Introduction
Recently sold my SOtM SMS-200 (replaced with Ultra). Based on the number of questions received, it was apparent that many people were still learning about how a network player can fit into the audio chain. Decided to write this Primer to help people start their journey into the interesting (but at times frustrating!) world of a network player (also called network streamer).
Note that the SMS-200 is not plug and play, and requires configuration and a basic understanding of networking (e.g. ip addresses of SMS-200, NAS, static ip address vs DHCP).
Suggestions for improving this primer most welcome.
Typical Setup
The SMS-200 sits at the centre of the music chain.  It takes music from various sources, e.g. usb disks, NAS, computers and online sources such as Tidal and Spotify and serves the music to a DAC via a USB link. Unlike a noisy PC which can also be used at the centre of a music chain, the SMS-200 is specifically built to provide superb audio quality.
The SMS-200 comes with a number of servers/connectors to use. The Eunhasu software is accessed using a browser (//eunhasu) and all configurations and setups are done there.  Note that Eunhasu is the same for the SMS-200 and SMS-200 Ultra.
To manage and play music, a mobile or desktop App or a browser can be used.
Eunhasu has a Roon end point, but requires (expensive) Roon license as well as a separate computer to run the Roon server.  Roon is well developed software, good UI, good metadata management which leads to new music discovery, Tidal integration.  When purchasing a new unit, SOtM offers a Roon trial license as well as a discounted one year license.
The most popular and most versatile is probably Squeezelite (also known as Logitech Media Server, LMS).  LMS is well developed with a good ecosystem and is used extensively on PCs and dedicated Squeezebox’s.  With dedicated, well rated Apps on phones and PCs, also on browser, users can access music on servers, disk drives as well as Tidal and Spotify.   A good all-in-one solution.
MPD is best described as under developed, with interface average, cover art depending on client and limited playlist management. However, found MPD to sound better than LMS and is my current server.
HQPlayer NAA (end point) requires a separate computer to do the upsampling. HQPlayer requires a separate license.
Shairport is a clone of Apple’s  Airplay. LibreSpot is an open source implementation for Spotify-Connect. MinimServer  and Bubble are UPnP Audio Servers.
System setup manages the network, library (NAS access) and software updates.
Eunhasu manual here.
How Does It Sound?
Most people have found the SMS-200 (and Ultra) to significantly improve audio playback. See SNA thread. There are also plenty of other reviews on the web. Some good videos from Hans Beekhuysen: SMS-200 review  SMS-200 Ultra Review
Next Steps After Getting SMS-200 Going
There are many tweaks to get even better sound out of the SMS-200. See SNA thread.  Both the power supply unit and USB cable to the DAC are 2 tweaks that should be considered early on.
If you have issues, post here and there are a number of experienced SMS-200 users on the forum who may be able to help.  Also contact SOtM here; they usually reply within a few days.
It can get quite frustrating but please do not give up.  The reward is hopefully better music.
Edited by Snoopy8
Formatting
  • Like 15
  • Thanks 1
  • Replies 144
Popular Posts
Introduction Recently sold my SOtM SMS-200 (replaced with Ultra). Based on the number of questions received, it was apparent that many people were still learning about how a network player can fi
This is my setting in MPD Never had a problem with it, maybe you can play with this.
Okay finally got it to work. Within the librespot setup, you have an option to uninstall. So uninstall librespot. Then select librespot again in eunhasu within the setup function within librespot the
Good idea @Snoopy8
I've found my sMS-200 and now sMS-200 Ultra really easy to set up and use. I can see where people may get into trouble though.
After trying MPD, LMS and Squeezelite, plain  Roon and HQPlayer to Roon I settled on the HQ/Player Roon partnership as the best SQ with the nicest, easiest to use interface. It did take a bit of sorting out on the server end but as a streamer the sMS-200 was a breeze to set up.
Great write up. LibreSpot might give me the ability to use the Spotify app natively. Anyone use it?
Guest gnnett
17 hours ago, a.dent said:
LibreSpot works fine.
