SmokinJoe
Integrated amp pairing with a preamp and/or power amp
HI all
I recently purchased a Rega Elex R integrated amp. I am really happy with the sound but would like to experiment with a tube pre- or power amp.
My question is does anyone know if I can:
1 - Add a tube power amp to the pre-amp output and use the Elex R as a pre-amp only
2 - Feed a tube pre-amp into one of the Line-in jacks and use the Elex R as a power amp only. If so does this bypass the Elex R pre-amp.
I've added a photo below. Grateful for any advice.
8 minutes ago, SmokinJoe said:
HI all
Yes.
Yes.
No.
You're most welcome.
you need the elicit-r I think with ht bypass to use just as a power amp :)
9 minutes ago, Zaphod Beeblebrox said:
Yes.
Yes.
No.
Thanks Zaphod. I am a big fan of precise and efficient advice.
One more question on point 3: is there a disadvantage if the tube pre-amp and Elex R pre-amp run in series before hitting the Elex R power amp. That is, will the ambience added by the tube pre-amp be flattened by the Elex R pre-amp?
Hi al
I did like the Elicit. Does that meant the ht bypass separates the pre-amp and power amp in the Elicit?
2 minutes ago, SmokinJoe said:
Hi al
it does yes, whack in ht bypass and it works as a power amp. bypasses the pre amp stage :)
Hi mate maybe post what
tube pre/power amps you use and your findings?
i have an Elex-r that replaced a SE kt88 amp, i didnt want to admit it at first but the Rega sounds better to me. Alot more
punch/drive. The valve amp was a Tubelab design running big edcors, the only thing my valve amp did better was acoustic stuff and some but not all jazz.
The elex is a bloody good amp.
Totally agree. I had planned to get separate pre and power amps but I just didn't find a combination to beat the elexr near the price. Will let you know how I go with the tube amps.
Guest Eggcup The Daft
If using the Elex R preamp output, make sure the power amps match to it. I remember a thread from a couple of years ago, where the Rega Brio preamp output levels were too low for some power amps.
Thank Eggcup. I imagine the only way to test is to plug a power amp in?
Would I be right in assuming an ht bypass can't easily be retrofitted?
If you can find the relevant numbers for the output and input, ask a question in the amplifiers and pre-amps forum and I'm sure someone will quickly answer.
I guess it depends on what you are attempting to achieve.
If you are attempting to accurately recreate the original musical event as closely as possible (aka: High fidelity), then applying another preamp to the input of a preamp can only serve to DECREASE accuracy.
If, OTOH, you are trying to achieve something else (say: Stripping detail and important musical information from the signal), then placing another preamp in series with the existing one will probably do just that.
Depends on what you mean by "easily". Several holes need to be drilled in the chassis, sockets fitted and then the tech needs to figure out the best part of the circuit to break into. I'd reckon the cost would somewhere North of $200.00 for a decent job.
I would t suggest so. In my opinion. Given popularity of these units. You are better off to flog off and pick up the model up with the feature built in. Or better still just buy the power amp version if that’s all need.
modifying and getting the existing unit rigged up to do something wasn’t designed to do can be hit miss and also unpredictable what outcome will be for resale. Some won’t want to touch a modded thing. Some might pay extra, can be gamble in my opinion. When off shelf straight replacement options there for what you are looking to do :)
I'm pretty sure the Elex R preamp is passive.
I have tried that on half dozen different mid-fi integrated amps, some times the sound can appear better and others not.
The several times it worked with a better preamp the treble extension got more detailed, sweeter and more melodious. Other times when it did not work it got very muddled, something wasnt right, volume reduced etc. Ultimately though in most of those attempts using that quality of amp I later preferred dedicated power amps on the preamp.
If the amp has a passive or active volume pot it may work better by adding another preamp externally. There are power amps that have a simple volume pot and are meant to be connected to an external preamp, but can be used as is and sound quite good. In those situations adding a good external preamp can really make it sound very good and can control system background noise if it’s a problem.
Edited by Al.M
    • By stretch2002
      Item Condition: Excellent, a few small marks on top cover Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Canberra State: Australian Capital Territory Payment Method: Paypal, EFT Reason for selling: No longer required, getting into components. Further information: Price reduced.
