Ittaku 4,461 Posted May 24, 2018 Share Posted May 24, 2018 (edited) I've been making my own custom speakers on and off for over 20 years and recently got inspired to start all over again with an open baffle design and all the latest scanspeak drivers, and upgrade pretty much all of my components. I'm extremely happy with the final result. I set out to create something that should be very natural sounding and be scalable to recreate large scale symphonic works and organs. Here is the executive summary of how it looks, before I introduce the family members: As you can see, MSB Reference DAC, Supratek Preamp, then into Audio Research Power amps and an SVS subwoofer. The power amps feed via XLO cables into my custom open baffle speakers. Everything is sitting (standing?) on solidsteel racks. Things aren't spaced evenly to make up for inadequate interconnect lengths Before you ask, the round thing at the back left is a fan... it gets awfully hot in here in summer with all those valves even with the ducted aircon running so I need extra airflow. That particular Dyson fan has a very low speed setting which isn't too noisy which is why I chose it. Data from my PC is first fed to the MSB Pro ISL interface which converts USB into MSB's custom optical fibre communication which gives it complete electrical isolation from the PC and supports up to 768/32 PCM, 8xDSD, and MQA. This feeds into an MSB Reference DAC. Again, this is connected via generic coaxial cable. This DAC had the extraordinary ability to make things just sound so much more realistic bringing instruments and people into the room. This DAC then feeds into a very unique Dual Cabernet preamplifier made by Mick at Supratek for my custom use which is basically a 4 channel preamp with separate inputs and outputs for mains and subwoofer. It has an amazing ability to simply flesh everything out and give the dynamics far more realistic contrast. Additionally with the DSP room correction I needed more gain. The reason this is a custom version is the default preamp is a 2 stage preamp which is normally considered advantageous but it added too much noise to my quite high gain amps so he redesigned it with bigger transformers and to be single stage only. The subwoofer channels are using new EH 6SN7s while the main channel has some military NOS 6SN7s on the driver and output stage. Those are herb's audio dampers on the valves. The preamp has a completely separate power unit: Since this photo, I've replaced the rectifier with a new Sovtek 5AR4. It didn't change the sound at all but runs cooler and outputs more current than the original NOS military valve it came with. Additionally I've replaced the two regulator tubes from the generic NOS military 6L6GC with modern Sovtek 6L6WXGTs which are a drop in replacement but rated to higher power. Again this didn't change the sound at all. The subwoofer is an SVS SB16 ultra, it only handles below 30Hz with a 4th order crossover, but measurements show room response flat down to 10Hz: Power amplification is via my beloved Audio Research Reference 250SE monoblocks: They are no doubt the heart of this system and responsible for the most musical, scalable and controlled sound I've ever heard. The tonality and richness of instruments is remarkably realistic. All instruments seem to have so much richer overtones and real presence in the room. For small acoustic works, it sounds like the ensemble is in my study even when I walk outside the room and around the house. I took the covers off even though they have fans in them since they're relatively protected in those stands and a bit more cooling won't hurt. I recently upgraded from a Reference 150SE which I already loved more than enough but snatched the opportunity for these babies because I've always wanted monoblocks just because. They have way too much power for my system which is reasonably efficient already. My speakers are a combination of drivers from Scanspeak: a 2x 32cm cone woofer, 2 x 12cm cone midranges and 1 beryllium dome tweeter: The reason for 2 midranges was they were (8 ohm) less efficient than the other (4 ohm) drivers and did not handle as much power and I really want all the drivers operating only ever in their linear range, and initially I had only the one woofer but due to massive dipole loss I moved to two. I had experimented with multilevel crossovers for each midrange but felt both doing exactly the same range was better. DSP is essential for these designs given their open baffle design and my small room, and I use custom convolution filters on Roon to expedite this. Speaking of crossovers, they're 12dB Linkwitz-Riley made from Miflex copper film and foil caps where possible, otherwise metallised poly films for the larger values but still bypassed. The smaller values