' conductors in his KLE connectors which were revealed to be silver plated copper...
Edited by pete_mac
42 minutes ago, acg said:
It would have to be capacitance, although as far as I understand the foils in Mikes new cables are not laid upon each other so capacitance should be ok. The more accurate phrase would be "the Grandinote amp has trouble with Mikes cables" rather than vice versa.
I have had other amps with problems with Mike's cables.   Mike actually rang the amp maker who said no, no - do not connect such cables to this amp.   It is a FET design with a bandwidth well into the Mhz.   Greater than usual capacitance (Mikes cables are ribbon design so naturally have higher than normal capacitance) it will occilate - and that is what it did.  Why do they design amps like that - it gives a higher slew rate.  What is going on here - that requires futrher investigation - but I would say probably capacitance.
I must say only that I ever owned had this problem - so its rare.   I think the guy has gone out of business, but will remain nameless.
Bill
That's the issue - people here claim they are not certified.  Keith, Rawl99 who is a professional engineer with a day job of installing Hi End gear (yes strange job for a qualified engineer - but he is bitten by the audio bug) says they are, and an electrician that works with Rawl says they are.   I have no doubt Rawl would have used them in some of his installations.  It's hard to believe all of them made a mistake.
I must mention my father was also a qualified electrician - he was an electrical estimator and dealt with this sort of stuff all the time, but didn't actually do it for years.   Now this is many years old - he is long retired and dead, but if licenced professionals like electricians allowed by law to do this sort of thing (technically until a few years ago it was illegal to change a light-bulb - but people did it anyway - strange bit of trivia) they can be in a bit of deep do do.  My father was getting on in years and decided to install circuit breakers in our house instead of fuses.   Being a qualified electrician he could do that but hadn't done such things in years.   It had to be inspected afterwards.   The inspector was in fact a friend of our family and told mum - dad did a bit of an iffy job - he will pass it - but please ask him not to do things like this in the future - he could put his licence in jeopardy.
Bill
Edited by bhobba
Bill
I think that’s a common issue with very high bandwidth amps. I’ve seen similar comments regarding Karan and Spectral amps, but in those cases the manufacturers state quite clearly that certain cables are not suitable.
I am suggesting where legal matters are involved this is not the appropriate forum.   Do what you like - it's the mods that make such decisions.
But once it gets into where the law is involved it is wise we stay clear of it - it's not what this forum is about.   It has been mentioned in may be illegal.   That's fine - but any more than that may expose this forum to legal problems.   If you are concerned about the cable not being compliant with the law there are legal avenues for you to pursue.  I have stated I have been assured by people who should know they are - that's enough for me.
Added Later
Of course any other issue such as the wire he uses etc is fair game.   Comment about it until the cows come home.  But legal issues are iffy.
Bill
Edited by bhobba
I have met both Bill and Keith at get togethers on a few occasions
Both are passionate about sound and both have a very good ear
Have tried a few interconnect cables from KLE and Geoff @gmdb
Both performed well and use a mixture of both brands in my system for different amps
As for Power cables I had some professionally made to suit my system
@acg put me onto some industrial cable makers locally and went in that direction
Edited by Full Range
It is.   The amp I had issues with was actually a nice sounding amp - but it had that problem freely admitted to by the designer.   It may have even been in the instructions - but who reads those?  You should of course - but many skip it.  As far as the Grandinote goes it was put into Mikes system by the distributor who should have been aware of it - so it may be something else - or just a time poor distributor who also didnt read the user manual.
Bill
22 minutes ago, Full Range said:
I have met both Bill and Keith at get together son a few occasions
Thanks mate - but let me assure you Mike Lenehan, Keith Eichmann and Ralw99 have ears that make mine like lead.  I have seen all of them perform feats that make my mind boggle.   For example Mike will say a speaker is 2 db down here - measure it and guess what - its 2 db down where he said.   I have seen Rawl at a blind DAC listening session pick what each DAC was and in correct order.   Only 2 people got it right - I was way off.   Mike mentioned a prototype speaker he was working on had an issue - a prize (a chocolate I seem to recall) to anyone that can pick it.   There were a number of audiophiles there - I couldn't pick it - Keith said straight away - the mid-range is off.   He got the chocolate.  It is very humbling.
Bill
Edited by bhobba
Bill
I am one of those people that can pick an issue or a change in tone where others can’t
Think that may come from my past, where I was a free roadie for a friends band
I mixed the sound and I tuned the instruments
They always said that the output sound was 100% better when I did it
You and I conversed about Steve’s horn speakers at length even to the point of the importance of the listening position
Keith has visited and listened to my system and we both concurred on every point
Geoff has also visited and listened to my system and he also has a great ear
Think I made a post on my system thread about the visits
Ohh and my power cables brand are
Bambach cables - similar to this model
http://www.bambachcables.com.au/products/Vari-Flex-copy
That Bambach wire is actually drawn in Bris Vegas...how's that for keeping it local!
