I’m thinking my next upgrade could be either a PS Audio DirectStream Junior or a Devialet 200.
Both mean I could sell my Chord 2Qute DAC and my Bluesound Node 2 streamer. Devialet means I could also sell my amps.
I listen to only Tidal (and a few tracks from a Synology NAS). PS does MQA full unfold.
Can anyone provide some advice on this or comparisons? Thanks
I'm totally biased but for the money (around 5k used) its hard to beat a D200. It does pretty much everything. Just try one at home in your own system, if you like the sound buy it and be done with it!
If you really want MQA just use Roon & Tidal into the Dev.
Well that’s a good idea wikee.
19 minutes ago, Sir Sanders Zingmore said:
Nice !
I have a devialet 120 which, depending on where you are located, I may be able to bring over for you to listen to
The other advantage of the devialet is that it doesn't break your back whenever you want to move it. I auditioned a Vitus and in my space it would have been a nightmare to move.
At that price range they sell really quickly although they are great value given that you have an integrated amp and dac.
39 minutes ago, Sir Sanders Zingmore said:
Nice !
Thanks for the offer, I’m in West Melb :) I work with the guy who borrowed your amp... was going to listen to his speakers last weekend but he cancelled on me!
True. Easy to move around compared to a pre, monos, DAC, source and a lot of cords.
Has any one also heard the PS Audio DirectStream Junior, or even senior?
Perhaps sanity prevailed and he decided to keep his amps. If it was the Wilson amps they were very cheap.
Aah I know the connection now!
@scumbag had a Devialet and he uses a PS Audio Jr now.
From what I have heard the Jr is close to "Sr".
Devialet is a swiss knife, PS Audio is a dac, streamer (and pre?)
Ask the maker of the speakers what he thinks
But listen first before you buy.
Thanks good advice as always
@scumbag I’d be interested in your view
6 hours ago, everydayIs25 said:
I like Devialet more.
Can you explain why it’s better? You’ve owned both?
Two very different beasts. Putting aside the fact that the Dev' is a combined DAC / Pre and amplifier and the DSJ is only a DAC / Preamp* - they both present things very differently.
The sound of the DSJ is probably more aimed at a mature audience. I think the guys that listen and make decisions on the PS Audio gear are going for a more refined and relaxed sound, in general. That's my opinion of course. The Dev' is very detailed, dynamic and has lots of grunt - that can be either the best or worst thing about them! Here's a parallel that might help. I think the Dev' sound (the expert not the pro which I have not heard) is a bit like the XMOS U208 chip sound - very vibrant but it does sound like there is a "V" in the response - almost like a permanent loudness control. The later versions of the firmware even sounded like some sort of compression was being applied - I ended up running one of the older versions to get around that. The PS Audio was pitted against Clay Gieseler's GroB DAC. I couldn't pick the 2 apart. So if you've heard the GroB then, in my experience, you've heard something like the DSJ on the current firmware (Red Cloud). I can listen to the DSJ for hours. I know that people have commented that they find the DSJ a tiny bit "white" or blanched but if you set it up right you can get some great sounds out if. Power cables and filtering make a big difference.
*The DSJ will work as a preamp. The DSJ and DS attenuate in the digital domain.  They up-sample music to a high bitrate to reduce decimation of the signal as volume is lowered. But of course, at some point they will start to degrade the signal at lower volume levels. Also related to their duties as a preamp - I personally, hand on heart wouldn't recommend a DSJ as a preamp based on my experience with my Pass Labs XA30.8 power amp'. In addition to the issue I mentioned above, there is the issue of random low level noise and the issue of simply not having a sufficiently grunty output stage to really make a power amp' sing.
The Pass driven directly by the DSJ sounded thin and not terribly musical. Just my opinion and experience. So a good / decent preamp would be recommended. I am having fun with a PS Audio BHK preamp at the moment but I got great results with a W4S STP-SE preamp too - not as "big" or clear a sound as the BHK but lots of grunt.