are copper foil in paper caps. When caps were not in the signal path, I used miflex metallised poly caps. The inductors are 10 gauge solen inductors, solid core for the lower frequencies and litz for the higher frequency applications when the skin effect resistance was significant below their crossover point. Resistors (only go to midranges) are duelund silver graphite. Wiring is neotech OCC flat to tweeter and midrange and cardas crosslink to woofer. Terminals are cardas copper tellurium - I originally used the silver rhodium connectors but I wanted to solder directly to the terminals and this material is not suitable for such use. Soldering is with wonder solder. The soldering is dodgy as but it works. My lack of final production skills is the reason I never got into professional speaker building. Maybe if I can employ someone to do the building after I design them it might work... Power cables as you can see are shielded thick cables, but not big name brands. I can't hear any differences between power cables so I don't bother. USB cables are cheap generics; again I can't hear differences between different USB cables, nor network cables. Interconnects are Neotech silver coax between DACs, custom made Neotech flat balanced from DAC to pre and pre to power for the main channels, and cheap generic NB speaker cable interconnects to subwoofer. Speaker cables are XLO reference 3 gunshot: The observant amongst you will have noticed the left power amp is on the right and vice versa. These speaker cables are so thick and unwieldy it was the only way I could make it work. The yellow cable is the fibreoptic cable going to the DAC. Power has since been upgraded to have two dedicated 20A lines, one for each power amp, and another regular line for the rest of the components. Did not change the sound at all. Power is regenerated, cleaned, and regulated by a PS Audio P20. Surprisingly this breathes more life, dynamics, and realism into the music, unlike power filtration devices. This is the PC that drives it all. I do a lot of software and translation work in my study where the hi-fi is and use the PC for both work and music duties. This is a completely passively cooled i9900k with 128GB ram and is dead silent. Perfect for even the quietest listening playback. The acoustic partition you see at the back are my makeshift room treatment that tackled the issue of surfaces I couldn't really mount things to. I have one on the front and rear wall, and one on the side. The room itself is quite "lively" without them, because it has lots of diffraction but very little absorption. These work surprisingly well considering their minimal cost and effort. That's a heater at the bottom in case you're curious. Music is predominantly classical; a massive collection of Bach, a lot of romantic era and plenty of early 20th century music. Most is sourced from prestomusic. I do listen to other types of music, especially some ambient electronic music, but as the system has improved I've found myself listening to more and more classical. I can finally listen to organ music and be satisfied. My rock collection hasn't been played in many years, but I've recently rediscovered gem recordings there and occasionally play them. Edited July 28, 2020 by Ittaku Updated pics 28 2 Link to post Share on other sites
andyr 5,869 Posted May 24, 2018 Share Posted May 24, 2018 Yes, indeed, Con - I enjoyed listening to it a couple of months ago, very much. 👍 I'm sure the dual AR monoblocs have pushed it up a notch or two! Andy 2 Link to post Share on other sites
Ittaku 4,461 Posted May 24, 2018 Author Share Posted May 24, 2018 2 hours ago, andyr said: Yes, indeed, Con - I enjoyed listening to it a couple of months ago, very much. 👍 I'm sure the dual AR monoblocs have pushed it up a notch or two! Thanks Andy. I much enjoyed listening to your system as well which had a completely different approach entirely to getting great sound. Link to post Share on other sites
Ittaku 4,461 Posted May 24, 2018 Author Share Posted May 24, 2018 (edited) Interestingly I think Mick hinted at my particular preamp variant in this blog post which he says will now be the default design: http://supratekaudio.blogspot.com/2018/03/were-back.html Here's hoping the noise issue in my system has helped make his preamps even better for everyone Edited May 24, 2018 by Ittaku Link to post Share on other sites
Ittaku 4,461 Posted June 6, 2018 Author Share Posted June 6, 2018 Apologies to those interested in the P700 transport; during a recent computer upgrade the CD transport came in handy again so I've decided not to put it up for sale. Link to post Share on other sites
