hlov Posted June 15, 2018 Share Posted June 15, 2018 Item: Pro-Ject RPM 4 with Roksan Corus Blue cartridge Location:Brookvale Price: 450 ONO Item Condition: Used Reason for selling: NLR Payment Method: Pickup - Cash, Paypal, COD Only Extra Info: Selling my old TT in great condition, just the cover has some light scratches, it serves to its purpose of protecting the table against dust, it can't be used while playing records. I have uploaded a couple of videos so u can have an idea of the sound quality, take in consideration that I have recorded them using a phone. 33 RPM: 45 RPM I'm including a Roksan Corus Blue cartridge which came on the new TT I bought in here and the seller described as "looks in good condition and should have many more hours in it", I did tested and it sounds very nice. I'm also including the Pro-ject Modification kit (https://www.projectaudio.com.au/collections/accessories/products/turntable-modification-kit) which I have installed to remove noise created by the motor. It's a pretty decent and I believe better than the entry level ones that you can get for the same price, this model was the predecessor of the RPM 5, this is a review from What HiFi https://www.sarte-audio.com/sites/default/files/dbutiirpm4.pdf I don't have the original box so I'll recommend pick up, The turntable will need to be adjusted and the cartridge connected as I have disconnected for clean it. Pictures: Link to comment Share on other sites More sharing options...
Guest ctmar0 Posted June 15, 2018 Share Posted June 15, 2018 How long have you had this TT? Link to comment Share on other sites More sharing options...
hlov Posted June 15, 2018 Author Share Posted June 15, 2018 1 minute ago, ctmar0 said: How long have you had this TT? Hi mate, I bought it new mid 2013 and got my thorens at beginning of this year so it's about 4 years old. Cheers, H Link to comment Share on other sites More sharing options...
Mungbean66 Posted June 15, 2018 Share Posted June 15, 2018 (edited) Cool looking TT. If I wasn't buying a RCM, I'd be all over this. GLWTS Edited June 15, 2018 by Mungbean66 1 Link to comment Share on other sites More sharing options...