Anyway, the DSJ is a keeper. The Dev' wasn't ;)
Edited by scumbag
Thanks @scumbag, I did try the Grob, can’t say I could tell an immediate difference. I probably needed more time with it.
I think I do like the V shape sound, not sure. I don’t use an EQ when listening to headphones.
Interesting that the Dev can sound compressed. I thought that upsampling did the opposite and enabled more clarity.
Compressed? Hmm, never experienced that issue...
Anyway, ultimately doesn't matter what any of us think. Just get one and try it at home, only way you'll know.
Thanks [mention=151841]scumbag[/mention], I did try the Grob, can’t say I could tell an immediate difference. I probably needed more time with it.
It’s my first time hear somebody said sound like Compressed... interesting.
It’s hard to say Dev better or PS Audio, as a system need to match each other and the room. Dev can sound bad with some speakers, PS can sound bad with some speakers.
My experience Devialet sound extremely well in a proper set up. The GT1 is one great example. It’s hard to find something to beat it at its price point. If you go multiboxes, you need to make sure they are all match.
When it comes to digital the Devialet is well worth an audition especially if you can pick one up cheaply. It is a Dac and a very useful integrated amp. Once you get into mid level digital they are mostly very good.
I think Trevor kindly offered to let you listen to his 120. You should take him up on the offer and let us know what you think.
Having met someone in Saigon who has several million dollars worth of equipment, with Devialet, PS Audio, McIntosh, Krell Amps and Preamps, Magico and Genesis Speakers, Audio Note and Expressimo TTs, a rack of CD players and DACs and it really gets down to you listening to as much as possible with the music you like also your age will have a bearing due to the deterioration your hearing has as you age.
The system I preferred in amongst his multitude of gear was one of his cheaper setups, which included a Devialet ? 200 Amp, Marantz KI CD and Harbeth HL5 speakers.
So from my personal experience, yes Devialet was the best amp in that environment to me with that source and speakers, so you have to get out and listen yourself as every system, setting and individual is different.
Just my $0.02
When trying out a number of amps last year the salesman kept pushing me to try a demo first model Dev 200. So after listening to several other amps I decided to give it a try. I actually found it very uninspiring and almost withdrawn and weak sounding, so much so that I wondered what all the fuss was about.
I can't comment on the PS Audio but I can say I won't be rushing out to buy a Dev anytime soon. No offence is meant to Dev owners.
cheers Terry
Edited by TerryO
    • By DocD
      Item: PS Audio BHK Signature 250 Stereo Amplifier
      Price: 7000
      Item Condition: Excellent
      Reason for selling: Using it for driving Abyss headphones - want to get a dedicated headphone amp as my usage probably does not need this much power.
      Extra Info: Upgraded the fuses to the highly regarded Synergistic Research Black fuses - that’s >$600 worth and improved the already excellent amp even more.
      Have the original double boxes.
      I am the second owner - bought via an Authorised
      dealer in Perth.
    • By frednork
      Item: Devialet Expert 200
      Price: $5000
      Item Condition: Excellent except for some marks around the buttons on the remote which were there when i got it. All working perfectly
      Reason for selling: Wouldnt want to die wondering
      Payment Method: Pickup - Cash, Paypal, COD Only Can post , will cost around $100-130 insured
      Extra Info:  It is complete with packaging, remote and all the bits. The remaining 26 months of warranty will be transferred once purchased. Have really enjoyed my time with this unit, the thing I miss already is just picking up the ipad and choosing a song on Roon. The Dev automatically starts up and starts playing music. Then when it is finished, it turns itself off again.  Oh, and it sounds good too!
      Pictures: Realised I am a good dust photographer so have included some stock pics also. (I cant even see the bloody dust!!)
    • By SteveC
      Item:  2 x Devialet Phantom Silver (RRP $7,180) + Dialog (RRP $499) + Remote (RRP$249) + 2 x White Tree stands (RRP $1198) Total RRP $9,928
      Price:  $5,950
      Reason for selling: Upgraded and back on the merry go round.