Exactly correct Pete.
Anything that is published or cited by KLEI is suspect iMO and the white paper has no intellectual rigour at all.
I might be reading this thread wrong and the original post but I have picked up major criticism in the posts of Mike Lenehan.  e.g. he couldn't develop a power cable. His speaker cables wouldn't work with Grandinote.  The Curious USB cable which Mike has promoted probably isn't as good as the KLEI etc.  And then suggesting all the issues with the Grandinote were somehow Mike Lenehan's fault, and not the makers for not offering full disclosure about how their amp works.
Mike Lenehan from what I have seen offers full disclosure about his products as I do myself.  Neither KLEI or Grandinote do this.  Their websites are wrapped up in a pseudo-scientific gobbly-**** language that doesn't explain what they actually do.
SNA has been very big on educating members about power cables and the Australian requirements that apply.  I have learnt a lot from member posts and the stickies that have been presented.  So much so that I have no interest in selling power cables.
Truth in advertising is something that should apply to the audio world like any other market.
100% correct Geoff and I really don't know why audio seems to be ( apparently ) different to any other market.
    • By Deja-Vu
      Item: Curious USB 0.8m cable
      Price: Sold pending payment
      Item Condition: used good condition
      Reason for selling: Surplus
      Payment Method:  Bank transfer COD Paypal
      Specs:
      https://curiouscables.com/shop?olsPage=products
      Lots of reviews online
    • By Matyk
      Item: qed digital coax
      Price: 55$
      Item Condition: great
      Reason for selling: nlr
      usb cable included. From addicted to audio. Paid 50$ 1 meter
      qed digital coax. 1 meter, paid 125$
      Both cables purchased 1st quarter of this year.
      i no longer want to run usb or coax audio. I run aes only now.
    • By sum1
      Item: iFI Micro iUSBPower
      Price: $120 (Includes shipping in AUS)
      Item Condition: Good
      Reason for selling: No Longer Required
      Payment Method: Bank Transfer or Paypal (as a gift or personal payment otherwise add 3% surcharge)
      Extra Info: Comes with original box and accessory
      Pictures: Attached
      Up for sale is an iFI Micro iUSBPower, that i purchased overseas a few years back.
      This is the USB2.0 version instead of the newer USB3
      Note that the iFI low noise power supply is a UK Plug since there is no Australian low noise power supply at the time of purchase. You will need to use your own adapter for it.
      The USB socket grip is on looser side which is a common complaint of the early batch but still functions normally.
      Rubber feet at the bottom has also gone yellow which is a typical occurrence.
      Features:
      IsoPower separates USB Audio and USB Power outputs, an innovative system to eliminate signal contamination
      Includes Ultra Low-Noise power supply
      IsoEarth ground noise elimination system, 10x less ground noise
      Super Regulator purified power supply, cleanest power ever
    • By **ZEP**
      Item: Chord Electronics QBD 76 USB Bluetooth DAC
      Price: $4,250 ovno
      Items Condition: Great condition, no scratches or marks, fully functioning and sounding sublime. This is a non smoking, pet free house
      Reason for Sale: Upgrade....its a passion for me!! Im looking for a DAVE if there is a part exchange anywhere??!!
      Payment Information: Cash on Pick up, Paypal, Direct Transfer
      Extra information: I’ve had this remarkable DAC for a few years now and it’s never disappointed me. It replaced a Wavelength USB DAC, which was also very capable, but the clarity and the extended detail that was achieved with this Chord DAC was astounding. Although it’s always about the sound, you should also remember that this is a piece of artwork. It’s beautifully crafted, shimmers Blue hues from the corner of the room and at a couple of KGs it has presence.....this is not just another generic black box!! There’s masses of connectivity, optical, USB, co-axial, and Bluetooth. I stream to it, run a transport into it and USB my Digital Media.The manual is http:// https://www.manualslib.com/manual/899220/Chord-Qbd-76.html
      Question welcome, and I’m happy to audition it to any serious party!
    • By Neo
      Item: Audioquest Coffee USB A/B 1.5m
      Price: $300 plus postage if required ( Ambertech rrp $535)
      Item Condition: 9/10 ( although the DBS pack is sticky, soft rubbery coating )
      Reason for selling: surplus
      Payment Method: Pickup - Cash, Paypal as a friend
      Extra Info:great usb cable which  I highly recommend
      Pictures: to come
