MuBh
SOLD: FS: Rotel RB-1070 Power Amplifier - PRICE DROP
Item: Rotel RB-1070 Power Amplifier
Price: $475 $420  $375
Item Condition: Excellent
Reason for selling: Decluttering, Using tube amps
Payment Method: Pickup - Cash, Paypal (sending to a friend or 3%) , Bank Transfer
Extra Info: see below
Pictures: see below
This lovely Rotel Power Amplifier has served me well and still sounds like new. Like all Rotel products, it is built like a tank, at the same time very musical. I have since moved to tube amps and trying my best to declutter gears I no longer use. Other than a few light scratches on the chassis (see picture), the amp is in extremely good shape. I don't have the boxes, hence the local pickup option. The amp comes with a standard power chord.
For more information please visit the Rotel site - http://www.rotel.com/product/rb-1070
Edited by MukeshB
Price Drop
Price Drop
Good price for a solid reliable amp
Further price drop
    • By Supedeloop
      Item: Rotel A12 Intergrated Amplifier, 12 months old
      Price: $900 ono $720.00 inclusive $20 Donation
      Reason for selling: Change in direction
      Extra Info: Item is in excellent condition minus a little dust. Have box and I think all the original packaging.
    • By audio_file
      Item: Rotel RA-820
      Price: $150
      Item Condition: Scratched
      Reason for selling: Replaced
      Payment Method: Pickup - Cash, Paypal, Bank transfer
      Specifications from https://www.hifiengine.com/manual_library/rotel/ra-820.shtml:
      Power output: 25 watts per channel into 8Ω (stereo)
      Frequency response: 10Hz to 40kHz
      Total harmonic distortion: 0.4%
      Damping factor: 20
      Input sensitivity: 2.5mV (MM), 150mV (line)
      Signal to noise ratio: 75dB (MM), 95dB (line)
      Speaker load impedance: 4Ω to 16Ω
      Dimensions: 430 x 66 x 271mm
      Weight: 5.5kg
      This was used for PC desktop speakers driving KEF Q1 speakers.
      I tried it on my Spendor SP2/3R2 and it had no problem driving these.
    • By leqt1969
      Item:  Roksan Caspian M1 Power Amplifier
      Price: $750.00 ONO
      Item Condition: Excellent used condition
      Reason for selling: NLR
      Extra Info: Advertised on behalf of a friend in Sydney. This is in excellent used condition.
      Caspian M series-1 Power Amplifier Spec
      Input Impedance: 38 kΩ
      Input Sensitivity: 700mV RMS
      Signal Inputs: Left & Right channels
      Signal Outputs: Chain Output L & R Channels
      Power Outputs: Loudspeaker, L & R
      Output Power:> 85 Watts continuous, into 8ohm; both channels driven; 120 Watts continuous, into 4ohm; both channels driven
      Power Supply: 330VA Ultra Low Noise Toroidal Transformer
      Current Output: 50 Amps Peak to Peak
      Damping Factor: & gt; 140 (8ohm)
      Frequency response: -3dB, <1Hz -> 100kHz
      Gain: 30.7dB
      Harmonic Distortion: <0.003% 1 kHz - 8 ohm <0.003% 1 kHz - 4 ohm Signal to Noise Ratio:>116dB (ref 70W, 8ohm)
      Dimension: 432 x 330 x 70 (W x D x H) mm 432 x 330 x 85 (including feet)
      Weight: 10 Kg
    • By Goatboy
      Item: Exposure 3010 Stereo Power Amplifier
      Price: $680   $500
      Item Condition: Very Good - functions perfectly / minor cosmetic wear
      Having one last crack at moving this on. I think this is a great amp for the asking price.
      I bought this power amplifier from the forums in 2017. Its main use is HT duties, as well as spinning 10 hours or so of vinyl each week. The amp has performed flawlessly and presents as warm and emotive, ie. the Exposure house sound. The amp is rated at 100w / channel into 8 Ohms, and has the capability to run as a mono amp, as well as the option to biwire.
      Note: the amp only takes banana plugs.
      Cosmetically, there are minor blemishes and some light scratches on the top of the unit.
      I have the original box, and happy to post.
      https://www.exposurehifi.com/images/quickstart/3010_Power_Amplifier_QS_Manual_web.pdf
      Specs:
      Power Output (Stereo): 100 Watts per channel at 1KHz into 8 Ohms
      Power output (bridged mono): 110 Watts at 1KHz into 8 Ohms
      Input Impedance: 18K ohms
      Frequency Response: 20Hz - 20 KHz ±0.5dB
      Total Harmonic Distortion: <0.015% at rated output ref 1 KHz
      Signal to noise: >100 dB ref rated output
      Channel Separation: >60dB, 20Hz - 20KHz
      Mains Supply: 110/120V or 220/240V, 50/60Hz (factory set)
      Power Consumption: <350VA, 8 ohm load both channels driven
      Dimensions (H x W x D): 115mmx440mmx300mm
      Net Weight (unpacked): 11kg
      Gross Weight (packed): 13kg
    • By tfranic
      Item: Krell KAV-300i, 240V
      Price: $1200 + postage
      Item Condition: Used but in excellent working condition
      Reason for selling: Moved house and with too much gear, lightening the load
      Very reluctant sale as this is an excellent unit and whilst other amplifiers have come and gone, this has always sounded and performed flawlessly. I am the 2nd owner and used it to drive my old series B&W 604s. Whilst the back sticker states it is a 115V it definitely a 240V unit.
      I have the original double box packaging, the remote, operating manual and torx key. Input 3 is currently set for surround sound processor so bypasses volume control but can be changed with the flick of the jumper on the inside panel. Instructions within the manual.
      No marks to speak of except small one in the centre top panel at the back edge as seen in the last photo.
      Made in the USA