Ittaku 4,461 Posted June 6, 2018 Author Share Posted June 6, 2018 Here's the USB cable I'm using which keeps the power away from the DAC. It allows me to power USB separately but the DAC doesn't need power from USB so I simply don't attach it to anything: Link to post Share on other sites
Ittaku 4,461 Posted June 21, 2018 Author Share Posted June 21, 2018 Upgraded the valves in the primary channel output stage on the preamp with the PSVane treasure globes. This was a complete gamble but paid off. They've given substantially more leading edge to the sound with bite to rosin on steel in violins, faster attack to all percussive sounds and more detail across the board. Initially they were cold sounding but after a couple of hours of burn in that went away. The instruments now are substantially larger vertically, have more air around them and more recessed in the stage. All in all a great improvement. Photos linked from my other thread: 3 Link to post Share on other sites
Ittaku 4,461 Posted June 22, 2018 Author Share Posted June 22, 2018 (edited) Next experiment: I've replaced the NOS tubes the preamp standalone power supply came with newer tubes, nothing special except that they're all significantly higher rated output (but still compatible) than the ones included, on the basis that the power supply is everything. The rectifier is a standard Sovtek 5AR4 which is rated at higher current output than the 5U4M it came with, and the power output tubes are matched Tungsol 7581As which are a drop in replacement for 6L6GC which the preamp was designed for but again produce significantly more power than the NOS 6N3C it came with. So far so good. The rectifier runs 25 degrees cooler (115) than the old one which is reassuring, while the power output tubes are at the same temperature (115). What difference do I hear? I don't hear any timbral or tonal balance changes, no changes to air, detail or stage... but the dynamics feel more solid, linear, and effortless going from the ultra quiet passages to explosions. I do believe the channel balance is slightly different too, possibly because these are matched tubes where the previous ones weren't but it could be my imagination. The only thing that's annoying is "thetubestore.com perfect pair" sticker they put on the base - it doesn't easily peel off without leaving residue so I had to leave them there which I'm not fond of 😕 . At least these guys delivered much faster than psvane.com even though both sent from Canada. Go figure. The tube dampers are a generic token gesture - I can't hear any difference with them on or off but they cost almost nothing so I leave them there Edited June 22, 2018 by Ittaku 1 Link to post Share on other sites
mach1 58 Posted June 23, 2018 Share Posted June 23, 2018 Hi Con, That's some journey you've been on. I totally admire your single minded devotion to the cause. 👍 Just one thing - the sub and its proximity to sensitive thermionic signal processing. Personally I would have it at far away from tubes as practicable. cheers Paul 2 Link to post Share on other sites
Ittaku 4,461 Posted June 23, 2018 Author Share Posted June 23, 2018 2 hours ago, mach1 said: Hi Con, That's some journey you've been on. I totally admire your single minded devotion to the cause. 👍 Just one thing - the sub and its proximity to sensitive thermionic signal processing. Personally I would have it at far away from tubes as practicable. Thanks Paul, while I did find it made a difference with the earlier preamp I didn't notice a difference once the preamp was changed to a low gain version, and it didn't seem to have any effect on the power amps. Link to post Share on other sites
Phill 37 Posted June 24, 2018 Share Posted June 24, 2018 Hi Con, Seems open baffle design is becoming quite popular, I had the opportunity to check out a friends system recently, same amp and phono stage pre as me, OAD UltraAudio, the focus and reason for my visit being his newly tuned Linkwitz LX 521 OB's, I've got a great system, one that I have finally been close to content with for some time that was until I got to hear the LX 521's, this system is on another planet compared to some of the best systems I've heard anywhere in every conceivable way, atmospherics and sound stage is a quantum leap ahead of my really very good box speakers, the bass is something one has to experience, magnificent, unbelievable shocking so now I'm saving again for my pair of open baffle design for my room. My compliments on your patience setting these things up, I know it can be a hit and miss nightmare till you nail it. Keep us interested people up to speed on your project. Just wondering do you think the shelf above the woofer would be interfering at all also I agree with your plan to extend the baffle length, I did think the driver array in your speakers needed some space, the tweeter is a bit crowded and close to the top mid driver, I noticed your using beryllium dome tweeters, are you happy with the top end, Seas has some very nice soft dome's available if you find the top a bit bright and could maybe negate the need for the foam. Regards Phill. 1 Link to post Share on other sites
