OZee
Movie Subwoofer
Hi All
I have CM9 setup and had a PV1D subwoofer.
Sub was awesome but i have shifted to 95% movies and need more chest thumping bass in small room.
3.5 meters x 5.3 Meters x 2.4 Meters (about 1600 cubic meters)
I am very confused on my next sub experience.
The biggest problem is I cant do a hearing test as there is no one place to test side by side where i live.
So Here is the question which configuration should i go with
B&W DB4s (approx $2500)
SVS PB 4000 (approx $2900)
SVS PB 2000 (approx $1450) and later have another PB 2000 when I upgrade the house.
only reason i am rejecting DB4s is that while it will be very clean sound but at same time I suspect it will not be chest thumping.
and reason i am rejecting 4000 is sheer size
and reason i am rejecting 2000  is the looks (only one hole instead of three)
lol
your views, please.
Guest yamaha_man
I have a JL Audio F113 sub that would move some air if you are interested.
Suggest using the new sub AND the existing sub to get the chest thumping experience. Dual subs is the way to go and set up correctly, can remove some of the bass dips in the room.
If size is a problem, then a SVS SB2000 is my suggestion.
The pb2000 will more than ample for the room and 2 would only be needed if you have uneven bass around the room as I did. I bought a pb2000 to run along with the Subsonic sub I already owned, which is now hidden behind my couch. The SVS is in the front corner of my room and bass is now much more even across all seating positions.
Chest thumping bass is more 60hz mid bass than really low stuff. The really low stuff SVS can create is where you feel the pressure in the room but don't hear it as much.
Edited by blybo
so you have already rejected your own sub options? then go pick up a run out svs pb13 ultra
try 1600 cubic feet
