Cybrarian
SOLD: FS: Trafomatic Audio Head One Headphone amp
Item: Trafomatic Audio Head One Headphone amplifier [High Gloss white finish]
Price: $800 + shipping [RRP $1400]
Item Condition: Excellent
Reason for selling: NLR
Payment Method: Pickup - Cash, or Paypal or bank transfer
Extra Info: A headamp which is different because you can
matching the different impedances of headphones. The Head One runs a pair of 6S45P triodes with 1.8dB of negative feedback on the outputs while one EZ80(81) becomes the indirectly heated rectifier. Two inputs switched via rear-mounted toggle and twinned pre-outs for biamping or subwoofing* turn this piece into a bona fide small preamp as well. The Head One is less than a year old & includes a spare new JJ Electronic EZ81 rectifier valve.
Specifications:
Experience Head One – Headphone Amplifier
Reviews: 6moons
Edited by Cybrarian
    • By thejt
      Item: Shanling MC-30 Music Centre (Valves)
      Price: $625 or $650 with Logitech Harmony 650 universal remote
      Reason for selling: Too much gear
      Payment Method: Pickup - Cash, Shipped - Direct Deposit
      I am the second owner of this locally delivered 240V unit and I am sure I will regret selling this later. Ask anyone who has ever come across one of these and they will back me up with how they were blown away by this little unit. The build quality is excellent, thick aluminium body and heavy transformers. The design is well thought out with the feet all featuring levelling. The sound it makes is lush and although it seems like it would not create a generous amount of sound at 3W (Class A) I can fill a lounge room with gorgeous sound without even going half way on the dial. This is without even using easy to drive speakers, I had used Quad 11L and Dynaudio Contour 1.32E which are both only about 86dB. It has a pre-out should you want more power, but I tried using a Quad 909 and preferred it direct. The unit actually provided more bass on its own. Feature wise, CD player, FM and AM radio, 3.5mm input and RCA input which should cover everything you could want.
      The original owner lost the remote but the unit can be operated from the controls on the device itself. Volume adjustment is a bit of a chore like that though so I picked up a Logitech universal unit which I can include for an extra $25 (cost $70). A common issue with many Shanling CD players is the occasion pause during cd playback but this is occurs only very occasionally and lasts about 1 - 2 seconds before resuming. The MC-30 has been otherwise faultless. I have the original double box so can ship at buyers risk if desired but note it is fairly heavy. Great chance to get into valves or Class A amplification without too much outlay. Questions welcome and I will try to answer best I can. Donation on sale to SNA. Please look at all the glowey bits in the pictures!
      Praise:
      https://www.stereophile.com/integratedamps/308shan/index.html
      http://www.charismaaudio.com/products/shanling/mc30.htm
    • By Highpower
      Item: Denon PMA-880R Class A Integrated Amplifier
      Price: $300
      Reason for selling: Accumulated too much hifi gear and about to move to a new house
      Extra Info: This Denon PMA-880R Optical Class A Integrated Amplifier complete with RC-156 remote control and Operating Instructions is in mint condition. This amplifier was made in Japan in 1993.  Amps made by Denon in this era were considered to be the best amps that Denon ever made. These amps hardly ever come up for sale.
      I have owned this amplifier from new and it has been very well looked after. The amplifier and remote control still look brand new and are unmarked. It's whole life has been in a cabinet behind a glass door, which is why it still looks brand new.
      This Class A integrated amplifier has a very clean, detailed and powerful output that is impressive for both analogue and digital sources. There are no crackles or hums present and it performs just as well as the day I purchased it.
      The PMA-880R has a solid power supply that uses a shielded toroidal transformer, and a pair of large 12,000uF capacitors for voltage smoothing and a very substantial heat sink. It features a source direct switch for tone controls bypass and optical connection between amplifier stages for detailed sound. Speakers can be connected via A, B, A B front switching. The speaker binding posts accommodate bare wires or banana plugs. The power rating is 2 x 75W RMS at 8 ohms or 2 x 120W at 4 ohms. The Denon PMA-880R uses an Optical class A circuit design for optimum sound quality. Source Direct can be used to bypass tone controls. The Denon PMA-880R accommodates both MM moving magnet and MC moving coil Phono options via front switching.
      The Denon PMA-880R has the following RCA inputs: Phono, CD, Tuner, Aux, DAT/Tape-1, DAT/Tape-2. The amp also has a Record Out Selector a headphone jack, and a loudness button.