      Great sounding British amp, 60W per channel into 8ohms.
      This model released in 2010. Recently serviced (this month), all tested OK.
      I love it, but am getting into separate components, and need to free up funds to upgrade!
    • By PKay
      Item Condition: Excellent Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Artarmon or Forestville State: New South Wales Payment Method: cash, EFT, Paypal as friend Reason for selling: Not used Further information:  I am selling this amp for my brother - it is in excellent codition with very little use. Postage is available as my brother has the original boxes but local pick up is preferred.  See 3rd picture for little mark which is hardly visible.
       Review from TNT
      There has always been an inherent rightness about the idea of an integrated amplifier. The efficiencies are impressive, the compromises mostly imagined. With the modern additions of display and a properly implemented remote control the integrated becomes all the more appealing. Now there are integrated and then there are integrateds: The sometimes classic (Naim) and sometimes overrated (fill in the blank) British offerings are not what I have in mind. For some reason, the Brits just don't seem to get the fact that an integrated needs real world power to be of real world use. Rotel is a company that knows how build high powered amplifiers, so when I found out that their flagship RA-1070 was said to be happy driving a tough 4 ohm load, I was quick to request a sample.
      The RA-1070 is the latest in a spate of offerings wherein the product's look and performance really threaten a redefining of the high end. There was a time when such a product would have cost well over $2000. While the old guard high end companies have product lines that continually reach higher and higher, the larger mid-level companies seem willing and able to supply more music for the dollar. It may be time to ask why...
      This is a very attractive piece of gear. My review sample is silver and black, but the 1070 can also be had in the more traditional all black. The faceplate of the unit is cleverly designed to suggest a more hefty look through the use of substantial black aluminum handles. In fact, the silver center section of the face is quite thin (as is the top cover) yet the unit looks and feels quite solid. A large motor-driven volume pot dominates the face. When operational, there's an illuminated section that indicates its relative rotational position. In an interesting nod to the days of tone & loudness controls, there's a four position contour control which allows for accentuation and attenuation of bass and treble. I left that control in the off position for all of the evaluation period. The rear panel is well laid out with proper 5-way binding posts situated near the center of the panel making it easy to connect even the most unwieldy cables. The usual IEC 320 connector is used, but in an odd twist, this Rotel floats the ground: This is very likely of no concern in typical use, but could be an issue in systems requiring a specific grounding scheme or extensive use of truly balanced devices.
      The RA-1070 uses a relay as a turn-on/off stabilization device and also as a protection device in case of overheating or shorted cables. The relay can be clearly heard when powering the unit up and down. With the exception of the speaker and contour control switches, all of the RA-1070's functions can be controlled by the superb remote. This is truly a wonderful remote...it can readily learn the remote codes for all of your other gear and allows you to use the Rotel remote to control an entire system. It is also possible to customize the unit's display to indicate associated equipment by specific name rather than type. The only negative that I should mention is that while it is possible to turn the somewhat bright display off, the unit isn't designed to remember that setting. So, the very next time the Rotel is turned on the display again needs to be turned off. This is a real shame as the display off setting is very well implemented. With the display in the off position, the display momentarily illuminates whenever a control is changed. Once the change is complete the display goes out. On a teeny-tiny but slightly tacky note: The motorized volume pot indicates that the RA-1070 is in mute by flashing its position indicator. While effective, I find this solution better suited to products of a lesser pedigree than Rotel.
      Sound
      The Rotel RA-1070 is a very suave sounding piece of gear. Right out of box it has a sound that is relaxed and assured. There are absolutely no hi-fi dramatics to this amp just a competent and musical presentation. The unit looks like it sounds like it functions...sensibly, controlled and without fanfare. The essential test of tone and timber that I like to use first is the Byron Janis. The piano is clear and open with a slightly soft presentation. It is less than muted but less authoritative than it should be. Overall tonality is quite good bordering on excellent. At well over 100 watts into 8 and 4 ohm loads, it sounds even more powerful in use than the ratings would indicate.
      Iris DeMent's voice is possessed of its usual plaintive clarity if again just slightly softened. There was no aspect of the voice's fundamental or attack that was lacking but rather a subtle sense of shading toward the warm and dark. Now, on the period strings of the Corelli, the sound was quite open and pure with an excellent sense of space and air. The guitars of Krushevo were also recreated with an appropriate portrayal of acoustic speed and timbre.
