jacyk
FS: Acoustic Treatment Panels
Item: Acoustic Treatment Panels
Price: 350ono
Item Condition: Excellent
Reason for selling: Clearing space
Payment Method: Pickup - Cash
8 Acoustic Treatment Panels (6 X large, 2 X small
Dimensions are 1200x1200 and 1200x800
Made from safe fibreglass 32kg³ density and covered in Trilogy One Acoustic material both sides, wooden reinforced frame with small air gap on back (wall side)
MSG ANYTIME! Price negotiable
Edited by jacyk
Accidentally posted an incomplete post, updated now
What frequency do these target?
All of them... Mainly to stop reflections.
    • By caleb
      Item: Mad Scientist Audio BlackPod Mini Tungsten Carbide Audio Footers 3pcs set
      Price: $100 plus $10 post
      Item Condition:7/10(has some scratches and wears on one of the tc ball but works fine)
      Reason for selling:no longer required
      Mad blackpod mini tungsten Carbide for sale in great working condition.I found it great  under sources.
      Exactly the same quality built compared to the standard tc version but in smaller fraction.
      Here's more info and reviews
      http://www.madscientist-audio.com/blackpodmini.html
      http://www.hifi-advice.com/blog/review/accessories-reviews/mad-scientist-audio-blackpods/
    • By SoundGuy
      Price: $12,000 $10,500 $9700
      Main Features
      Gain 26.8dB
      Power Consumption 300W
      Width 17.75" (45.1cm)
      Depth 19.83" (50.4cm)
    • By mtan002
      Item: Music Appreciation Appreciation 8th Edition + Multimedia Companion V4.5
      Price: $40 + Actual postage
      Item Condition: Used
      Payment Method: Paypal or cash on pickup
      This book is in fair condition with cover and all pages intact.
      The Multimedia Companion is in good condition.
      You pay actual postage based on your location.
    • By Sarenda
      Item:Dali Speakers
      Price: $250
      Item Condition: Working and in OK condition.
      Reason for selling: Too many speakers!!
      Extra Info: I believe these Dali speakers along with magnificent sounding centre channel speaker  were selling for around $1500 plus in it's day.
      A bargain at $250
      Pick up only.
      Cheers.
    • By John Buchanan
      Item: Stax SRM-Monitor
      Price: $2000 ONO
      Item Condition: Excellent.
      Reason for selling: Thinning the herd
      Stax SRM-Monitor
      Overview
      The SRM-Monitor is a combination of Stax' solid-state amplifier, the SRM-1 Mk2 Professional and their diffuse field equalizer, the ED-1, in one larger package. The SRM-Monitor came to the market in 1988 and was still available in 1995, according to the Stax 35th Anniversary product brochure. The volume control of the SRM-1 Mk2 appeared to have been changed to a dB calibrated numbered type with indents, for repeatable and measurable volume variations in a professional situation, but internally the same blue ALPS RK-27 dual channel potentiometer had been used. Most of these units appear to have been sold to audiometry workplaces, as they are quite often referred to in research papers, and rarely mentioned or seen elsewhere.
       The two inputs mentioned below are switchable between either balanced or single ended (via two sliding switches on the back panel – one each for left and right channels), and the diffuse field equalizer can be switched on or off via a push switch on the front panel. These units seem to be extremely rare (I have seen as few of these for sale as the Stax SRM-T2 over the years).
Inputs on the back panel consisted of:
1. 1x Unbalanced line level RCA/cinch input.
      2. 1x Balanced line level XLR/Cannon input.
Outputs consisted of:
1. 1x Unbalanced RCA/cinch loop output (with the Diffuse field equalizer output switchable) – back panel
      2. 2x Professional bias headphone jacks (580V) Stax 5 pin connector – front panel.
      3. 1x Normal bias headphone jack (230V) Stax 6 pin connector – front panel.
      History
      Headphone frequency response measurements, conducted with a microphone in front of the headphone driver, much as speaker measurements were conducted, observed that headphones with a measured flat frequency response did not sound as flat as would be expected from a speaker with identical measurements. Comparing the sound of a flat measured speaker with a flat measured headphone revealed extreme tonal differences that started off a whole lot of investigation into why they sounded different and how a headphone’s frequency response could be altered to make it sound like flat measured speakers.
      An experiment was set up as follows:
      1. A loudspeaker playing a frequency sweep was recorded by a high quality, miniature microphone in one of two types of room – either an anechoic chamber or an approximation of an ordinary room (see later) – and the frequency response was charted.