      The specifications are as follows:
      Power output: 75 watts per channel into 8Ω (stereo)
      Frequency response: 20Hz to 20kHz
      Total harmonic distortion: 0.02%
      Input sensitivity: 0.2mV (MC), 2.5mV (MM), 150mV (line)
      Signal to noise ratio: 76dB (MC), 94dB (MM), 110dB (line)
      Output: 150mV (line)
      Dimensions: 434 x 160 x 353mm
      Weight: 8.2kg
      Accessories: RC-156 remote control
    • By BlueOceanBoy
      Item: Mytek Brooklyn DAC+
      Location: Brisbane - Free express insured post AUS wide
      Price: $2699 offers considered
      Item Condition: Presents as new - 27/8/19
      Reason for selling: NLR - upgraded (I hope!) to Auralic/Luxman combo
      For Sale
      Mytek Brooklyn DAC+
      $2699 ono
      “As new” Condition
      Bought AUS store 27/8/19
      Designed in New York
      The only reasonably priced high end DAC with MQA hardware decoder needed to hear full original resolution of Tidal Masters
      Brooklyn DAC+ is primarily reference USB2 DAC, but also line and phono analog preamplifier and a reference headphone amplifier. It integrates digital and vinyl hi-res playback for reference listening on headphones and speakers. All integrated functions are of the premium grade. Both phono preamplifier as well as a headphone amplifier are of the highest quality, they challenge dedicated units costing thousands of $$.
      Brooklyn DAC+ was launched at RMAF 2017 in October 2017 and is now shipping. It replaces Brooklyn DAC which has now been discontinued.
      Brooklyn DAC+ features the following improvements as compared to Brooklyn DAC:
      - Sabre 9028 Pro chipset ( 9018 in older model)
      - Higher grade, more transparent and less noisy analog attenuator circuit.
      - Improved analog input performance
      - Improved Phono Stage transparency
      - Improved Headphone Amp sound (more detail, more definition)
      - Dual mono analog path
      SPECIFICATIONS :
      CONVERSION: up to 384k, 32bit PCM, native DSD
      up to DSD256, DXD, 130dB Dynamic Range
      MQA HI-RES DECODER: built in certified hardware
      MQA™ decoder
      DIGITAL INPUTS: USB2 Class2 (OSX, Linux driverless,
      all formats), AES/EBU (PCM up to 192k, up to DSD64 DOP), 2x S/PDIF (PCM up to 192k, up to DSD64 DOP), Toslink/ADAT 2x S/PDIF (PCM up to 192k, up to DSD64 DOP), SDIF3 DSD up to DSD256
      CLOCK: “Mytek Femtoclock Generator™” 0.82ps internal jitter, Wordclock Input and Output (allows stacking multiple units for multichannel operation,
      includes mch DSD)
      ANALOG OUTPUTS: RCA, balanced XLR, simultaneous,
      50 Ohm impedance
      HEADPHONE OUTPUTS: Reference High Current,
      High transient Headphone Amp, 500mA, 6 Watts,
      dual headphone jacks, designed to drive hard to
      drive headphones.
      BUILT-IN ATTENUATOR: Choice of 1dB step analog attenuator, separate for main out and head- phones,
      1dB step digital 32 bit attenuator and purist relay bypass.
      BUILT-IN ANALOG PREAMP: Line level input or
      Phono M/M, M/C input, relay controlled.
      AUDIO INTERFACE FUNCTION: All digital inputs can
      be routed into computer via USB2. Allows connection
      of external digital sources such as CD Players and
      digitizing ADCs.
      REMOTE: Included, universal remote capable
      FIRMWARE: Upgradable via USB Control panel
      WORLDWIDE POWER SUPPLY
      OPTIONAL DC/BATTERY POWER INPUT: 12VDC
      DIMENSIONS: WxDxH=8.5x8.5x1.74”=216x216x44mm
      WEIGHT: 4lbs, 2kg
      WARRANTY: 2 years
    • By Cafad
      Just thought I'd put up a post to draw attention to Burson's new offering.
      https://www.bursonaudio.com/products/conductor-3/
      Looks very nice, although I will admit to being a little confused about the power supply description.
    • By Phuong
      Item: Auralic Taurus Pre (Balanced Class A Preamplifier and Headphone Amplifier)
      Price: Sold
      Item Condition: mint
      Reason for selling: need money
      Very well reviewed Auralic Taurus Pre, fully balanced class A preamp and headphone amp , heaps of good review online, comes with all original accessories.
