o2so
SOLD: Relist - another price drop! Auralic Merak Monoblock Balanced Power Amplifiers
Item: Auralic Merak Monoblock Balanced Power Amplifiers 200W/400W
Price: $2,250  2,100 plus postage for both
Item Condition: 8/10 (a couple of minor cosmetic marks on top plates, front plates and sides are perfect)
Reason for selling: Freeing up some cash as moving house soon
Payment Method: Cash on Pickup, otherwise Paypal, COD Only
I had initially listed these as a package deal with my Auralic Taurus Pre Preamp, but have now decided to relist individually (Mark OKd this).
These were purchased from Addicted to Audio about 5 months ago. They were floor stock and I paid them 2,800 bucks, however the price new was north of $6,500!
They work flawlessly and produce a really incredible sound, which I would describe as powerful, precise, elegant and neutral, but far from col or clinical.
Each Monoblock is rated at 200W in 8ohm and 400W in 4ohm (continuous power). Both are fully balanced. They incorporate an innovative hybrid design (half way between class A and D, at least this is my understanding), in which the advantages of class D amplifiers (small size, efficiency, zero heating) are paired with those of class A/B amps (high energy storage, massive power supply, and great control on all speaker types, including difficult loads). Each mono block has a linear power supply and 56,000uF capacitors array and can store up to 120J of energy, while remaining 90% efficient. This means they run stone cold even with low impedance speakers at high volumes.
Each Monoblock has a circuit (which can be bypassed) that switches the amp on or off when a very low input signal is detected (or not detected), while keeping the output stage on at all times. This results in the amps being always ready to sound at their best (no need for any warm up time), while consuming virtually no energy when at idle.
These have only balanced line in, and each of them has a low level line out that is controlled from the preamp and can be used to send the signal to active subs or more amplifiers.
The exceptional quality of these mono blocks is confirmed in several reviews, including on SNA, where they were tested with the matching Taurus Preamp (that I am also selling separately). Here are some examples:
http://www.theabsolutesound.co...c-merak-mono-power-amplifiers/
http://www.6moons.com/audioreviews/auralic3/1.html
https://www.stereo.net.au/reviews/auralic-taurus-and-merak-pre-power-combination/
Specs and user manual here:
http://www.auralic.com/download/MERAK_USERSGUIDE_R1.pdf
Specifications
Continuous Output Power;  200W/400W (8ohm/4ohm)
Peak Current Output:  >16 amp (40 ms)
Frequency Response:  20Hz - 20KHz, +/- 0.5dB
THD+N:  <0.01%, 20Hz-20KHz@1W
IMD:  <0.01%, 20Hz-20KHz@1W
Residual Noise:  <50uV, 20Hz-20KHz, A-weighted
Input Ports:  1 x XLR, Sensitivity: 2.2Vrms(RCA input requires adapter)
Input Impedance;  10K Ohm
Output Ports:  1 x XLR invert output ( for BTL mode)
1 x Cardas patented CE binding post
Damping Factors;  >800, 8ohm@1Khz
Optimized Loads:  2ohm to 16 ohm
Power dissipation:  warm-up mode: 5W
playback mode: 15W/450W (idle/max. output)
Dimension:  330W x 330D x 70H
Weight:  8.5kg
I purchased them to drive my Magnepans 1.7, a notoriously very demanding speaker, which they did beautifully. I have now sold the Magnepans and do not require these anymore, plus I am moving to a larger house and I need to cover some extra expenses.
The original boxes are missing but given the small size, contained weight and simple shape these can be packed up professionally and safely posted
Edited by o2so
price drop!
39 minutes ago, Randle said:
I don't need them, but I'm trying to think about a reason I could need them. Beautiful!
There is always a reason to need new gear :)
Preamp now sold, monoblocks still available
I reduced price AGAIN and this is starting to be a lil silly price.
I am selling a pair of new generation, great sounding monoblocks that retail for over $6,500. They have received raving reviews pretty much everywhere, will drive any speakers including planar speakers, are compact, beautiful and energy efficient. All of this of just over 2 grand.
Second hand gear, even when relatively new, goes for about 50% of the retail price on SNA. I am selling these for LESS THAN 1/3rd OF THE RETAIL PRICE.
