I still have to line the inside with Dacron, 50mm thick, and install the Passive Crossovers before I glue the back on.
 They look awesome, a lot of work gone into these.
I got to think about some sort of bracket to hang them off the ceiling.
Now the fun begins with the installation.
The outer rim of the baffle will be screwed up into this frame that fits around the enclosure.
I have to build another support frame above the ceiling around the hole I cut in the gyprock that will support the weight.
I will get all this sorted using empty enclosures so I'm not handling the finished speaker, then the finished speakers can be installed.