Well after 2 weeks of slightly temperamental operation I would have agreed with you, until this morning. Now it does not work again. And I think it has something to do with what I see as one of the biggest scourges on computing, MacAfee. For some reason despite my wife hating them with avengence after they crippled her previous computer, she appeared to have a new "free trial" operating on her computer with a warning that Spotify was trying to do something wrong to her computer. The only on screen option was to "buy" something from MacAfee, so shut down computer, again removed the MacAfee apps from the computer and with windows firewall turned back on, Available Devices sees the sMS200 but will not connect. So thanks again MacAfee, another $200 to get a computer geek to fix the mess you have created. Simply, Spotify say a firewall may be stopping it, but as per screen shot windows firewall has "allow Spotify" selected in all boxes!! So back to the drawing board.
Grant
Guest scumbag
Grant
Í work in tech support (not pure IT, software related) and Norton is terrible for crippling people's computers. And of course the WIN10 built in firewall / Defender software can sometimes wreck havoc for WAN/LAN related activities.
One avenue to look at it to ask SOTM and Spotify to verify which IP addresses and ports are required for the services. Also, obviously, creating exceptions for the music app's and services where possible / applicable would be a wise move. If it makes you feel any better (it probably won't), these sort of things afflict a wide range of users' who are simply trying to enjoy the user of their PC's.
Edited by scumbag
Guest gnnett
9 minutes ago, scumbag said:
Í work in tech
l here you mate.
My job has me at the mercy of this stuff too, so I am venting about other stuff as well. I will wait for the 'tech guy my wife trusts to work on this computer and revisit then.The sad thing is that last night a cousin was around and got her all enthusiastic with Spotify and now will be back to square one.
I will send an email to May again and hopefully she can advise something that might help. The problem is Spotify though. I have found Spotify to be absolutely useless and only interested in responding about payment methods. Nothing technical. If I find something better they will be gone.
Guest scumbag
Just going back to the flow chart above - there would need to be an ethernet switch to connect the NAS/SOTM/PC in there if I am not mistaken. Well that's my understanding of it.
And also, the Switch needs to connect to a router go get to the outside world. Yes?
Edited by scumbag
Guest scumbag
And just to sound like a total smart arse, I found setting up Roon with a similar setup very easy, though. I should say that was on WIN7 with AVG antivirus and the Windows firewall.
Edited by scumbag
Yes, that is correct. I was aiming for a simplified diagram...
Guest scumbag
But (engaging smart arse mode again), leaving that out might cause more confusion to a newbee.
Well I tried LibreSpot this morning but it only works for a couple of seconds then turns off. Not sure why.
My solution of using Squeezelite for Tidal also failed. It appears that the laptop has to be on for it to work, just like Roon.
Guest scumbag
Squeezelite is a service that runs on the SOTM isn't it? I would have thought that would work without a PC (unless there are other factors I'm not aware of in your setup). Are you running Squeezelite on your PC or on the SOTM? if it's on your SOTM I can't see why it would need the PC on.
http://docs.sotm-audio.com/doku.php?id=en:squeezelite
"Squeezelite is a network music player which could be used with Logitech Media Server(aka. LMS). Eunhasu has LMS inside of itself which is available Tidal, Qobuz and internet radio."
Edited by scumbag
Squeezelite is a player software not a server software. It only plays what is fed to it by LMS. You need LMS or Roon Server to feed it.
I've never used Windoze with Roon, LMS, Tidal, Spotify etc. My advice would be to switch to Ubuntu, Rock or OSX if you want to avoid that MacAfee or Norton problem. They've all worked seamlessly for me. I currently use Ubuntu which I feel is the best compromise.
Guest scumbag
i think I might have confused my terms. LMS is inside Eunhasu - " Eunhasu has LMS inside of itself " - so you'd just need some sort of controller (smart phone or tablet) to connect to the LMS server and control it. Or a squeezebox remote or squeezebox touch also I suppose.
Also I've read this:
https://support.tidal.com/hc/en-us/articles/205608542-SOtM
"Follow
SOtM
To use TIDAL on SOtM you have a variety of options.
For Eunhasu OS, when using Roon as a player activate Roon Ready or Roon server feature on Eunhasu web gui. Sign up for Roon and enter your TIDAL username and password in Roon under Settings, then Services.