Cmon guys, if you are in the market for a power amp I believe this is the best deal that is currently on. By far.
I agree on this one. Beautifull to look at. No idea on how they sound. If i had a pre amp this will be on my list
FWIW I have had luck selling the more left of centre stuff on Audiogon. These Amps are light and easy to ship (and I am guessing not hard to convert to 110) so it might be worth your while.
The speaker binding post looks unique. How is it to be connected to typical loudspeaker? Does it require special type of cables?
No, they are designed to accommodate spades or bare wire. These are Cardas binding posts and all reviews praise the choice of Auralic of using these posts because they are supposedly better than standard binding posts. They are not great for bananas, but they do work with bananas too.
From Tone Publications:
I must give AURALiC kudos for including Cardas CE binding posts with the amps. Clamping a single knob down onto a tough plastic bracket holds my speaker cable’s spade terminations against the posts. And it’s so easy to get a good finger hold on the knob that I don’t need a post wrench (or a kung-fu grip) to get a tight cable connection
Nope....
1 minute ago, aasza said:
Nope....
Thank you. Understood now how it works. :)
and more from Tone Publications:
the MERAKs strike a fantastic balance of timbral and tonal accuracy, major dynamic slam and a complete lack of fatigue.  Putting them through their paces with the KEF Blades, the Focal Maestro Utopias and the Dynaudio Evidence Platinum speakers proved the $5,000 US pair of AURALiC amplifiers were not out of place in a six figure system.
Hey, I am happy with any trusted members based in Sydney (or close enough to drive to Sydney) to take these home and give them a go in their system for three days or so. I am pretty sure the first one who tries these out will buy them, but I understand that many may have never had a chance to audition them.
Still FS? Most def keen. How much the bundle with the Taurus, too?
@mjth Sorry to tell you this
Hey mate, I only have the Monoblocks left. They are easy to drive with any preamp, I am currently listening to them fed by a simple DSPeaker Antimode Duel Core, which is a digital equaliser more than a preamp, and they sound great. PM me to discuss if interested.
Edited by o2so
These are still available. @mjth has released that he is actually after tubes.
You got me all MExcited about the ME750 you bought recently, so I have now committed to an ME850 (at around the same price as your monoblocks).
Otherwise, it would have been excellent to run your (former) 1.7 Maggies.
Best of luck with the sale. At that low/ bargain price, those amps should sell themselves.
I bought that ME with the long term view to downgrade and free up some money, which I will need soon as we are moving to a larger place. Hopefully someone will pick up this bargain and get the Meraks off me soon. I will miss them but I need the cash to buy a scooter to ride to work as I will be too far from train station!
Edited by o2so
still available. Now also on Audiogon...
    • By Mikety
      Item: Auralic MERAK monoblocs
      Price: $1950 plus postage if required
      Item Condition: excellent
      Reason for selling: time to change
      Payment Method: Pickup - Cash, Paypal + fee, Bank transfer
      Heaps of good review online, no original packaging but can pack securely to post.
    • By Vladas
      Item:
      MASTERSOUND INTEGRATED TUBE AMPLIFIER BOX R
      Parallel Single Ended in "Class A" Integrated - Made in Italy
      Power: 2 x 35 Watt
      Tubes complement: 2 x ECC802 - 6 x EL34
      Input: 3 line + Phono MM
      Output: 1 line
      Load imped.: 4-8 ohm
      Bandwidth: 18 hz / 25 khz 0 db
      Output Transformer: MastersounD
      Automatic Bias
      Supplied with remote control - R version
      Negative feedback: 0 db
      Dimensions: 43,6 x 40,9 x 18,5 cm
      Weight: 24 Kg
      Made in Italy
      Price:  $3000 (RRP - $5200)
      Item Condition: Brand New - still in the box
      Reason for selling: Change of financial situation
      Pure Class A  2x35 Watt PSET (Parallel Set) which is used in the very high end tube
      amplifiers like Aries Cerat $30K USD. This gives you uncompromising power to run in pure class A almost any 89+ db speakers.  Lack of power is Achilles weak spot of most tube amplifiers and I believe PSET is the best solution used by the very high end manufacturers. Legendary Mastersound brand - makes PF100 tube amplifier $50K USD. Fabulous musical EL34 tubes. To my knowledge, this model is absolutely the best value for integrated tube amplifier in that price range; made in Italy but priced similarly to comparable Chinese models. Includes very good phono pre-amplifier - same as in the flagship models.  This is Box R version with remote control (cost $330 AUD extra).
