Furutechfan Posted June 18, 2018 Share Posted June 18, 2018 Hi I am currently running music on my roon based sonic transporter then to micro rendu. Do you know of away i can play spotify through the sonic transporter to microrendu? Thanks Lyndon Link to comment Share on other sites More sharing options...
awayward Posted June 18, 2018 Share Posted June 18, 2018 From the Small Green Computer FAQs, I haven't tried it though. Q. Do any of the “available apps” in Software Manager allow the microRendu to access streaming services? A. Roon has the best integration with Tidal of any playback software. They also support free streaming radio. The squeezebox software supports streaming. It has 1000s of streaming radio stations as well as Spotify, Pandora, Tidal and others. If you are having problems getting these to work, please reach out to us as we are happy to assist. Link to comment Share on other sites More sharing options...
rand129678 Posted June 18, 2018 Share Posted June 18, 2018 (edited) 6 hours ago, lyndonlim said: Do you know of away i can play spotify through the sonic transporter to microrendu? Hi Lyndon Do you have version 2.5 (or higher) on your microRendu? You should be able to play direct from the Spotify app, direct to the Rendu, via Spotify Connect, but it needs v2.5 (or higher). Just need to install Spotify Connect: See here: https://www.computeraudiophile.com/forums/topic/31563-sonicorbiter-spotify-connect-output-mode-beta/ Edited June 18, 2018 by Music2496 Link to comment Share on other sites More sharing options...
Furutechfan Posted June 18, 2018 Author Share Posted June 18, 2018 Thanks so much guys. I'll try it tonight. Not sure what version my MR is. Link to comment Share on other sites More sharing options...
rand129678 Posted June 18, 2018 Share Posted June 18, 2018 (edited) 1 hour ago, lyndonlim said: Thanks so much guys. I'll try it tonight. Not sure what version my MR is. No worries. It tells you on the front page. See mine below (I'm on version 2.6): Btw, the method I linked above by-passes Roon and by-passes your sonicTransporter. Using Spotify Connect on the Rendu means you play direct from the Spotify app (Mac/PC/iOS/Android) direct to the Rendu. Hope that helps. Edited June 18, 2018 by Music2496 Link to comment Share on other sites More sharing options...
Furutechfan Posted June 19, 2018 Author Share Posted June 19, 2018 Cool. Good to know. Link to comment Share on other sites More sharing options...
rakan23 Posted December 20, 2018 Share Posted December 20, 2018 (edited) e all want the same things. So reckons the Hold Steady frontman Craig Finn. His songs document interpersonal relationships, not those that exist between man and his audio machinery. Do audiophiles all want the same things? Not by a long shot Xvideos Youporn Xhamster Edited December 23, 2018 by rakan23 Link to comment Share on other sites More sharing options...
