Mike13
PS Audio vs Devialet
16 minutes ago, Sir Sanders Zingmore said:
Oops. My bad. Sorry Max
No problems Sir Sanders. These things are affected by so many factors! I'm actually questioning whether everything was right but the owner assured me it was a few years old (so its burnt in) and I personally checked that it was running Redcoud and left it on, so likstening on the second night, the DAC had been switched on for quite some time. I actually wanted/thought the DSJ would be up there with the rest of the DACs so I'm scratching my head after reading so many rave reviews. My only question is the screen said Redcloud 0.0.0 See attached photo. Can anyone advise if that all looks right and would give the improvement everyone says the latest firmware delivers? I work in IT so I know how to update firmware, and I did grab the latest release just incase there had been an incremental update, and tried loading the firmware but nothing happened. So I assume its up to date.
2 hours ago, Zaphod Beeblebrox said:
Wrong question.
The correct question is:
"Under what conditions did you listen and was it a proper double blind comparison?"
If it was not a DBT, then personal bias was likely the over-riding factor in the conclusion.
You are working on the basis that I had a preconceived perception on the Dev, which I did not. I only knew that I didn't want to listen to any gear that I could not afford because if it was so much better than what I could afford then I would want it and not be happy with my purchase.
Before you say well then you had a bias against any gear that you could not afford so subconsciously that is why you decided you didn't like the Dev or some other bs at roughly the same time I listened to the then way outside my budget Martin Logan 15a dipoles and as I have reported on this forum previously, I stopped listening to them after one and a half minutes or so because they sounded so very very good and again I knew that if I listened to much to them then I would never be happy with my speaker purchase. I listened to the Dev with a open mind and no bias and decided it was not for me, end of story.
Again I invite you to reflect on what you write Zaph and how you address people. It would be nice to read your very knowledgeable posts without it often coming across that your basically telling those who don't agree with you or whom you don't agree with how stupid or wrong they are, because that is how it comes across quite often.
regards Terry
Edited by TerryO
Guest scumbag
1 hour ago, Snoopy8 said:
Interesting thread, but heating up. Guys, please do not spoil it...
Sorry. Must go get another coffee.
and some more popcorn.....?
Guest scumbag
Mine reads:
"redcloud 3.5.1"
I and a few people who posted on the PS Audio forum had issues with the update. I had to do a roll back and try it a second time as the first went astray. I updated from Huron to Redcloud and it sounded like ASS the first time I updated, so I knew, without DBT that something was wrong.
So grab the image for the previous version and roll back to that then update to Redcloud again and don't forget to power cycle after each firmware flash. Once you've done that, check the Bridge firmware too as it may start to report that an update is available for that too.
Edited by scumbag
DBT
1 hour ago, Zaphod Beeblebrox said:
Although your question was highly impertinent, I will respond as best as I am able:
Double blind testing is, at present the best form of testing we have. In many areas, from pharmaceuticals to audio. An highly contentious claim was made. Such an extraordinary claim requires extraordinary evidence. A DBT would be suitable evidence.
FWIW: I've listened to several Devialet amps, under both sighted and blind conditions. They are, by any measure, exceptionally fine sounding products.
Completely Agreed. The Devialet 200 is really good value amp and it can be as good as many multi-boxes system that at a lot higher price if not beating them.
Devialet can sound bright when the synergy with the rest of system is not there, its a very revealing amp.
42 minutes ago, scumbag said:
Mine reads:
"redcloud 3.5.1"
I’m going to grab the DSJ and try that and report back early next week
I don't want to deviate from the OP's original question too much.
But if you are considering Devialet, may I also recommend looking at the new Micromega M One. I have had one for around 1 week  now, and I am very happy with the sound it produces, even a little astonished TBH. One of the main differences between it and the DEV is that it is class A/B architecture. The build and sound is really fantastic.
http://www.krispyaudio.com.au/products/Micromega-M%2dOne-integrated-amplifier.html
Guest scumbag
It looks even more like a set of scales than the Devialet. I like the Micromega stuff. It would be interesting to hear how it compares to the Dev'
Edited by scumbag
Lots of action on this thread. Look forward to catching up after work.
Absolutely, they nailed it from that angle, if it was on the floor you would be tempted to stand on it.
it sounds really nice, though, I have heard a few devialets  and wasn’t enamoured of their sound sig. I do like the sound of the m one though, it manages organic with good detail resolution and very good imaging. Quite surprising given the 100 watt rating and size of it.