      It is sometimes possible to go too far in one direction and I felt that the Rotel RA-1070 was less prone to this softening when used with my usual digital reference rather than the also excellent RCD1070. It may be that my system's overall resolution requires just a bit more raw musical information that the Rotel combination can create. More than anything, this is likely to be a matter of personal preference and perhaps most importantly the room/system interface. In any event, I appreciate the RA-1070 more when using my reference digital rig and analog.
      Ah, analog
      I will rue the day that there are no more phono stages. One of the most appealing qualities of the Rotel RA-1070 is its lovely phono stage. It is really quite excellent. The Sonny Landreth pressing quickly reveals the essence of a phono stage. First of all, it is dead silent. A noisy phono stage will overlay a hum over the blackness of the virgin vinyl. The phono stage of the 1070 is fully capable of differentiating a good pressing from one made from old combs. The Landreth LP has some wild dynamic swings from cut to cut. The Rotel really handles the range with aplomb. In contrast to the linestage's less assertive style, the phono stage of the 1070 is incisive and full of verve.
      As I got the Rotel RA-1070 ready for the return trip to Rotel, I had to make my system ready for some fairly large, typically high end separates. I was miserable. Not only was I going to miss the functional simplicity of the Rotel and its remote I was already missing the elegance of having all of the voltage gain and current swing in one box. Here I was on my hands and knees looking for interconnects and power cords while trying to fit the new separates into the swollen component rack. There, on the floor, the Rotel RA-1070 was staring at me as if to say, there is an easier way!
      There's just no arguing the fact that using an integrated amplifier makes for a more simple system. What the Rotel RA-1070 proves is that such convenience does not have to come with an unbearable loss of musicality. The 1070 is comfortable with tough loads and very easy to listen to and there is just no way to complain about its design and functionality. Maybe someday I will retire from reviewing. When I do, it will hopefully be an easier and simpler time...a time, I hope, of music. When that day comes it would be a pleasure to spend my time listening to the Rotel RA-1070, the bother and hassle of separate components just a distant memory. Until then, I trust that you'll get out and try to hear the 1070. You may find that the simple life of the Rotel RA-1070 is for you. Highly recommended.
      © Copyright 2003 M. L. Gneier - https://www.tnt-audio.com
      HTML by: Andrea De Marco
      SPECS
      AUDIO
      Response Bandwidth 4 - 100000 Hz Signal-To-Noise Ratio 102 dB Total Harmonic Distortion 0.03 % AUDIO SYSTEM
      Type amplifier Subcategory audio components Functions amplifier Sound Output Mode stereo Additional Features A/B/A+B speaker switch Tone Control Yes POWER DEVICE
      Power Consumption Operational 400 Watt HEADER
      Brand Rotel Product Line Rotel Model RA-1070 Packaged Quantity 1 BUILT-IN DISPLAY
      Type fluorescent MISCELLANEOUS
      Color black Color Category black AMPLIFIER
      Input Impedance 33 KOhm Input Sensitivity 1.5 V AMPLIFIER OUTPUT DETAILS
      Output Power / Channel 100 Watt Output Impedance / Channel 8 Ohm Frequency Response 20 - 20000 Hz Total Harmonic Distortion (THD) 0.03 % Channel Type main Channel Qty 2 INPUTS & OUTPUTS
      Headphone Jack Yes REMOTE CONTROL
      Type universal remote control Remote Control Technology infrared ACCESSORIES
      Remote Control Type Universal remote control - infrared Features LCD display, learning AUDIO SPECIFICATIONS
      Type Amplifier Frequency Response 4 - 100000 Hz Signal-To-Noise Ratio 102 dB POWER
      Form Factor internal BATTERY / POWER
      Type power supply CONNECTIONS
      Qty 1, 2, 3, 4, 7 Type audio line-in, audio line-out, headphones, network, phono input, preamplifier out, remote control, speakers output, trigger Connector Type RCA x 2, RJ-45, banana/spade x 2, phone stereo 6.3 mm Connector Location front, rear DIMENSIONS & WEIGHT
      Width 16.9 in Depth 14.2 in Height 4.8 in Weight 22.71 lbs GENERAL
      Manufacturer Rotel of America
    • By Marc
      Item Condition: As new, with all packaging. Shipping Options: Pickup available but audition is not available.,Shipping is included in price. Suburb or Town: Sunbury State: Victoria Payment Method: Paypal (+fees), Cash on Pickup, EFT, Credit Card (+ fees) Reason for selling: Not a great match for JBL L100 Further information:  Selling my MA252 which has only been used for a few months, and then, maybe only half a dozen short times. It's as new, with all packaging and accessories.
