The Audio Experts
SOLD: FS: PrimaLuna - Prologue Premium - CD Player $2000
Sponsor
Item: PrimaLuna - Prologue Premium - CD Player $2000
Price:  $2000. (RRP $3999)
Item Condition: Like New, played a handful of discs comes with 3 months warranty and all packaging and accessories. Still has plastic protective film over metal chassis
Reason for selling: Display Model.
Payment Method: Eftpos, Cash, PayPal (+3%) or Direct Deposit
The ProLogue Premium CD Player comes equipped with: True Dual Mono design using two 12AU7 dual-triode tubes and one 5AR4 rectifier tube per channel. While it is fine to use a single tube as a buffer and claim your CD player is "tube", it can't be compared to the PrimaLuna design and what it does for the music. Vacuum tube rectified power supply adapted from the award-winning ProLogue Three preamp that incorporates eleven separate power supply regulation circuits. Tube rectification is synonymous with organic sound, especially with CD players being know as sounding like "a computer." State-of-the-art Burr Brown SRC4192 24 bit/192kHz upsampling circuit and Burr Brown PCM1792 DACs. Two SuperTube Clocks™. An ultra-low jitter clocking device that replaces the solid-state oscillator with a vacuum tube. Yields incredible detail retrieval and dynamics throughout the entire audio spectrum. Why use two? The addition of the second clock further reduces jitter, resulting in greater detail and resolution. Highest quality USB digital input allows using your computer for storage and playback of your music with all the benefits of features like playlists and easier access to your whole music library. Rather than just add in a USB input as an afterthought, PrimaLuna engineers searched endlessly looking for the best-sounding USB interface we could find. We found the hiFace, made by M2Tech in Italy. This USB input converts the jitter-filled USB digital signal to S/PDIF, dramatically improving the digital signal quality before it even gets to the SuperTube Clocks. This USB input is a true high-resolution digital input, so you can play back your high resolution digital files, up to 24-bit/192kHz. Premium parts including polypropylene coupling caps, triple pi power supply filters, custom designed isolation transformers which separate the analogue and digital devices, Resulting in decreased signal degradation and improved sonics from top to bottom. Many CD players weigh in at five kilos or less. The ProLogue Premium tips the scales at 15 kilos! Beautiful heavy-gauge anodised brushed aluminium remote control. Controls all important CD operations and will even control functions on the DiaLogue components. Comes with rubber rings on both ends to protect furniture. New power transformers. Heavy-duty, dual-mono, power transformers increase control and detail. PTP-circuit. If the power transformer should overheat, this innovative "Power Transformer Protection" circuit cuts primary power, allows the preamp to cool down, then resets itself. Chassis made of finely finished heavy gauge steel, and five step automotive quality finish. Each coat hand rubbed and polished. Removable tube cage included no charge. Conservative design runs tubes easy for long life.
Specifications:
Freq. Response: 20Hz-20kHz +/- 0.5dBOutput Voltage: 2V +/- 0.5dB Distortion & Noise: Below -96dBChannel Separation: 90dBDynamic Range: Greater than 120dBPower Consumption: 50 wattsTube complement: 4 - 12AU7, 2 - 5AR4Dimensions: 14.5" x 8" x 15.5" (WxHxD)Weight: 33 lbsAnalog Outputs: 1 pair RCADigital Outputs: 1 coaxial / 1 opticalDigital Input: 1 USB
86302906_plcd2.jpeg.847d349c9c50e16963936b480d31a028.jpeg1312544234_plcd3.jpeg.b8b9d27316414b9d150f285c6b55ff24.jpeg41237730_plcd4.jpeg.01706d677c8a78f6ec3d6906d6bf0cdf.jpeg2001970141_plcd1.jpeg.20a547a321563704110e7ed28357c144.jpeg
    • By koputai
      Item: Marantz CD54, and Marantz CD44 CD Players
      Price: $150  $100 for the pair
      Item Condition: Old and tatty
      Reason for selling: NLR
      Extra Info: Here are two old Marantz CD players. They both have the famed CDM-1 swing arm transport, and TDA1540 DAC pair.
      Both are in working condition, but the CD44 needs a new loading belt as the tray doesn't currently open.
      These are quite heavy and I don't have suitable boxes, so pickup only please.
      Thanks for looking.
      Jason.