When using Squeezebox as a player, activate Squeezelite features on Eunhasu web gui. Open Squeezelite app or LMS and install the ickSteam Music Platform and login or register an account to the ickStream Music Platform
To add TIDAL to your account and enter the service account details when using MPD/DLNA as a player, activate MPD/DLNA feature on Eunhasu web gui. Use Bubble UPNP application and select TIDAL service.
To add Shairport as a player, activate Shairport feature on Eunhasu web gui. Activate Airplay on your iOS devices or MAC and play music via TIDAL app.
For Windows OS connect TIDAL Web player via web browser or run TIDAL application and enter your username and password."
But I certainly agree about setting up a Roon Rock NUC. I am actually feeding my directstream junior directly through my Roon Rock (i.e. it is a server and an endpoint). This is meant to be a strict NO-NO but it sure sounds good to me.
Edited by scumbag
clarification
Guest scumbag
I was able to use LMS as a standalone server on my SOTM200 and I controlled it via the Squeezer app' on my Android phone.
Edited by scumbag
I've never tried this but it's good news it works as designed. With Spotty and Tidal apps (or via ickstream) installed on LMS it would be the best way to stream from Spotify or Tidal.
@Mike13  have you tried this?
Guest scumbag
Can I just say in all this - do get yourself a good Ethernet Switch - I bought a TP link 8 port and it was a piece of junk (lots of dropouts). So I replaced it with a TCXO 8 port (modded with new internal clocks etc) - http://ppaproduct.blogspot.com/2015/07/audio-grade-switcher.html and things are glitch free. I'm not going to claim that the mods in the switch made the sound better but I can categorically claim that all the dropouts stopped immediately so I guess that does mean the sound was better ;) . Of course, my setup might be different to yours but if you are getting glitches or dropouts - consider one of Paul Pang's switches or perhaps get a better ethernet switch.
Just me 2 bobs worth.
Edited by scumbag
Guest scumbag
SOTM= bloody expensive. No, I don't have that sort of change. I sold one of my kidneys already and apparently I have to hang on to at least one to stay alive.
+ 1 for the switch .. solved my connection issues i had with my sms-200 . I use a stock netgear gs-105 . Im planning on purchasing the uptone switch when released .
Thanks @a.dent and @scumbag . I installed iPeng app for iPhone. Funny thing is Tidal does disappear when I turn off my laptop. I did install LMS on it to install ickstream.
can ickstream be installed directly into LMS on SoTM?
For MDP, I put my Tidal cress in, but there doesn’t seem to be a way to play Tidal that I can find.
My router is about 10 metres from my SMS-200 so I use a cheap powerline Ethernet thing. I’m sure it’s not ideal. Is there another solution?
Guest scumbag
This is an old document but it suggests you can ; http://www.sotm-audio.com/files/Ultimate/sMS-1000SQ/english/ickStream_App_installation_on_LMS_english.pdf?a241e7
And, as much as people think 6moons is off with the clouds, here is a mention in this article: http://www.6moons.com/audioreviews2/sotm5/3.html
Hopefully the fact that someone had to remote into the SOTM to do this for the reviewer is a reflection of his lack of tech' prowess, not a reflection of how difficult it is!
Mark
Edited by scumbag
Guest scumbag
I bought a 4 in 1 WIFI extender. I wanted to get away from ADDING noise to my mains, after all I spent a lot of money to filter it out!!!
I'll look up the model tonight when I get home. Quite well priced and quite powerful WIFI with quality of service available (i.e use the same device to stream multiple data streams but give priority to your music stream).
Mark
Mark
That sounds good. I have an Apple WiFi extender but probably not great. I thought wired would be better but I guess not in this case.
Guest scumbag
There's a bit of discussion on computeraudiophile about that. As always, there are various opinions (opinions are like aholes right?). That's where I got the idea from - https://www.computeraudiophile.com/ca/bits-and-bytes/extending-a-network-for-hifi-r653/
Note option B. I went for a cheaper solution (but still powerful) as the model they suggest in the article is quite expensive.
this is one I got - https://www.umart.com.au/Edimax-BR-6478AC-AC1200--Multi-Function-Concurrent-Dual-Band-Router_39847G.html
It does give a strong WIFI signal - it certainly beats the one that I got from my internet provider.