      Although highly regarded, it just doesn't match up with the JBL L100 in my 2nd system. So I'm going try a few other amps to see what gels.
      Current RRP is $7,995. I can ship this via Couriers Please at buyers cost.
    • By EricL
      Item Condition: Mint condition (9/10) Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition. Suburb or Town: Greensborough State: Victoria Payment Method: Cash on Pickup, EFT, PayPal + 3% Reason for selling: NLR
      This is an award winning integrated amplifier from Denon with Australian power specifications. It is made in Japan.
      You can read the summary review: https://www.hifichoice.com/content/awards-2010-amplifiers-£1000
      The Denon catalogue also featured it as an award winning amp from EISA 2010-2011.
      It works beautifully and even has MM/MC phone stage.
      It can drive my Audio Technica MC flagship OC model AT-OC9XSL cartridge (0.4mV) and sounds great via my Paradigm Studio 20 speakers.
      It can be used as integrated amp, power amp and pre-amp. See photos for various setup in the manual.
      Specifications of the amp: Refer to photo.
      I bought in early 2011 (RRP - Around $1700) and used it for a year and then upgraded to Luxman amp.
      It has been sitting in the Hi fi room all this time.
      There are two very minor hairline scratches on the front. They are not noticeable unless you examine in close scrutiny. Please see photos.
      This amplifier is rather heavy -15.5kg so I prefer local pickup.
      It comes with the original manual, power cable, unused remote and original box.
      Will include the Denon catalogue featuring this amp.
      I can ship interstate if buyer is keen and there will be additional shipping costs.
    • By Mr.Anderson
      Problem
      I used to be a very happy owner of a Prima Luna Prologue II amp for which I managed to find the best damn tube combination (after months of rolling & rolling) which made the amp just sing every time I turned it on. However, despite its musicality and all the goodness it offered, I had one gripe with this amp. The lack of a remote. (I believe that this is simply human nature where we are never forever happy and at rest with certain things no matter how hard we try)
      This made me go for a Prima Luna Dialogue Premium Integrated. Now this amp is a beast.. weighing just above 50kg and looking as stunning as a valve amp can be. And guess what, It has a remote. One hell of a remote... I'm sure you can already guess where I'm going with this. Despite all the new features and looks and what not, the Tube arrangement is vastly different with the new amp and even after quite a lot of rolling attempts and various changes, I still have not had a combination of tubes which could even come close to that of my previous amp.
      Prima Luna Prologue II employs 2 x 12AX7 + 2 x 12AU7 in the pre section and 4 x EL34/KT88/KT120/etc. in the driver section.
      Prima Luna Dialogue Premium Integrated employs 6 X 12AU7 in the pre section and 4 x EL34/KT88/KT120/etc. in the driver section.
      I'm at a dilemma whether I should keep the new one and sell the old or keep the old one and sell the new
      Questions
      Can anybody give suggestions to how the Pre section of the Dialogue Premium is arranged ? (i.e. the internal structure of tubes and how they affect the sound of the amp)
      Has anybody found a good combination of tubes for the Dialogue Premium amplifier which can make it sound as it should ?
      Can 12AU7 be interchanged with 12AX7 ?
      And BTW, the winning tube combo in my Prologue II is as below. Those who have this amp, Please give it a try and see what I mean...
      2 x 12AX-7 = Telefunken Smooth Plate (Selected Tube)
      2 x 12AU-7 = Brimar CV 4034 (Purchased from Tubemonger who has the tooling to create matching bases that would go into the 12AU7 socket)
      4 x EL-34 = Svetlana Winged C (NOS). (I tried a quad of Mullard EL-34 XF2 NOS with the above pre tubes but the Svetlanas sound waayyyy better with them)
      All Opinions are welcome
      Cheers....