      Links below shows additional information about The Box and Mastersound brand in general:
      http://www.mastersoundsas.it/1/reviews_4451773.html
      https://soundapproach.com/mastersound-box-r-integrated-amplifier-class-a.html
      https://www.technologyfactory.eu/en/mastersound/integrated-amplifiers/mastersound-box/a-5384-10000401
      https://forum.audiogon.com/discussions/axpona-2018-integrated-mastersond-box
    • By alexb
      Item: Little Dot Mk II Headphone Amplifier
      Price: $SOLD
      Item Condition: Mint
      Reason for selling: Selling head-fi rig
      Payment Method: Pickup, EFT, Cash, Paypal (buyer pays all transaction fees & postage)
      Great condition and one of the best value headphone amplifiers available. Australian variant with 220v power supply. Upgraded Value Electronic CV4010 KQDD/K and 6H6 VIII tubes.
      The device has a single volume knob on the front along with a blue LED and of course, the 6.3mm port. At the back you can find the input and output RCA pots as well as the power button. The specifications of the amp are as follows:
      Input: Gold-Plated Unbalanced Phono (RCA) Jacks Output: 1/4" Gold-Plated Stereo Headphone out Driver Tubes: 6JI Power Tubes: 6N6 Frequency Response: 20HZ - 50KHz (-1dB) THD+N: 0.1% (50mW into 300 ohms) Suitable Headphone Impedance: 32 - 600 ohms Pre-Amplifier Output Impedance: 10K ohms Power Output: 300mW into 300 ohms 200mW into 120 ohms 100mW into 32 ohms Average Power Usage: 28 watts Dimensions: 210mm (length) by 110mm (width) by 130mm (height) Weight: 2.5 kg or 5.5 lbs.
      The Little Dot MK II boasts a SEPP (single ended push pull) circuit (in similar vein to the rest of the MK-series tube amplifiers) greatly increases sound quality, dynamic range, output impedance, and harmonic distortion. The Little Dot MK II also provides gain control of 3, 5, and 10 via internal DIP switches for fine-tuning so you can maximize synergy with almost any headphone you have, whether it be 32 ohms or 600.
      Some cheap tube amps have what is called a hybrid design, where the power is provided by a transistor based circuit and the driver circuitry is tube based. Examples of these designs are the headphone amps with only a single vacuum tube (the driver tube). Not only does the Little Dot MK II have a fully tube based design (both power and driver elements are tube based) it actually has independent circuitry for the left and right channels.
      So essentially, you have 1 power tube and 1 driver tube for the left channel and 1 power tube and 1 driver tube for the right channel. This is called an SEPP design (think of it as 2 + 2 design).
    • By Raffinator
      Item: Vincent Audio SP-T700 Monoblock Amps (silver)
      Price: $2,200 pair
      Item Condition: Very good. 2 years old
      Reason for selling: NLR
      Extra Info: For sale are my pair of Vincent Audio SP-T700 Hybrid Monoblock amplifiers in silver. I am the original owner, and they are 2 years old. Selling due to a change of configuration.
      See https://www.vincent-tac.de/en/product-lines/tubeline/sp-t700.html for full details.
      See https://funaudio.com.au/brands/vincent/ for link to current importer.
      I have the original boxes in good condition, and I'm willing to ship at the buyer's expense. 16kg each in two cartons.
    • By NADbooffa
      Hi all,
      The current setup is NAIM Nait driving two B&W CM9 floorstanders  and NAD T762 (soon to be replaced) driving the center and surrounds ( B&W)
      Oppo 105D being used as a pre amp, connected to NAIM via balanced o/p for music (CD, SACD, Bluray etc)
      Need a streamer to be used with NAIM ( maybe via 105D )
      Thinking about getting an Auralic Aries or NAD C658 (with Dirac) as the streamer.
      Leaning more towards the C658 as Auralic don't have much of a presence here in Oz? ( for after sales issues)
      What are your thoughts?
      Cheers.