      2. The same microphone was inserted into a subject’s ear canal and the same speaker replayed frequency sweep was charted again.
      3. It turned out there was quite a difference between the charted frequency response of the two recordings.
      4. It was postulated that if the frequency response of the recording made by the microphone in the ear (see 2) could be altered by pre-equalization to ultimately match the shape of the frequency response of the recording of the same microphone when not in the ear (see 1), then replay of that in-ear microphone recording would sound the same as that of replay of the recording made by the same microphone in a room.
      5. This gave rise to a target measured frequency response for a headphone to sound like a flat measured speaker i.e. if the headphone had a measured frequency response that looked like the target response, it should sound flat when reproducing a recording that had been mixed with speakers in front of the mixer, and sound as if one was listening to speakers in front of him/her, rather than via headphones.
      6. The concept of pre-equalization of headphones was thus born.
      Pre-equalization could either be mechanical (i.e. the driver frequency response was manufactured to behave that way e.g. the AKG 240DF – not so easy) or electrical (which should be cheaper, easier, field-adjustable and possibly adaptable to different headphones), and meant that although the headphones now had a frequency response that had been altered to something that looked decidedly non-flat when measured, it reproduced the sounds coming from a sound source with the same frequency response at the ear canal as if recording and replay over headphones had not been introduced into the chain i.e. the headphone replay should now sound the same as sitting in the room and listening to the speakers.
      Two main theories of the correct pre-equalization curve were forwarded. The first, called free-field equalization, suggested that the above experiment be conducted in an anechoic chamber (like a field, free of reflective, absorptive and refractory surfaces). So, to reiterate, a free field equalized headphone is designed to sound like the reproduction of speakers with a listener sitting in an anechoic chamber. Although an anechoic chamber is more reproducible as a standard, it was argued that nobody listens in an anechoic chamber (and indeed, most listeners find even speaking in an anechoic chamber uncomfortable) and a reasonable approximation of a standard listening area be used to conduct the above experiments. This was called diffuse field equalization.
      There are many things that alter sound between the release from the sound source and arrival at the ear canal. Reflections, diffraction and absorption from objects in the listening environment, reflection, diffraction and absorption by the head, hair and ears all contribute to alteration of sound before it reaches the ear canal. Diffuse field equalization, as mentioned before, is an attempt to make the replay of a recording on headphones sound like you are listening to the same recording through speakers in a non-anechoic room. Experiments were also done so that headphone users were asked to equalize various sharply limited frequency bands’ playback on headphones until they had matched the loudness of the same playback through speakers and with headphones removed. A good correlation was obtained between this method and the probe microphone recording method.
      The direction of sound (from the front in a reverberant field) with speakers is far removed from actually injecting the sound directly into the ear canal. Naotake Hayashi (of Stax), pondering this problem, possibly because Stax couldn’t successfully mechanically create a diffuse field equalized headphone, and any electrical equalizer would have to be a custom unit, first decided to create a new headphone that coupled its own reproducible miniature room (complete with uneven diffractive, reflective and absorptive surfaces) called the Stax SR-Sigma Panoramic Earspeaker System. It had headphone drivers that fired from anterior to posterior instead of laterally into the ear canals. The sound was bounced off irregular mineral wool into the ear canals, creating a mechanical diffuse field room for each ear as well as having "speakers" that fired sound from the front, rather than straight into the canals. It was partially successful, but listeners either hate it or absolutely love it. Personally I have always loved it, but they are quite inefficient headphones and also sounded quite rolled off at both ends of the frequency spectrum. They were also huge and very odd looking. Better drivers than the original Sigma drivers (which were later recycled into the Lambda non-professional earspeakers) improve the frequency extremes, allowing the merit of the theory to finally shine through (e.g. the very rare Sigma Pro or the Sigma/404 hybrid provide the sound that the Sigma gave a hint of).
      Stax later decided (around 1986 – 1987), instead, to bite the bullet and build 4 custom equalizers to electrically equalize their latest headphone range to provide individual target diffuse field responses for each of its various, then-current headphones (the ED-5 for the SR5 normal bias headphone, the ED-1 and SRM-Monitor for the Lambda Professional high bias phone and the ED-Signature for the high bias Lambda Signature). The headphones could then be less bulky than the Sigma and more fashionable (see my avatar for what the Sigma looked like – it definitely had a style only a mother could love). Again, reactions to Stax engineers’ diffuse field equalized headphones literally polarized listeners into “hate it” or “love it” camps. I would guess that economically, this proved to be a dead end, and no further research into diffuse field equalization has ever been mentioned by Stax. Consequently, the rather rare equalization units sell for a premium on the used market these days.