    • By LWA Staff
      Item: Musical Fidelity X-Ray V3 CD Player
      Location: Len Wallis Audio HQ, 64 Burns Bay Road, Lane Cove NSW
      Price: $800 EOFY Special $640
      Item Condition: Very good second hand condition
      Payment Method: Cash, Paypal, Credit Cards, Bank Transfer
      Delivery: We can deliver to anywhere in Australia. POA.
      Extra Info: Get clean and detailed sound sound with this excellent CD player with up-sampling to 96Khz. Very hard to fault at this price.
      Specifications:
      DAC architecture - 24 bit Delta-Sigma (Bitstream), Dual differential w/8x oversampling
      Disc mechanism - Philips
      Upsampling - 96kHz
      Frequency response - 10Hz to 20kHz +0 / - 0.2dB
      Signal /noise ratio - > 115dB “A” weighted
      Total harmonic distortion - < 0.006% 10Hz to 20kHz
      Total correlated jitter  - < 170 pS
      Channel separation - > 100dB 20Hz to 20kHz
      Linearity - < 0.2dB down to -90dB Audio output at digital 0dB level 2.14VRMS at 1kHz nominal
      Analog output - 1 pair RCA connectors
      Analog output impedance - 50 Ohms
      Digital outputs - 1 optical (Toslink), 1 S/PDIF (RCA connector)
      Power requirements - 100/115/230V AC 50/60Hz (factory preset)15 Watts
      Dimensions (approximate) 216mm wide x 100mm, high including feet x 345mm, deep including rear terminals and on/off button
      Weight - 5kg
    • By Plattenspieler
      Item: Balanced Audio Technology (BAT) VK-D5SE CD Player
      Price:  SOLD (please contact me by PM if you are interested in this player)
      Item Condition: 9.5/10
      Reason for selling: computer audio / vinyl
      Payment Method: Cash on pickup, bank transfer, paypal (+3%)
      I am selling my BAT VK-D5SE CD player. The player uses four Burr Brown PCM1704K 24bit dac chips, arguably one of the best dac chips ever produced. The player has a tubed output stage with four 6H30 tubes. The tubes in the player are the original ones supplied by BAT. I never opened the player. This is the latest version of this player. This is the first time the latest version is offered for sale on SNA. Earlier versions employed 20bit dac chips and/or different Philips drives. The review below has all the details about the different versions.
      This is very likely the last VK-D5SE player that ever sold new worldwide. I bought it brand new and sealed less than 5yrs ago from AV Gallery, an authorized BAT dealer. The player is in unmarked condition and comes with the original box and all original accessories. The massive remote control has some tiny marks. Also, a battery once seems to have leaked inside the remote control's battery compartment. This has no impact on functionality at all. The BAT remote control also worked with Musical Fidelity and Marantz equipment.
      This is what lampizator.eu has to say about the BAT VK-D5SE: "This is one of the best CD players ever made. Well built, all design is optimized for perfect analog-like sound. Digital output quality can rival the best transports. It goes without saying that it has balanced XLR and RCA outputs. True balanced topology from one of the best designers in the industry." The designer is Victor Khomenko.
      I agree. I have not heard a better CD player. I compared it to high-end Esoteric and Marantz players when I bought it and preferred the BAT because of its analog-like sound. It is built like a tank.
      The original box is extremely sturdy. I am happy to ship the CD player in its original box at buyer's risk and expense. The dimensions of the box are 25cm x 62.5cm x 53cm. The gross weight is about 17kg. Alternatively, the player can be collected from Williamstown or Carlton.
      The manual is available online: http://balanced.com/sites/default/files/ManD5SE.pdf.
      An online review of the player: http://www.stereotimes.com/cdp032204.shtml.
    • By MattyW
      Item: Marantz CD63SE & Remote
      Price: $180
      Item Condition: Near new
      Extra Info: Nice sounding CD player utilizing the Philips TDA1543 DAC chip. Very pleasant and easy to listen to
    • By Audionerd
      Item: ACCUSTIC ARTS PLAYER ES mk2 CD PLAYER/DAC
      Price: $2450
      Item Condition: Virtually Perfect
      Reason for selling: Too much gear
      Payment Method: Cash, Paypal, Bank Transfer
      Extra Info: Sweet analogue sounding CD player with premium onboard upsampling DAC, accessible via coaxial and USB (24bit/192KHz asynchronous) digital inputs.
                        Seldom available from this high end German manufacturer. Complete with remote, manuals, driver CD and original packaging.
                        Stylish brushed aluminium and chrome chassis in immaculate condition.
                        A bargain at less than half original price of $5990.