Edited by Ray H
On 10/05/2018 at 1:57 PM, scumbag said:
The Giesler Grob DAC is worth having a listen to. It might also get you that Preamp functionality that you need. You'll then need a device to stream to it unless you use a PC or MAC. More $$$$$
I demoed it but couldn’t hear a huge difference between it and my Bluesound Node. It makes me wonder about my 2Qute vs Bluesound. I’ll do this test.
I heard this M one box, I didn’t like how it’s sounded. But it’s only me.
19 hours ago, scumbag said:
Sounds like the DSJ was on Huron. Red Cloud is / was a massive jump.
I don’t understand why a company would release a product that isn’t ready at the time of release. If a firmware upgrade makes a massive jump shouldn’t they have held off on the release?
I used to own a Meitner MA1 Dac and in the few years I owned it there was only one upgrade. They got it right at the time of release.
Edited by PKay
Thanks for the detailed feedback, very enlightening !
Guest scumbag
They did have it right at launch. But now they have it righter.
Too right.
I’ve read about this issue as well, look forward to finding out if this makes an improvement  to the dac for you
Looks good and I like the room correction option because I don’t think the Devialet would know my speakers. Would have to work with Tidal or Roon though. Does it upsample? I think the other two do. Not half the price of the Dev, almost the same.
How does it compare to the Devialet? Did you do a comparison?
Edited by Mike13
The world’s best amp doesn’t do speaker or room optimisation, I suggest you get the chance to listen to both.
No need to thanks me, it wasn’t for you anyway.
I just found i pointless to argue here the best way is suggest the OP few options and let him go and try to listen to it.
If I have to say I think Devialet sound more detailed and less coloured sound to me.
I’m not entirely sure if it upsamples to be honest, I know it has a 32 bit dac and does dsd. The dac stage sounded a little laid back initially, but is sounding better and better as it runs in.
i have not heard the Devialet and the m one side by side, but owned a dev 120 for a while. Personally I find the m one listenable, whereas I did not like the tone of the dev, I found it processed sounding and it did not last long in my system. I’m sure they can sound very nice in the right system though, different models and software versions affecting the sound quality. Admittedly the m one is a dev copy, but totally different implementation, architecture and outcome. The room correction is an extra on the m one also.
The m one is not currently a Roon endpoint, but can work via Bluetooth apparently.
Ultimately it would be of benefit to hear them side by side, but that would be difficult I expect, as I don’t know of any dealers that sell both.
Good luck with your search, nice products you are looking at.
No Offend, but it’s really a joke if anyone think the M-One is better than Devialet. If you do some study on the power supply unit that Devialet did in the Expert and compare to the one in M-One, M-One is a joke, especially the PSU in Expert Pro series probably one of the best SMPS PSU. And then you learn how important PSU is for all amps especially amps contains class d component. The M-One is by far worse than Devialet.
Guest scumbag
9 minutes ago, everydayIs25 said:
No Offend, but it’s really a joke if anyone think the M-One is better than Devialet. If you do some study on the power supply unit that Devialet did in the Expert and compare to the one in M-One, M-One is a joke, especially the PSU in Expert Pro serious probably one of the best SMPS PSU.
Apparently not everyone gets the "joke". These were totally fooled and thought the power supply was for real:
And what part of the power supply strikes you are a joke?
http://www.micromega.com/downloads/white-paper-UK-v2.pdf
http://www.powerelectronics.com/power-management/resonant-power-supply-suits-audio-systems
Edited by scumbag
Having owned a Devialet Expert 200 for some time and learning quite a bit about it I think it is difficult to question the technology and innovative thinking that has gone into this product. The specs are amazing! and I am very impressed by them.
The thing that replaced it has worse specs yet I prefer it. Not straight forward this audio stuff me thinks!
    • By RAF13
      Price: $3900 Item Condition: Excellent 9/10 Shipping Options: Pickup is available,Audition is not available, but in-person pickup can be arranged with limited personal contact Suburb or Town: Perth State: Western Australia Payment Method: Paypal (+ Fees or F&F), Bank Deposit, Cash on Pickup. Reason for selling: NLR Further information:
      These amplifiers have hardly been used and are in excellent condition, they have sat on a rack then they have been sitting in the spare bedroom carefully boxed from an interstate move. Unfortunately moving into a smaller house means these amps will not get used, so they’re looking for a new home!
      Comes complete with all original factory accessories and packaging.
      Current RRP $4995.00
      Enjoy an unheard of level of control and command from your loudspeakers with the Stellar™ M700, one of the most extraordinary under $5,000 power amplifier pair ever crafted. The M700 combines the slam, linearity, control and pacing of a Class D output stage with the warmth, grace, and rich inner detail of Stellar’s Class A Analog Cell. The results are nothing short of breath-taking. Liberate all the toe-tapping energy trapped in your media library. Plumb music’s subterranean depths as your system gives you more bottom end than you thought possible. Revel in rich layers of fine, full detail. Marvel at the deep, extraordinary, wall-to-wall soundstage. Control your loudspeakers as never before. Effortless. Lush. Stellar.
