Saxon Hall
FS: Zefal Solibloc Vintage Bike Pump.
Item   As Above
Location   Epping Vic
Price   $20
Item Condition   Banged Up, Well Used but nice to have for a collector of Vintage Bike Gear
Reason For Selling   Dont own a bike
Payment Method   Cash on Pick Up, or Bank Transfer/PayPal if delivery is required
Extra Info.  This is an old bike pump. It works but is a bit stiff and sticky when pumping in and out ( is that rude?)
It has a few dents and scratches. ( Please have a good look at the photos)
It has the hose fitting which is in good condition.
It is made out of anodized aluminium alloy. I believe the design dates back to the 1970,s
If you want it delivered it will cost $8.50 for Standard AusPost Parcel Delivery
Photos
ITEM03a72d9775df1a367db431f1f5968ba6.jpg902ac7df5862ca2016a4cbb4964bf785.jpg133d074280f59e06beeb0871fb6867b4.jpga7b676f3126e12a73848afbe53315ac0.jpgb919baaae4e1bcccbff119ee475954d6.jpgb0ec3480cb6567afbc680c4f7a516fc9.jpg1678e25432da8ff4e853d13d5e3c6cc2.jpgc1f762fd0c5084b3994f73f7f5f89a8c.jpg
Edited by Saxon Hall
    • By coolhand
      Item: Moon Audio Blue Dragon Balanced TRRS Head Phone Cable, 1.5m - inc. unbalanced 3.5mm adaptor
      Price: $100 ($255 RRP.)
      Item Condition: Very Good
      Reason for selling: NLR
      Can ship to anyone, anywhere, at purchasers expense !
      Terminated at amp end only
      This cable has a 3.5mm TRRS plug at the amp end and is supplied with a 3.5mm Stereo adaptor so it can also be used with unbalanced sources.
      The headphone end is unterminated and is dressed so that it can be used to directly re-wire headphones, or could have plugs soldered to suit any requirement.
      The Blue Dragon Headphone Cable has been designed with Ultra Pure Single Crystal Copper conductors using the Ohno Continuous Casting Process.
      It is a good fit if you want to improve clarity and dynamics of your headphones and do not want to add coloration.
    • By coolhand
      Item: Kimber Kable USB Ag, Pure Silver Conductor cable - 1m.
      Price: $125 (RRP. $254)
      Typical superb Kimber Kable sound & build quality, with USB Type A -> Type B termination.
      "Mini BUS Ag cables utilize large gauge pure silver conductors in tandem with large gauge (6.1%) silver-plated copper drain and shield wires.
      A high performance high-density polyethylene (PE) dielectric is used on the signal conductors to maximize signal integrity.
      All Kimber Kable USB cables feature crimped and soldered shield to shell connection which helps reduce ground resistance variations."
    • By coolhand
      Item: Clearaudio MAGIX2 Magnetic Resonance Isolators (Levitation Footers) x8 - Two boxes of 4 devices.
      Price: $600 per set of 4 (RRP. $1300)
      Item Condition: Excellent
      Can ship anywhere, to anybody, at purchasers expense !
      The Clearaudio MAGIX2 Magnetischer Resonanzedämpfer are the result of many years research in most effective means of reducing any acoustic feedback to the minimum. An absolute unusual feature of this principle is that the MAGIX2 in operating state reaches an automatic self-shielding of the magnetic field.
      With these deployed I was able to entirely eliminate any disturbances & feedback from a turntable arranged on a platform which was situated upon a suspended timber floor, even with large speakers in close proximity and high replay volumes.
      They are equally beneficial with any type of audio components which can benefit from isolation and/or damping.
      Dimensions: 111 mm x 105 mm
      Each device weighs 2.2kg and is height adjustable.
      To reach optimal resonance absorption it is necessary to coordinate the number of MAGIX2 relative to the weight of the component to be damped (and additionally the weight of an underlaying platform - if for example an acrylic plate or wooden board is also to be deployed under the component)
      Weight bearing capacity: 16 pounds (8kg’s) each (take the weight of the component, and platform if used, which you intend to isolate, and divide by 8 to determine the number of Magix you will need).
      From a sonic perspective, the Magix differ from other devices by what they don’t do.
      Most any isolation device imparts some sort of character of its own. That may be increased detail, more speed, a slight softening, added brightness, etc., etc.
      The Magix strips all those artifacts away, and leaves behind a sense of purity and air.
      Background silence is increased, subtle details are allowed to unfold rather than being forced out, and the music ebbs and flows with a naturalness that is alluring.
      Review:
      https://hifi-unlimited.blogspot.com/2009/08/levitate-your-music-clearaudio-magix2.html
      "So the CDP is levitated, but how does it sound? In a word, fantastic!
      It's probably THE most effective isolation device around. It doesn't really change the sound that much, but what little it does matters so much to the music. It allows your equipment perform to it's fullest without exhorting it's own character, which by comparison, the Finite Element Ceraballs do so to a certain extent(if over used, that is!).
      I can say that each musical instrument, vocal replayed via the system now has an added dimension to it. Like high hats has that brassiness to it. The piano seems more naturally real and violins have that little extra sheen to it's resonating body. Vocals have the extra body too. Best of all each and every instrument presented within the sound stage has that little bit of air around them, making them seemed free, un constricted."
    • By coolhand
      Item: DH Labs Power Plus AC Cables x 4
      Price: See Below
      Can ship to anyone, anywhere at purchasers expense !
      Highly performance cables with unanimously positive reviews, the DH Labs Power Plus are built using high purity copper 12 gauge conductors wound in a noise cancelling geometry, they're also very flexible considering their high current capacity & thickness.
      I have 4 available:
      2 x 1.5m with Wattgate 526i/320i series terminations, $180 Each
      2 x 1.25m with Premium Furutech F-11M/G Au (24kt Gold Plated Pure Alpha Copper Conductor) series terminations, $275 Each
      Or take all 4 together for $900 😉
    • By coolhand
      Item: DH LABS Revelation (Pure Silver) RCA Interconnect Pair - 1m.
      Price: $425 (RRP. $820)
      Extra Info: Can ship to anyone, anywhere, at purchasers expense !
      DH Labs Revelation is constructed with Six Pure Silver conductors in an interleaved helical array.
      Each conductor is individually insulated in an air-spaced, tape wrapped proprietary air-Teflon matrix insulation consisting of 60% air.
      The dielectric constant of this foamy-looking material is only 1.4 which is closer than most to the theoretically ideal dielectric.
      Each cable is carefully terminated with custom machined 99.3% pure copper locking rca plugs
      DH LABS Revelation Review
      "As markedly as the Revelation cables improved the sound, it was the improvement in musical coherence that impressed me the most.
      On some CDs where I had previously only heard disparate musical lines, I could now hear how those lines related to and played off of each other.
      As a non-musician, I have to admit that it surprised me just how evident this improvement now was.
      Putting the DH Labs Revelation cables in my system left me feeling that I had upgraded not only all my components, but the sonic quality of my entire CD collection as well."
