Pipey
Rega Platter wobble
Hey, I bought a Rega planner 1 a few months back and have been enjoying it immensely. Just recently I’ve noticed it had a considerable amount of vertical wobble in the platter. I’m talking five or six mm. Moved the platter on the sub at five degree intervals and it made very little difference. Is this play deemed an acceptable amount of tolerance. To my mind I’d think not. I know the deck is a basic starter unit but I thought I’d be getting decent quality buying a recognized brand name. Any thoughts on the issue ? What would be the course of action to follow ?
If you bought new it's time to bring back to the store
Yep bought brand new, only two months old really.
I agree, if only two months old this is not correct and should not be your problem and you should not touch it as you could void your warranty.
Having said that the only cause I can think of is that the nut holding the sub platter bearing on to the plinth is loose.
Ah I see what I’ve done there. I’ll try to explain a little better. The movement is at the outside of the platter when the turntable is rotating.
So is it like an edge warp on a record and you are suggesting  the platter may be warped?
Although interesting to know the problem the main thing is it is not correct and should be returned.
Edited by EV Cali
Yep even without a record on there and the platter rotating it’s like it’s not totally flat. I’ll check it when I get home and make sure nothing is loose or on the piss.
rega planar 1 warped platter is not uncommon. so is sub platter issue. Since it's using some type of resin on both of them not something rigid like glass, metal or perspex. I've seen many post regarding warped planar 1 platter
Do you know if they found a fix ? Or went to a different deck.
Many Rega models have suffered from platter wobble. It is a sub platter warp causing the problem. Your dealer should replace the sub platter. Zero tolerance for vertical platter wobble.
No fix rather than replacing it. To be fair it is not a design issue more of manufacturing and quality control issue. the material itself is fine if it's been made properly, not the best but fine for it's price bracket.
 Replacing the sub platter with a Groovetracer or Tangospinner metal sub platter will solve this issue.
Ok. After a little tinkering I’ve improved the situation a whole heap. I took the platter off and pulled the sub platter spindle assembly out. Made sure the plastic sub platter was full down on the spindle. Not sure if it moved but. Chucked it all back together and now I’m only getting the slightest bit of wobble. 1 mm maximum. Think I’ve got it the best I can hope for. I’ll call that a win. Thanks for all the reply’s and input 👍
Hi all,
i have the same issue with my rega P3. I took it back to the supplier who have said I may have damaged it moving house which I don’t believe. They have also told me a little platter wobble won’t make a difference. I’ve never been happy with their response. Where do I stand with this. The one they use to demo in the shop is fine.
4 hours ago, Paul80 said:
Hi all,
You didn’t cause the sub-platter to warp by moving house. Stand on your dig and demand a replacement sub-platter.
Yep common problem with Rega turntables. I had an old Planar 3 from the Eighties with the same problem. A 5mm wobble would be clearly audible as an unstable pitch, like a badly warped record. Get a replacement sub platter or buy an aftermarket upgrade. It's a popular upgrade for Regas.........
5 hours ago, Paul80 said:
Hi all,
Both those responses are crap. If its under warranty, take it back and get them to remedy the problem.
    • By tachi
      Item Condition: Good condition Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Huntingdale State: Western Australia Payment Method: Paypal, EFT Reason for selling: Moving on Further information: This is a MMF 9.1, bought in Singapore. The main difference between this model and the Australia model is the motor. It uses a 16V ac motor. I  have been using it for the past 6 years' without any issue.
      Specifications
      Triple Plinth
      Drive method: belt drive
      Motor: 16 V ac motor
      Platter: 1" Acrylic
      Speeds: 33 and 45rpm
      Tonearm: Project 9cc (carbon fibre)
      Price includes a fully functionable turntable with dust cover and please note that no cartridge is included. For a detail review, please refer to:
      http://www.stereomojo.com/MusicHallMMF9.1Turntable Review/MusicHallMMF9.1TurntableReview.htm
    • By hugo_wilco
      Item Condition: Excellent just a bit of dust Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Melbourne State: Victoria Payment Method: Eft Paypal Cash on pickup Reason for selling: Funds required Further information:
      Unfortunately due to Pandemic I am forced to sell my gear. This is my favourite TT and has been the longest I’ve had. This TT is phenomenal and I don’t  I want to let this go but don’t have a choice.
      The Ref2 is the latest with the updated power supply.
      Purchased from the wonderful guys at Sonic Purity.
      Will be selling  Phono stage separately
      Your chance to get an endgame TT package at nearly Half  price!!!!
      RRP: $14,900
      Buyer to pay out of pocket Paypal fees.
      Will be boxed so can arrange freight to interstate.
      TURNTABLE ONLY FOR SALE
      Have all boxes and packaging. Will be boxing them in the next few days Nd will post photos.
    • By mashley
      Item Condition: New Shipping Options: Shipping is available at agreed cost. Suburb or Town: Potts Point State: New South Wales Payment Method: PayPay, EFT only Reason for selling: No longer required Further information:
      I have 8 new Littelfuse 251001 1A very fast acting pico fuses.
      These 1 amp ones are used in the Rega Radio and Radio R.
      Some years ago, a power surge in a lightening storm caused the two in my Rega Radio R to blow, thankfully saving the Radio.
      I had to buy a pack of 10 ... hence now there are 8.
      My Rega gear is long gone, so hopefully someone else can make use of them as spares.
      $5 will be donated to Stereonet.
      Littelfuse_Fuse_251_253_Datasheet.pdf
    • By mashley
      Over the years I gathered a fair bit of info on my now long gone Rega gear -  Planet II, Radio R, Elex, Mira II - and on lots of other models and variants as well.
      I was a bit - well, alarmingly - obsessed with the rough industrial clamshell aesthetic!
      Info includes reviews, circuit diagrams, circuit board layouts, Rega service notes, interior and exterior photos, user manuals,  and some notes and info from forums.
      Not a huge amount ~ but if anyone similarly obsessed and/or suffering and can make use of it,  PM me and I'll send you it all in a zip (130MB).
      Here's a very nice Red Planet (found here https://www.flickr.com/photos/ippinkan/) - sadly Rega didn't go further with colour. Sadly I didn't think of repainting mine!