davewantsmoore 6,549 Posted June 24, 2018 Share Posted June 24, 2018 4 minutes ago, Phill said: LX 521 The key to this speaker is it's constant coverage pattern (helped by the funny shaped baffle). 4 minutes ago, Phill said: Just wondering do you think the shelf above the woofer I have a similar shelf (just below) the lower-mid woofer in my OB .... and I spent a lot of time worrying about it, but it didn't seem to have much negative effect ... and the shelf was kinda unavoidable for me. 4 minutes ago, Phill said: I did think the driver array in your speakers needed some space, the tweeter is a bit crowded and close to the top mid driver The tweeter really needs be to be close to the mid driver. If anything, I'd say it's not close enough. 4 minutes ago, Phill said: negate the need for the foam One way to do this, would be like in the 521, to get rid of the baffle around the tweeter ...... but the baffle shape needs to be part of the 'whole design', so it would mean kinda revisiting the entire speaker. 14 minutes ago, Phill said: saving again for my pair of open baffle design for my room The 521, or any of JohnK's designs, are really really good (as mentioned, the funny shaped baffles are a big part of it). 1 Link to post Share on other sites
Ittaku 4,461 Posted June 24, 2018 Author Share Posted June 24, 2018 (edited) Thanks for your comments. Phil, you're absolutely right about the open baffle. I've been tinkering with speakers for 25 years and this is my first OB design - the woofer was the reason I finally felt it was possible to do as this particular woofer handles 300W of power and is flat to 30Hz in free air. There are some unique challenges in making OB work at loud levels and be controllable at the same time. I'm actually considering changing from the one 4ohm 13" woofer to two 8ohm 13" woofers when I "finalise" the design in the future just to handle even more power - an unloaded woofer can't really handle the same sorts of power levels as it can in a box. Additionally it's impossible to get a flat frequency response in a real world room but modern DSP has made it far more manageable (I'd say it's essential if you're aiming for full range from OB woofers). However when you get it right, the incredibly tightly damped bass is second to none; the speed and lack of smearing and the group delay is unbelievable. Listening to a speaker with a box - any speaker - even up to hundreds of thousands of dollars, is disappointing now. The box is always audible. That said the current baffle I have is terrible with its own vibrations since the woofers do so much excursion. I don't think timber of any thickness will ever suffice which is why I'm having a friend help me with some finite element modelling on an aluminium billet baffle instead. The challenges are much bigger than I originally thought... The parcel above the woofer is there to hold the crossover components for the mids/tweeter, but also to give it some physical structure and rigidity to stand up. The sloped front baffle would flex like a tuning fork otherwise lol. As for the tweeter - it's supposed to be as close as possible to the midrange to minimise lobing. The crossover being 2500Hz means it's impossible to avoid lobing entirely. It's physically impossible to get this much closer than it currently is @davewantsmoore You can't see it but the foam is over some of the physical surround of the tweeter. As for the foam - it is not there at all because these are bright in any way shape or form - it's there to minimise the diffraction from the extra wide baffle. The baffle design was always meant to be temporary and in its final form would be sloping away from the tweeter and much narrower either side of the tweeter. There is no soft dome tweeter I've ever heard that sounds anything close to this beryllium tweeter - any preconceived ideas you may have about what a tweeter will sound like just because it's made of metal will be smashed if you hear what these sound like. The tweeter is the most transparent part of the whole design as it's virtually impossible to attribute any particular sonic signature to them. They just have an unlimited extension to the sound and just completely disappear, replaced only by music. Nothing tizzy or bright or sharp or fatiguing, purely liquid sounding natural tones without any artificial warmth the way ribbons do, either. Where's all this going? Well I've been considering starting an actual speaker business and as awful as this temporary design looks, I do have potentially grander plans, getting a few friends involved with expertise to get me over some of the other hurdles. However the parts alone cost many thousands so a production version of these sorts of speakers would be in the tens of thousands, but I also have a more minimalist smaller design in mind; it'd still be very expensive. I'd only be making very small numbers for very particular customers, and I would only be doing it for love, not money. Watch this space (but very very patiently)... or not. It may never eventuate. Actually I'd be happy to have people come around and have a listen even it this form, though one at a time because my listening space is currently confined. Edited June 24, 2018 by Ittaku Link to post Share on other sites