Edited by scumbag
Well that’s a bargain if it works well with Hifi equipment.
Guest scumbag
I still have to really give this a proper try out though. It seems very good streaming to 4K Netflix to my TV though!
Guest scumbag
If it can handle 4K it can handle Hifi streams.
Yeah I know but the thing is, in this hobby, there's bytes and then there's the way things sound. At the risk of public crucifixion, The 2nd is purely subjective and sometimes doesn't correlate with measured performance.
I couldn't see how to install ickstream on the SoTM itself (I did install it on the laptop LMS).
@scumbag how did you manage to do this? You can stream Tidal without a non SMS-200 version of LMS?
I've got to decide quickly because my Roon trial runs out in a couple days. Got to say it has grown on me, fast.
Guest scumbag
Mike,
I was only quoting from those links with regards to Tidal / ickstream. I was able to get LMS running just fine inside the SOTM200 so i can speak from experience on that part.
in the 6moons review, it does mention that this can it can be done though in the screenshot it looks like it was a command line action.
If you buy the SOTM new you get good support. I had a guy log into my SOTM using my PC and teamviewer as i was having a network related issue. The techies know what they're doing.
I'd suggest shooting off an email to SOTM to confirm "from the horse's mouth". Then even if you get a used unit, you at least know that it is doable.
This is a really good suggestion!
Guest scumbag
Yes, I'm full of those.
Anyway, I think I have a 3 month subscription card sitting in my messy office. I don't know if it's any use to you but I could post it to you to perhaps start another trial. I don't think you'll be able to extend the one you're on though.
Also, if you buy 12 months and then go for lifetime, they deduct some of the 12 months against the full membership, I have read. So another thing to consider.
Edited by scumbag
Oh right, they probably deduct the number of months you haven't used. A 3 month trial would be good if you can find it.
Guest scumbag
I'll have a look.
I just went through the process of installing Tidal via ickstream on my sMS-200. It's basically exactly the same as on your mac PC or Linux computer.
I notice Deezer can be installed the same way. I'll have to give Deezer HiFi a shot via Squeezelite!
Open LMS
Click on settings
Paste ickstream repository address
Agree to terms
In Plugins open ickstream settings
Click on Tidal
Login
I've taken some screen shots.
740724518_ScreenShot2018-06-13at9_07_18pm.thumb.png.63207b1dedc141e743c01b12888441f7.png
770895287_ScreenShot2018-06-13at9_08_01pm.thumb.png.3fa4db116670d0213556a92885d5c41a.png520362518_ScreenShot2018-06-13at9_13_53pm.thumb.png.a85cc59f8dd5558c0e7d51deee981445.png1628142320_ScreenShot2018-06-13at9_16_47pm.thumb.png.07a0e9c7de88a9b3c3b386a5aa652548.png863220778_ScreenShot2018-06-13at9_18_12pm.thumb.png.be785a62221946e6ec081defeea04a98.png1879145904_ScreenShot2018-06-13at9_23_12pm.png.8b5a7b839cf54451eadc9ab99c64ae3b.png373316004_ScreenShot2018-06-13at9_23_25pm.png.887b12d4e10a70068a5819170be080a2.png
    • By Snoopy8
      Item: SOtM SMS-200 and Audioquest JitterBug
      Price:  SMS-200 + JitterBug bundle $445,  SMS-200 $430,  JitterBug $45.  Plus postage if required. $15 SNA donation on completion of sale.
      Item Condition: Good
      Reason for selling: NLR
      Payment Method: Pickup - Cash, Bank Transfer
      Extra Info:  Preference given to local pickup and cash for bundle.  Test of equipment welcome at pickup time. Will split if bundle not taken.  Postage at buyers expense if required.
      SOtM SMS-200 is a good cost effective laptop replacement, my own post here.  Replaced original 9V wall wart (USA  pins, dodgy adaptor) with an Australian 12V wall wart; 12V produces better sound. To get the best audio,  suggest pairing with a Gieseler  12V PSU or any other 9V/12V DC power supply unit.
      Audioquest JitterBug is  a simple-to-use and highly effective digital noise filter for USB connections that improves the sound of computer audio. Just plug JitterBug into the USB port for clearer, more compelling audio.
