MaxPlumage
SOLD: FS: SVS PB 1000 Subwoofer x 2
Item: SVS PB 1000 (duals)
Price: $750 each
Item Condition: as new, includes boxes
Reason for selling: want to upgrade
I have a couple of SVS PB 1000 subwoofers for sale. Bought in October last year, both in as new condition from a smoke/pet free home, still have the boxes. The reputation of SVS subs is well known: https://www.svsound.com/products/pb-1000
Please note: will only sell together.
Asking $750 each (price is final) pick up from Canberra.
Photos attached, questions welcome.
Cheers!
Edited by MaxPlumage
Hi do you still have it?
Hi mate sorry, but these went yesterday. Thanks for your interest and good luck finding what you are after.
    • By vik74au
      Item: REL Acoustics R-505 Subwoofer
      Price: $1,100
      Item Condition: Excellent, perfect working condition
      Reason for selling: Upgraded
      Excellent working condition, albeit some fine scratches on the piano lacquer finish, only visible under direct close light, see pics. Sole owner since new, carefully maintained in a smoke-free, no-children and pets home throughout its life.   Heavy duty long throw 12" Drive unit, 500 watts Class D See photo for more specs   Original box and packing as in photo, for pick up only as this sub is a heavy 26kg.   Accessories included as in photo: - Power Cord - Neutrik Speakon Interconnect (High Level) - Spikes - User Manual   NOT Included: I also have a set (of 4) of IsoAcoustics Gaia III isolation feet and carpet discs that I have been using on this REL for sale separately if buyer is interested, see last pic of it (without carpet discs) on the REL.
    • By crabnoodle
      Item: 2 x Monitor 9 v7, Monitor Center 1 v7, 4 x Monitor Surround 1 v7, DSP-3200 Subwoofer with Perfect Bass Kit
      Price: $2500
      Item Condition: Excellent apart from minor scratch on top of subwoofer cabinet.
      Reason for selling: Switched to different speakers due to a smaller room
      Extra Info: Selling as a set only. Modified subwoofer feet for extra height.
      Monitor 9 v7 - 4-driver, 2-1/2-way bass reflex, quasi-3rd-order resistive port, floorstanding model
      Center 1 v7 - 4-driver, 3-way center channel
      Surround 1 v7 - 4-driver, 2-way bi-directional surround/rear
      DSP-3200 - 12-inch single driver, bass-reflex, dual high-velocity low-turbulence resistive ports, built-in amplifier, USB Port / PBK Interface. 900 watts Dynamic Peak / 300 watts RMS.
    • By krusto
      Item: Velodyne SPL-800i MiniVee 8" Subwoofer (Black)
      Price: $600 with donation of course
      Item Condition: Perfect
      Reason for selling: NLR, last of my small subs
      Extra Info: Only 24 months old. This Sub is practically brand new and in Mint condition. I considered keeping this one, but alas, let someone enjoy it.
      Seriously small subwoofer that is an absolute ball tearer.  Comes with original box and shipper protective box for safe travels. Prefer a VIC sale, but happy to courier if required.
      AMPLIFIER
      1000 watts RMS power
      DIMENSIONS
      Speaker dimensions (H x W x D) 27 x 26 x 33cm
      Subwoofer: 8” forward firing (6.5” piston diameter)
      GENERAL
      Magnet Structure: 5.76kg
      Frequency Response: 28-120 Hz
      High Pass Crossover: 80Hz (6 dB/octave)
      Low Pass Crossover: 40-120Hz (12 dB octave initial, 48 dB octave ultimate) or bypass with Subwoofer Direct
      Phase Control: 0 or 180 degrees
      Protection: Dynamic compression
      Weight: 16kg
      DRIVER
      8” (6.5” piston) forward firing
      2.5” dual layer voice coil
      Die-cast aluminium basket
      SIGNALSOutputs: Line-Level, high pass crossover, 80Hz, 6 dB/octave
      Inputs: Gold plated RCA Line and Speaker Level Inputs
    • By krusto
      Item: Paradigm Monitor 10 Sub
      Price: $600 obo with donation of course
      Item Condition: NR MINT/MINT
      Reason for selling: NLR offloading my subs
      Extra Info:  Lightly used for music, very nice, smooth subwoofer. Incredibly small (sealed) cabinet. Not only awesome for musical applications, but deep and powerful enough for any home theatre enthusiast.
      Original box and accessories for safe delivery. Happy to courier if required.
      The amp and driver in this Monitor range are made in Canada, assembled in China.
      DESIGN Single driver, acoustic suspension, built-in advanced Ultra-Class-D™ amplifier, USB port for PBK?equalization, removable grille AMPLIFIER 900 watts Dynamic Peak; 300 watts RMS Sustained AMPLIFIER FEATURES Auto-on/off, soft clipping, thermal protection ROOM CORRECTION Anthem Room Correction (ARC®) (sold separately) LOW FREQUENCY DRIVER 254-mm (10 in) carbon-loaded polypropylene cone, Active Ridge (ART) Technology surround, 38-mm (1-1/2 in) 4-layer copper-clad aluminum voice coil. Nomex® spider, 4.5 lb ferrite magnet, AVS™ die-cast heatsink chassis FINISHES Black Ash WEIGHT 30 lbs. (13.6 kg) DIMENSIONS HXWXD 13" × 11.125" × 12.75" (33.0cm × 28.3cm × 32.4cm) LOW FREQUENCY EXTENSION 17 Hz (DIN) LOW PASS FILTER FREQUENCY Variable 35 Hz - 150 Hz; Bypass Option SUB / SAT PHASE ALIGNMENT Variable 0° - 180° INPUTS Two RCA (L/R-Mono) for L/R lineout or Sub-Out/LFE-Out of receiver/processor or other line-level source COMPATIBLE PRODUCTS PT-2 Wireless Transmitter (sold separately)