Nada 1,438 Posted June 24, 2018 Share Posted June 24, 2018 50 minutes ago, Ittaku said: . .. The parcel above the woofer is there to hold the crossover components for the mids/tweeter, but also to give it some physical structure and rigidity to stand up. The sloped front baffle would flex like a tuning fork otherwise lol. Well this is an opportunity if you want to experiment. Just add side walls under the shelf and leave the back open you will very quickly make a U-baffle to experiment with. Your low bass will get appreciable gain to fill in to your sub at 30Hz. 1 Link to post Share on other sites
Ittaku 4,461 Posted June 24, 2018 Author Share Posted June 24, 2018 Just now, Nada said: Well this is an opportunity if you want to experiment. Just add side walls under the shelf and leave the back open you will very quickly make a U-baffle to experiment with. Your low bass will get appreciable gain to fill in to your sub at 30Hz. Thanks that was actually considered in my original design as well, however I wanted to avoid parallel walls of any sort so they would have been flared out. Again this was a temporary design and I may consider it to minimise the wrap around loss, but it wont have any effect at 30Hz - that waveform is just too darn long to be stopped by that. Nonetheless you are right and something I may do next iteration. Link to post Share on other sites
Nada 1,438 Posted June 24, 2018 Share Posted June 24, 2018 Wouldn't it be better to try the U-baffle now in the temporary frame? It is a "test bench" and happens to be just crying for a quick U-baffle mod. 1 Link to post Share on other sites
Ittaku 4,461 Posted June 24, 2018 Author Share Posted June 24, 2018 1 minute ago, Nada said: Wouldn't it be better to try the U-baffle now in the temporary frame? It is a "test bench" and happens to be just crying for a quick U-baffle mod. Absolutely Link to post Share on other sites
Nada 1,438 Posted June 24, 2018 Share Posted June 24, 2018 31 minutes ago, Ittaku said: Absolutely Oh great. Im way too lazy to build a U-baffle so hope you try it and let us know how it sounds. Link to post Share on other sites
soundbyte 1,476 Posted June 24, 2018 Share Posted June 24, 2018 22 minutes ago, Nada said: Oh great. Im way too lazy to build a U-baffle so hope you try it and let us know how it sounds. I think that there is a problem with a U baffle with parallel sides. Easily done though, four square pieces of MDF and stand them in place. As quoted from @Ittaku 's post above "The box is always audible." a U baffle is nearly a box and as such I think you will hear it. I suggest that any if extra sides be used, as @Ittaku says, they should be flared, even then you may well hear a negative change in sound quality. Link to post Share on other sites
Ittaku 4,461 Posted June 24, 2018 Author Share Posted June 24, 2018 There is one thing I have on my side though with the woofers - they cross over at 230Hz and the side walls will be too close for that frequency or below to form standing waveforms. However it is also giving it more material that can resonate. Link to post Share on other sites
THOMO 1,744 Posted June 24, 2018 Share Posted June 24, 2018 (edited) A really interesting system. Are those Scanspeak Illuminator 12MU midranges as used in some of the most expensive speakers in the word? Nice to see the speckled /black spot jarrah cabinets on the Suprateks.That is pretty rare timber. Edited June 24, 2018 by THOMO 1 Link to post Share on other sites
Ittaku 4,461 Posted June 24, 2018 Author Share Posted June 24, 2018 (edited) 6 minutes ago, THOMO said: A really interesting system. Are those Scanspeak Illuminator 12MU midranges as used in some of the most expensive speakers in the word? Nice to see the speckled /black spot jarrah cabinets on the Suprateks.That is pretty rare timber. Yes those very midranges; the same as in the Wilson WAMMs. I can't tell for certain but it appears to be the same woofer too (but my tweeters are better the WAMMs' ) Edited June 24, 2018 by Ittaku Link to post Share on other sites