      The problems faced when crafting a new power amplifier are many—delivering sufficient power, control, frequency extension, and dynamics while maintaining a perfectly layered soundstage under the most complex musical passages.
      All amplifiers sound different. What determines sound quality are the components and topologies of the amp’s input voltage stage and output current stage. Each section should complement the other. Between them, the amp develops its sound.
      Stellar’s design imperatives—affordable pricing, uncompromised sonics—were major challenges solved by the invention of a unique new circuit christened the Analog Cell™.
      Stellar engineer Darren Myers had planned from the outset to take advantage of Class D’s high current, low distortion, ruler flat linearity for the output stage—knowing full well it is the input stage that determines sonic character. This critical interface between preamplifier and power amplifier is where Stellar’s magic would be unveiled; where Myers could lavish upon the music the sweet, tube-like quality of Class A biased MOSFETs. His challenge was to synergistically marry both input and output topologies, for which he invented Stellar’s Analog Cell.
      The Analog Cell is the heart of the M700’s musicality, where richly overlayed layers of music’s inner details are preserved even in the most complex orchestral crescendos. The Analog Cell is a proprietary, fully differential, zero feedback, discrete, Class A MOSFET circuit, hand-tuned to capture the smallest micro dynamics without sacrificing the loudest macro dynamics music has to offer.
      Features
      Mono power amplifier pair
      Zero-loss Analog Cell input stage
      Powerful MOSFET balanced output stage
      RCA Single ended input
      XLR “true” balanced input
      350 watts into 8Ω
      700 watts rms into 4Ω
      2Ω stable
      Less than 0.1% thd 20Hz to 20kHz at rated power
      Damping factor 1100 for excellent loudspeaker control
      Front panel standby button
      Efficient operation with very little heat
      Dual, solid copper, plated, output binding posts
      27 pounds
      Input 12-volt trigger
      Prefer local pick-up, but happy to pack ready for shipping. Buyer to arrange their own preferred courier.
    • By RAF13
      Item: PS Audio Stellar M700 Monoblock Power Amplifiers (Pair)
      Price: $4200.00
      Payment Method: Pickup - Cash, Paypal(+3%), COD Only.
      Features
      350 watts into 8Ω
      2Ω stable
      27 pounds
    • By Luke Murphy
      Item: Devialet Gold Phantom will tree pod wood stand
      Price: $3300
      Item Condition: great
      Reason for selling: upgrading
      Extra Info: bought about 7 month ago fantastic condition. Will come with bic and recipt
    • By Mpr_65
      Item: PS Audio Stella Gain Cell DAC - pre amp
      Price: 1400
      Reason for selling: Upgrading.
      Extra Info:  Very versatile pre amp from renowned manufacturers PS Audio USA.
                            Numerous digital and analog inputs and single ended and balanced output. See photos.
                            Can be used as a stand alone dac or full pre amp with the well regarded Gain Cell volume control.
                             A little over 2 years old and in excellent condition with no marks dings scratches or blemishes.
                             Purchased locally for $2500. Receipt and original packaging, instructions and box provided.
                             A clear step up when used as a dac with a Bluesound Node 2.
                             Functioning perfectly with a user friendly remote and interface. It’s a very clever piece of gear.
      Reviews
      http://v2.stereotimes.com/post/ps-audio-stellar-gain-cell-dac-preamp
      https://www.dailyaudiophile.com/ps-audio-stellar-gain-cell-dac-review/
    • By Audionerd
      Item: PS Audio P300 Fully Balanced AC Power Regenerator, MultiWave II Version with 3 Euro outlets and power leads
      Price: $750
      Reason for selling: Selling for a friend who is quitting high end audiophilia
      Payment Method: Cash, Bank Transfer or Paypal
      Extra Info: Comes with original double cartons for safe transport at buyer's expense if necessary, plus 1.5m Golden Sunrise power lead from high end German manufacturer HB Cable Design. I can't find RRP for this lead, but it's a heavy duty higher model with gold-plated Euro plug that would probably sell for over $500 (see photo and check their website). The most critical component would clearly be connected to this power lead.
      Two more standard power leads with Euro plugs are also included, so all 3 outlets can be used immediately. The original input power lead is supplied with multi-pin adaptor, or a 3-pin AUS plug could easily be fitted.