      As mentioned above, the four ED diffuse field equalizers were designed for three different Stax phones. The ED-5, ED-1 and ED-Signature were placed between the source and the headphone driver and are connected by way of RCA cables. The ED-1 matched the construction and size of the SRM1 Mk2 Professional and was finished, like those units, in either black or silver. The ED Signature matched the chocolate brown of SRM-T1/S/W. The SRM-Monitor incorporated an ED-1 and an SRM-1 Mk2 Professional into one large package and was finished in either black or silver, and had switchable RCA or XLR inputs. The ED-5 unit was made to match the then current SRD-6 transformer unit (an interface between a speaker-driving power amp and the Stax earspeakers) in silver.
      The ED-Signature would most likely also match the 404 and Lambda Nova Signature. The ED-1 equalization (in my case, provided by the SRM Monitor) sounds excellent with the Lambda Nova Signature and surprisingly good with the Omega 2 Mk 1, despite being the wrong equalization for the latter. The upper midrange/lower treble, in particular, sounds quite a bit flatter and the low end remains in good balance with the mid and high. As Bill Sommerweck said in his review of the ED-1 in the April 1989 issue of Stereophile, track 9 on Stax' own “Space Sound” CD changes from objectionable (without the equalizer switched in) to quite listenable with the equalization switched in. In my opinion, there is no magical out of the head experience, except when listening to the aforementioned CD, or the Ultrasone binaural tracks (i.e. binaural recordings). These are seriously spooky, but sound 3 dimensional with or without equalisation. Try them with someone who is not used to listening to headphones and see what happens when you cue up track 1 or 2 of the former, or the fireworks track of the latter. Sabine whispering in your ear - oh yes! Shower spraying on your shower cap - OMG!
      Now, here is where things start getting weird. I had a listen to the Sigma/404 and the SR-007 phones with the equalizer on and they both sound great - it may just be happenstance, but I've never heard "Kind Of Blue" sound so wonderful and with plenty of lower bass (which even the SRM-717 doesn't seem to match). This is strange, as the frequency response for the ED-1 is flat in the bass, and should not be suited to the Sigma/404 or SR-007 anyway (see graph below).
      Maybe it's a de-emphasized treble spike? I don't know, but whatever, this pre-equalization is not just scientific theory and sounds really good. To me, the sound has gone from lots of good hi-fi parts and moved to an organic whole. To my ears, the Stax SRM-Monitor is the single best piece of equipment I have ever purchased.
      General Description of the Sound
      The SRM-Monitor, without the equalizer engaged, is a very good pure class A FET DC amplifier with clear dynamic sound and excellent low level detail resolution (indeed, under these circumstances it is almost the same as the SRM-1 Mk 2 Professional, apart from the added balanced input and the click stop calibrated volume control. There are apparent improvements to the sound, smoothing the slightly spiky balance of the SRM 1 Mk2 Pro. Compared to new Stax amplifiers, such as SRM-717, the sound is slightly less refined and on the dry side, but still very impressive. Stax tube amplifiers such as SRM-T1, SRM-007t etc might offer a little bit more refinement and are more fluid in their presentation as well but are not as powerful.
      However, when the Diffuse Field Equalizer is switched in, this amplifier becomes magic. A reduction in any residual Lambda series tizziness in the upper midrange and a slight filling in of the Lambda midrange trough allows the Lambda to sound much flatter while retaining the power it is capable of.  Cymbal reproduction is particularly improved. The vocal reproduction is much better overall, coming closer to the nearly perfect Sigma series in that department. The bass quality is also flatter, which is odd, as the equalizer frequency response appears to leave the bass frequencies unchanged.
      The SRM-Monitor also sounds great with the SR-007 Mk1, especially with the Diffuse Field Equaliser switched in, despite the equalizer being specifically adjusted for the Stax Lambda Pro. There is no hiss or hum at any setting of the volume control.
      Pricing & Other Data of Interest
      I have only ever seen 2 for sale in over 10 years and the one I didn’t buy had clearly seen better days.
      Technical Specifications
Frequency characteristics: DC~20KHz ±1dB
      Input impedance: 50KΩ
      Amplification factor: 60dB
      Distortion factor: 0.02%/1KHz/100V with Lambda Pro
      Input level: 100mV
      Bias voltage: 230V (normal bias) 580V (professional bias)
      Electric power consumption: 47W
      Size: (W) 300 mm × (H) 87 mm × (D) 314 mm
      Production run: 1988 - 1995?