davewantsmoore 6,549 Posted June 24, 2018 Share Posted June 24, 2018 4 hours ago, Ittaku said: Thanks that was actually considered in my original design as well, however I wanted to avoid parallel walls of any sort so they would have been flared out. As long as you operate it below the cavity resonance you will be fine.... although I suspect you are operating the driver at a higher frequency because of the small midrange, and 12dB filter. I did a fair bit of measuring of a smaller cavity ~20cm x 50cm cavity with a "Z" frame in it ..... and it was fine with a 24dB octave slope low pass filter at (-6dB@) 120Hz. 4 hours ago, Ittaku said: Again this was a temporary design and I may consider it to minimise the wrap around loss, but it wont have any effect at 30Hz It will give you more gain at 30Hz (than what you have now) .... but not enough unless you apply more EQ somehow. Link to post Share on other sites
Ittaku 4,461 Posted June 24, 2018 Author Share Posted June 24, 2018 (edited) 7 minutes ago, davewantsmoore said: As long as you operate it below the cavity resonance you will be fine.... although I suspect you are operating the driver at a higher frequency because of the small midrange, and 12dB filter. I did a fair bit of measuring of a smaller cavity ~20cm x 50cm cavity with a "Z" frame in it ..... and it was fine with a 24dB octave slope low pass filter at (-6dB@) 120Hz. It will give you more gain at 30Hz (than what you have now) .... but not enough unless you apply more EQ somehow. Roger on that, it's a 12dB LW design without L-pads or zobels (they only make the sound worse in my experience). I drive the woofer up to just before cone cry at 230Hz and cross over to the two midranges there. It allows me to still use an air core inductor (for extreme power capability with no saturation) with 10 gauge wire thus keeping the resistance of the inductor lower than if I had to cross it over lower - thus minimising any loss of damping, and is high enough above the natural roll off of the midranges (which is 150Hz) to not destroy them from too much excursion, but since they don't handle as much power with linear response, that's why I have two of them. Alas that means I had to put a resistor to the midrange components even though they're less efficient due to the crossover exciting the band pass component. I like to have as few components in the signal path as possible but the resistor was essential for balance. Edited June 24, 2018 by Ittaku Link to post Share on other sites
davewantsmoore 6,549 Posted June 24, 2018 Share Posted June 24, 2018 What do you do about EQ needed for each driver, eg. the 6dB extra slope, or the 'dipole peak' EQ? Link to post Share on other sites
Ittaku 4,461 Posted June 24, 2018 Author Share Posted June 24, 2018 (edited) 10 minutes ago, davewantsmoore said: What do you do about EQ needed for each driver, eg. the 6dB extra slope, or the 'dipole peak' EQ? DSP is an essential part of my system, hence why I use the Dspeaker X4 as my DAC/DSP/Crossover. But what exactly do you mean by EQ needed? To tame peaks, boost troughs, or balance output or... something else? The sensitivies between them are balanced to the same 91dB, the peak from the bandpass crossover I mentioned needs one resistor on the midrange. The rest are balanced in an anechoic environment, but the DSP fixes it for a real world environment. Edited June 24, 2018 by Ittaku Link to post Share on other sites
davewantsmoore 6,549 Posted June 24, 2018 Share Posted June 24, 2018 1 minute ago, Ittaku said: DSP is an essential part of my system Ah! 1 minute ago, Ittaku said: But what exactly do you mean by EQ needed? The response of a dipole has a peak in it.... and you would flatten the peak with EQ, if it wasn't substantially reduced in level by the crossover. The peak frequency depends on the baffle width (wider baffle, lower frequency) http://www.musicanddesign.com/Dipoles_and_open_baffles.html Link to post Share on other sites
Ittaku 4,461 Posted June 24, 2018 Author Share Posted June 24, 2018 1 minute ago, davewantsmoore said: Ah! The response of a dipole has a peak in it.... and you would flatten the peak with EQ, if it wasn't substantially reduced in level by the crossover. The peak frequency depends on the baffle width (wider baffle, lower frequency) http://www.musicanddesign.com/Dipoles_and_open_baffles.html Sure, but I wasn't sure what particular part of EQ you were referring to. As you see the dspeaker DSP is essential - again part of why I hadn't tackled OB before because these problems had much more convoluted workarounds in the past. Fortunately the X4 sounds amazing as a DAC too, and does its DSP at much higher - native - sample rates than most setups so I don't need to rely on resampling and its attendant issues. Link to post Share on other sites
