RTR001
Old Martin Logan Aerius Crossover rebuild
I recently picked up a nice old pair of Martin Logan Aerius speakers (built May 93) which I’m looking to do a complete rebuild of when I find the courage to do so. I’m looking for some advice as to the best way of tackling the crossovers since the majority of the existing caps are 25 year old electrolytics.
Martin Logan sent me the crossover schematic which I’ve included below. Reading this I’m looking at 2 of each of the following caps:
For the top end: 10uF, 15uF & 22uF
For the woofer: 80uF, 100uF, 470uF
The inductors are air core so I’m not going to worry about those or the resistors.
I don’t have a small fortune to invest in super high end caps so am considering some bypass options as well as some premium ELKO caps for the bottom end - I may need to combine a few to get the 470uF.
I’ve looked into this a little and there is a lot of talk about using the Vishay MKP1837 0.01uF (readily available at Speakerbug) as a tiny bypass cap. At this stage, for the ESL panel capacitors, I’m *thinking* about using a combination of Jantzen Standard Z-caps and Premium Z-caps where my budget will allow and add a bypass to each using the Vishay.
I haven’t had any experience with bypassing though so I’m unsure if this is the best approach or even a good one. The speakers which I’ve recapped have always just been like for like values.
I would appreciate any suggestions & advice
I’ve used the Vishay MKP1837 0.01uf as a bypass on a 47uf and 25uf MKP on/off....beat me if I can tell the difference.   Not sure if you are going to notice the difference in a XO network for speakers.  I’ve used them for psu bypass too on electrolytic 100uf....
However utilising these instead of ceramic smooth the SQ up in a input fet stage.    The ceramic that was replaced were for RF suppression.
Not capacitor related, but the main problem with all ML speakers of that vintage is that the conductive coating on the Mylar membranes degrades over time. I have heard that the conductive particles float off the membrane as they get attracted to the charged stator panels, eventually leading to a dull lifeless sound in the speaker. Some call it a fatal flaw, but my suspicious nature tells me it was a bit of planned obsolescence by ML as they did a roaring trade with replacement panels @ $1-2K a pop!
Also, ML panels are difficult to take apart being glued tightly in place (with risks of bending and crumpling the metal stators) making refurbishment difficult. If you do manage to remove the stators successfully, then it is just a matter of recoating the Mylar membrane with a specific conductive liquid solution. A repair kit for all electrostatic speakers can be purchased cheaply from Rob MacKinlay at ER Audio.com in Western Australia.
Once repaired in this manner the MLs should go for another 10yrs+. Btw, I don’t think the newer ML speakers are prone to this problem.
Steve.
Maggie’s have a different kettle of problems ...aluminium strips attached to a moving plastic sheet of mylar/kapton, the glue denaturing over time and causing the sheet to resonate, flap and rattle.
Edited by Steve M
Thanks guys, I'm tackling the panels separately and have already spoken to Rob and a few others :)
I've also read that aside from the Vishay's using corresponding values ~1% of the main capacitor is an effective bypass. I.e. Running a cheaper 10uF Janzten Z-cap in parallel with a 0.1uf Superior/Silver Z-cap. Not sure how effective that is?
Given that the panels are so revealing (when working 100%) I'm keen to get the most out of the crossover within my budget of a couple of hundred dollars.
    • By Johnno2017
      Bought a Sotm SMS 200 unit from a SNA member last week to replace my Sonos Connect. I can see why the Sonos is so successful as it is so easy to use, just plug, simple 1-2-3 setups and play.
      I cant say the same for SMS 200, I got nowhere further than seeing power up and ethernet light up. Tried to connect my PC to SMS 200, but all I got was error messages.
      Sotm instructions, Google and Youtube were my reference for help. Now, here I like to ask for help, possibly some pictures of your connection.
      Equipment :
      - Laptop (PC)
      - Sotm SMS 200
      - Lan Cables CAT 5
      - Modem router
      - TP-LINK Power Adapter
      Connection attempt 1
      - connected pc to sotm with lan cable
      - tried the ip thing 168.192.1.0 and //euhasu and eunhasu.local
      Connection attempt 2
      - connected sotm to modem router with lan cable
      - pc connected to the same modem router with lan cable
      - tried the ip thing 168.192.1.0 or 1 and //euhasu and eunhasu.local
      ##Goal is to use squeezelite to play tidal.##
      Thank you for reading !!
    • By dsj88
      I'm trying to play an MKV movie file off of an external hard drive.
      I've plugged it in the the front USB port, plugged the power cord in, the hard drive lights up and spins up fine but nothing happens on the Oppo.
      It's a USB 3.0, NTFS file system that works fine on my computer. I don't see any option on the Oppo's menu to play something off of external media. For all I know it could be detecting the hard drive fine but I just don't know how to access it.
      Any help would be appreciated.
    • By zaphodis
      Hello all, just wondering if anyone might be able to shed some light on this issue. I have an older Samsung Plasma TV (PS-63P71FDX), and whenever I am running a device with its output set to 1080p, it shows this noise in the image on the panel.
      I've tested with a standalone blu-ray player, ps3, ps4 and a wdtv. Switching it back to 1080i solves the issue, but just wondering if anyone has any ideas what might be causing it?
      I've attached a video of the issue in action. I've also tried numerous different HDMI cables, connecting devices straight to the TV instead of through my receiver (Onkyo SR605) and still have the same issue.
      Cheers!
      http://www.youtube.com/watch?v=yH6W_XD5ZIQ
    • By twobob
      Hi Guys … I have just purchased a Samsung Soundbar (HW-H551 for $229 from the Good Guys) and need some advice on how best to connect Foxtel, SD TV, Apple TV, use the Blu-Ray player I have and replace the home theatre speakers with the Samsung Soundbar.
      My set up is (including links to manuals for others that have been looking for them):
      - Panasonic 42" TV TH-P42G10A. Link to manual Refer p44-45 for connections diagram
      - Foxtel IQ2. Link to manual Page 80 for diagram
      - Apple TV2. Link to manual
      - Samsung Blu-Ray DVD player (part of the Home Theatre set: HT-BD1252W). Link to manual: Page 15 for diagram
      - Samsung Soundbar HW-H551. Link to manual. Page 14 for diagram.
      - Logitec Harmony One remote control. Link to manual
      I'm hoping to have all sound go through the Soundbar … grateful for any tips!
      Thanks in advance!
      Cheers, deers and happy-new-years from hurmeez and two bob
    • By confusedtv
      Hello DTV community,
      We've constantly had unreliable reception in Richmond NSW since DTV started despite the MySwitch page indicating we should have "good coverage". By and large, we live with the issue (until we can afford to get a reliable antenna professional to visit), however I was hoping for a bit of help and advice on the following issue:
      Most of the time Channel 9 has no signal- in these cases both Ten and Seven are clear. But on the occasions that Channel 9 does decide transmit properly either Ten or Seven will then drop out.
      Any ideas? And does this indicate what our general issue with reception might be?
      Cheers in advance (and a happy new year),
      Confused
