Hello guys I am new commer here.
A week ago I just purchased a vintage 1993 ka-5050R MOSFET kenwood amplifier. I am so happy with the eartquaking solid sound.
Can anyone tell me the difference between my amplifier and the Ka-7050R?
Does also anyone know why the volume knob led indicater at times it flickers when putting volume up and down? And input selector switch doesnt always obey the selection made.
Could all this result of non usgae for some time of device pls?
Thank you so much for the help.
Johann
Hi @johannmicallef480
Basically the 5050 is 80watts/channel and the 7050 is rated at 100watts/channel.
Most other things are equal such a MM & MC signal to noise ratios and the 7050 having better distortion control.
Manuals here:
https://www.hifiengine.com/manual_library/kenwood/ka-5050r.shtml
https://www.hifiengine.com/manual_library/kenwood/ka-7050r.shtml
Some answers to questions about your model are here:
http://www.fixya.com/tags/kenwood_ka_5050r
JJ
Hello janjuc.
Thanks for you interest.
In the owners manual it says 95watts + 95 watts din into 8 ohms not 80 and 140watts + 140 watts into 4 ohms
1 hour ago, johannmicallef480 said:
Hello janjuc.
The output from the links provided is 80w @ 8ohms for the 5050 and 100w  @ 8ohms for the 7050
JJ
Just looking at the basic specs there is an extra 3 kg, probably a larger power supply and associated cooling, ? better electronics, but that would depend on price.
@johannmicallef480 just reading this post now, 80wpc of MOSFET power is absolute grunt,and smooth sound , enjoy?
Hi Johann,
you are right, age and non-use of switches and volume knob are usually the first things to go bad on old integrated amps.
First you fix them by wiggling them, then when that doesn't work, you fix them by spraying them (from the inside with the top taken off the amp) with electrical cleaning spray, then when that doesn't work, you fix them by replacing them.
Regards,
Grant