davewantsmoore 6,549 Posted June 24, 2018 Share Posted June 24, 2018 Oh, but that DSP, is stereo in/out (or did I read it wrong?) .... how do you get the filter slopes right for each driver? Link to post Share on other sites
Ittaku 4,461 Posted June 24, 2018 Author Share Posted June 24, 2018 9 minutes ago, davewantsmoore said: Oh, but that DSP, is stereo in/out (or did I read it wrong?) .... how do you get the filter slopes right for each driver? What? The crossover is passive. The DSP is for impulse and amplitude only. Link to post Share on other sites
Ittaku 4,461 Posted June 24, 2018 Author Share Posted June 24, 2018 Sorry I may have confused you by saying the dspeaker is a crossover as well - it's only a crossover to the subwoofer. I use 4 channels out from the dspeaker into a 4 channel preamp. The 2 main channels from the preamp go into the ARC amps which feed the main speakers while the 2 subwoofer channels from the preamp go straight into the subwoofer's own amplification. Link to post Share on other sites
davewantsmoore 6,549 Posted June 25, 2018 Share Posted June 25, 2018 What? The crossover is passive. The DSP is for impulse and amplitude only. Then my original question remains. How do you account for the dipole peak for each driver? 1 Link to post Share on other sites
Ittaku 4,461 Posted June 25, 2018 Author Share Posted June 25, 2018 Okay I spent a few hours playing with side walls for the woofer today. I went hunting for something suitable from Bunnings and it delivered in the form of some 16mm thick floating MDF shelves that were just about the right size. I did not try to secure them to the side of the speakers as such, just resting them at various angles upright along the side and performed a few measurements with them as parallel side walls, flared side walls, inside walls only, outside walls only. Simply placing them on both sides and having a quick listen revealed an immediate increase in low frequency amplitude and the measurements confirmed this. Putting either inside or outside side walls on the speakers conferred a 2dB boost across the entire frequency spectrum that the woofers operate. Both changed the position and amplitude of various peaks and troughs in subtle ways, however adding just inner walls created an exaggerated trough at approximately the crossover frequency of 230Hz for reasons unknown - using just outside walls did not exhibit that. Putting both inside and outside side walls created a massive 5dB boost across all frequencies without any change to the overall shape of the frequency plot. This seemed to be quite a nice win in terms of how much DSP management would be required to balance outputs. Recalibrating the DSP room correction I had to create different profiles for the amplitudes to be similar to be able to conduct a meaningful listening comparison, otherwise tone balance would be different. Listening to the change, however, is where it got frustrating. My first impression was that it was boxy sounding suddenly when it hadn't been because I initially had the side walls parallel. Even though the woofer shouldn't be exciting frequencies that fit between those side walls, there is enough energy presumably from the radiated sound from the midranges to excite them. In essence I'd created half a box with now two parallel vertical walls and two parallel horizontal shelves. Then I moved them in a much more flared fashion as much as my space would allow and that seemed to improve that issue dramatically. Tonally there was no dramatic change though the extra bass headroom allowed me to set disco levels before excursion issues with the woofers. But it was not a universal win. In a nutshell, the more sidewalls I put on, the less air and openness I would experience from the sound. The inner walls' effect was relatively small but noticeable but the outer walls was much more dramatic, with the sound no longer "filling" space in the lateral directions. I tried them on and off numerous times with different sources of music and while it wasn't a blinded test, the difference was always there. I'm actually thinking the extra air I'm experiencing without the side walls is probably artificial and the out of phase dipole radiation is generating this extra ambience, and putting the side walls in place is partially neutralising that effect. Regardless, it unfortunately just didn't sound as good to me. It measured a lot better and required far less extreme DSP but just didn't sound as good. A fun experiment indeed but alas not an approach I'd consider a way forward by itself. One thing that I have learnt, though, is that perhaps that horizontal shelf which is parallel to the base shelf is doing more harm than I'd imagined. I've certainly seen most OB designs have a large vertical shaft instead of a horizontal shelf for reinforcement and this would seem to be a better approach. No need to reinvent the wheel if someone's already done the work before! 2 Link to post Share on other sites