      Extra Info:  Collection preferred at this stage. Purchased locally in Feb 2016, includes all original boxes, cables accessories etc.
      This is an emotional sale as I really enjoyed these speakers and I did not upgrade anything in my system for the past 2 years! Prior to that was a different story.
      Now just about every store I have seen them in stick a single Phantom in the corner somewhere and get people to Spotify to it. Yes you can use it that way but that does not bring out the best in them. I honestly preferred these over the Active LS50s. They are known for their bass but if you feed them properly and bring them out a bit like I did then it is not overblown. Their optical inputs are 24/192 and the Spark software (highest quality option in my opinion) can be loaded on your MAC/PC and with an app you can play your music via wifi. Also can do Spotify Connect, Bluetooth and Tidal is in the Spark app. Also has Internet Radio.
      The stands a very rigid and the speakers are locked in to them so there is no vibration. Also all cables are run through the middle, very neat solution.
      The remote is the nicest volume control I have ever used. Sit on your sofa and turn the dial. No comparison to using buttons.
      I had a little RPi with optical out connected to them for Roon use.
      Also had the Oppo digital out for TV/movies. With the 2 Phantoms and the Dialog you effectively have 3 inputs.
      I think you could also enjoy them near-field in a smaller room as they are easy to position.
      They are real all rounders and  just a pleasure to listen to. They are too good to put in the second room with the kids, rather someone appreciate them.
      https://www.devialet.com/en-au/buy-silver-phantom/
      https://www.devialet.com/en-au/accessories-phantom-tree/
      https://www.devialet.com/en-au/accessories-phantom-dialog/
      https://www.devialet.com/en-au/accessories-phantom-remote/
    • By Black Label
      Item: PS Audio LANRover USB Transporter
      Price: $450 ONO
      Item Condition: Excellent, however with no original packaging
      100% functional condition. 95% cosmetic condition, there being some slight marking to the mirrored labels from wiping away dust.
      Reason for selling: Purchased a Sonore Rendu
      Payment Method: Pickup preferred but could easily post Australia wide - Cash, Paypal, COD Only
      Extra Info: I purchased this device in late December 2017 from Mike Leneham and used it between a MacMini and Oppo 105D. To be honest I can't give an accurate portrayal of it's direct effect on my system as at the same time I also introduced an Isotek power conditioner & cables, a Nordost USB cable, and the aforementioned MacMini as a dedicated Audirvana server. Combined however they were a most positive development
      Anyway, as discussed in this REVIEW the LANRover provides the following:
      Regenerates, cleans, and reclocks USB audio data Galvanically isolates DAC from computer or music server Buffers and retimes audio data irrespective of computer or server Removes any need for separating 5V from USB cable Eliminates computer jitter Removes computer digital and power supply noise Increases possible distance between computer and DAC from a maximum of 5 meters to 100 meters Works over home LAN router Place computer or music server in one room and DAC in any other Dramatically enhances sound quality of USB audio Works with PCM or DSD audio PCM to 352kHz, single or double rate DSD Requires no additional software Works with any installed USB driver Windows, Linux and Mac compatible
      Thanks for looking!
    • By Dhillon
      Item:  PS AUDIO POWER PLANT P300
      Price: $500
      Item Condition: Good
      Reason for selling: upgraded
      Payment Method: Pickup - Cash (very heavy, pickup at this stage)
      Purchased off another SNA member about 2 years ago. This unit is in very good condition with a few minor marks for its age.
      This is a power regenerator. The unit can output a pure sine wave or numerous options / other PS Audio designer delights. In addition, output voltage can be set anywhere between 220 - 240 volts which is quite handy in the Australian context. Finally, you can vary the frequency as well from 50 - 120 Hz. Power rated 300W, good for preamp / DAC etc. Note that it has US plug outlets.
      It weighs 16 kilos so I would prefer pick up as postage will be expensive.
      US plug, box included (as photos)
