The Audio Experts Posted July 3, 2018 Share Posted July 3, 2018 (edited) SOLD Item: XSP-1 GEN2 (RRP $2,199)& XPA-DR2 (RRP $2999) $3980 for both units Location: Clayton VIC, freight available. Price: $3980 for both units. Item Condition: Like Brand New, less than 20hrs comes with full manufacturer’s warranty and all packaging and accessories. Current Model Reason for selling: Cancelled customer order. Payment Method: Eftpos, Cash, PayPal (+3%) or Direct Deposit Extra Info: XSP-1 GEN 2 Superb Analog Audio Quality o Exceptional sound quality via an all-analogue, fully balanced, differential signal path with vanishingly low noise and distortion. o Audiophile quality, load invariant, high current headphone amplifier with independent level control and memory. o High performance phono preamp that supports both moving magnet and moving coil cartridges, with user-configurable cartridge loading for moving coil cartridges. Precise Control o Full analogue bass management with independent, individually configurable, Linkwitz-Riley 12 dB/octave high-pass and low-pass filters for the mains and subs. o Level control via a high resolution (.5dB/step) digitally controlled analogue resistor network. o Digital flexibility and convenience including precise repeatability on all settings, a smart mute function, turn on level limit, and a full function remote control. o Informative, dimmable front panel VFD display shows level, status, and input selections. Flexible Input and Output Options o Excellent input and output flexibility: 2 sets of balanced inputs, 4 sets of unbalanced inputs, one set of balanced main outputs, and one set of unbalanced main outputs. o Support for both stereo subwoofers and a summed mono subwoofer. o True external processor loop. o Gold plated, solid brass machined RCA connectors and gold plated XLR connectors. o Flexible trigger and control options. Top Quality Parts and Construction o Tight-tolerance surface mount components and short, precisely matched signal paths deliver a superb, tightly focused acoustic signature. o Top quality parts and construction for years of reliable service, including hand-selected semiconductors and top quality passive components. o Highly regulated and shielded toroidal power supply. o Fully transferable five-year warranty. Universal Voltage Operation o The XSP-1 can operate on 115 VAC or 230 VAC and will automatically detect and select the correct line voltage for your area. XPA_DR2 Differential Reference™ Performance and Sound Quality o High-powered, fully-differential, low distortion amplifier design delivers massive dynamics with smooth precision, offering superbly detailed sound and incredibly natural imaging. Sound Quality First o Designed first and foremost to sound superb in all types of audio systems with all types of music. o Low noise, low distortion, wideband amplifier design with traditional Class A/B output stage ensures smooth, detailed sound, without a trace of strain or harshness. o Totally stable with real world speakers in real systems; not just on a test bench. Modern Efficient Circuit Design o Optimized Soft-Switch Class H™ power supply topology delivers improved efficiency without compromising audio performance. o Switched Mode Power Supply (SMPS) offers all of the performance of a traditional linear power supply, with improved efficiency and reliability, and reduced overall weight. Quality Construction o Top quality parts and construction throughout for years of reliable trouble-free service. o Heavy steel 4RU chassis with milled aluminium faceplate offers strength and rugged good looks. o Solid machined gold-plated RCA input connectors provide a reliable connection with a wide variety of audio interconnects. o Fully modular construction allows you to purchase as many channels as you need today, and then add more channels later when and if you need them. o Designed, assembled, and tested in the U.S.A. at our plant here in Franklin, Tennessee Flexible Signal Connections and Power Options o Gold plated five-way speaker binding posts with clear shields allow you to use a wide range of speaker cables with bare wires, lugs, or banana plugs. o Choice of balanced or unbalanced input for each channel, independently controlled by reliable metal toggle switches. o Remote trigger input and output allow the XPA-DR2 to control and be controlled by other trigger-enabled equipment. o World compliant AC line voltage operation enables the XPA-DR2 to operate on any line voltage between 100 VAC and 250 VAC 50/60Hz. o Standard IEC power inlet fits all standard IEC power cables and most custom audiophile power cables. Protection o Audiophile-grade fault protection is entirely transparent under normal listening conditions, yet protects the amp and your other equipment from virtually all common faults. o The XPA-DR2 is protected from AC line faults by a rugged resettable rear panel push-button circuit breaker. o Full five-year warranty ensures that you’ll be able to enjoy your XPA-DR2 amplifier for years to come. Pictures: Edited July 10, 2018 by The Audio Experts 1 Link to comment Share on other sites More sharing options...