Ittaku 4,461 Posted June 25, 2018 Author Share Posted June 25, 2018 29 minutes ago, davewantsmoore said: The my original question remains. How do you account for the dipole peak? We seem to be talking across each other. The DSP room correction applies to the entire frequency spectrum and nulls peaks and slightly boosts troughs. The nulling of peaks by the DSP room correction fixes the dipole peak. Link to post Share on other sites
davewantsmoore 6,549 Posted June 25, 2018 Share Posted June 25, 2018 I see. (Sorry for any confusion....where I am coming from is) I would want to EQ each driver individually, as the peak is different for each driver..... or perhaps not so much different seeing as they are on the same big rectangular baffle. Link to post Share on other sites
davewantsmoore 6,549 Posted June 25, 2018 Share Posted June 25, 2018 2 hours ago, Ittaku said: No need to reinvent the wheel if someone's already done the work before! The 'shelf' needs to be far enough away from the driver to no affect the radiation impedance too much (you can see this reflected in the electrical impedance if this is an issue). The shelf must not create any cavity resonances or reflections, this is related to wavelength size. ie. close surfaces are OK at low frequencies, but become a problem at higher frequencies. For mids operating up to ~4khz+ I'd want to have more clearance (and chamfer the back of those driver holes).... but it's not 'binary world'. Check the electrical impedance and acoustic measurements while moving the shelf around on a test mule is really the only way to see how big the effect is. 1 Link to post Share on other sites
Ittaku 4,461 Posted June 25, 2018 Author Share Posted June 25, 2018 8 minutes ago, davewantsmoore said: The 'shelf' needs to be far enough away from the driver to no affect the radiation impedance too much (you can see this reflected in the electrical impedance if this is an issue). The shelf must not create any cavity resonances or reflections, this is related to wavelength size. ie. close surfaces are OK at low frequencies, but become a problem at higher frequencies. For mids operating up to ~4khz+ I'd want to have more clearance (and chamfer the back of those driver holes).... but it's not 'binary world'. Check the electrical impedance and acoustic measurements while moving the shelf around on a test mule is really the only way to see how big the effect is. Thanks. These mids cross over at 2500Hz. Link to post Share on other sites
Nada 1,438 Posted June 25, 2018 Share Posted June 25, 2018 4 hours ago, Ittaku said: .... A fun experiment indeed but alas not an approach I'd consider a way forward .... Thanks for doing the experiment and writing it up. Interesting findings in terms of the sound. I wonder what happens if you stuff the U-baffles? You might still get the +5dB for free and lose the boxy sound? If you are thinking you might need two x13" for the dipole bass I wonder if you might do better leaping up to a single 18" driver? Or cross the subwoofer higher eg 60Hz? Cheers. Link to post Share on other sites
Ittaku 4,461 Posted June 25, 2018 Author Share Posted June 25, 2018 1 minute ago, Nada said: Thanks for doing the experiment and writing it up. Interesting findings in terms of the sound. I wonder what happens if you stuff the U-baffles? You might still get the +5dB for free and lose the boxy sound? If you are thinking you might need two x13" for the dipole bass I wonder if you might do better leaping up to a single 18" driver? Or cross the subwoofer higher eg 60Hz? Cheers. I've searched far and wide for drivers that I can use, those 13" are special drivers. 18" ones would sound terrible in this application without another driver between that and the midranges. Making 4 way passive crossovers is fraught with other problems. Stuffing the baffles will slowly start turning the speakers into boxes with acoustic suspension and lose the super critical damping the drivers currently have and introduce more group delay. I can cross the subwoofer higher, but why do that when I can add more drivers? The sound quality from the subwoofer is nowhere near that of the main drivers due to the quality of the driver and its amplification - I've tried all the way up to 80Hz and it just gets progressively worse sounding but more disco level sound pressure levels 1 Link to post Share on other sites
davewantsmoore 6,549 Posted June 25, 2018 Share Posted June 25, 2018 2 hours ago, Ittaku said: Thanks. These mids cross over at 2500Hz. Yes, so we care about what is happening with them up to at least ~4khz 1 Link to post Share on other sites
