jkn
Satori 2018
I would be very interested in seeing a response plot of this at say 30* off axis to see.
When I measure I would normally do at 0*, 15*, 30* and 45*.
I would normalise my response (and then apply eq[emoji41])
If you are considering maybe make the mids and Tweeter in the same box in a offset mtm set up with minimal spacing, it's not like the Tweeter needs a box anyway so it's essentially 'wasting space'
...... It does look very nice though
I would normalise my response (and then apply eqemoji41.png)
I do kind of similar procedure as well
 Not really at this stage I have single drivers running -(WMT ) + 18" in each corner and I can not fault the system it sounds pretty good so no changes are to be made to this speakers very happy with the outcome.
Just posting room response of Volt studio 18" 4564 taken from listening position.
 6db boost 70l close box
These are awesome drivers they have very similar texture to my PHL (speed,authority punch...)plus they are able to go very low
Edited by jkn
v_18_21.jpg&key=5d37d2da5376dfd95784be47a59d957a4a4415967af431a77366fd56ab6f134e
Volt_in-rom.jpg&key=cbcaac44b23f3216f158c9631529784585fa348244a02f8480e3894cd672ae6f
Anyone who hasn't heard a properly used and integrated 15-18" sub is missing out on somthing special.
I have 4x 15" subs for my new home theatre (post coming soon) and considering going for 6
Hi, mi name is Enrique from Spain...read the whole post and I would like you to comment on your current impression and which configuration has finally been the best.
Hi Enrigue
WMTW works well crossovers 90/250/1600
I have finished my old project Raal140 15D/PHL6,5 1360/ and paired with Malcolm PHL15 this combo sounds incredible love it
I have also made some progress towards my Apogee OB project at this stage I'm not sure about the shape of the front baffle yet  but will be using Apogee ribbon 6.5" mid/bass and 15" bass .
So far I have made just temporally baffle just to measure the ribbons
So the ribbons don't operate low enough to dispense with a mid?
How does the PHL 15" ported compare to your PHL18 sealed sonically ?
They are usable from +-600 up I believe there are some good  bass drivers which will make it 2 way speakers
And yes mid drivers is a option I will try several options before making final OB speaker set . PHL 6.5" mid/bass is also in OB and crossing at 250Hz >750Hz.
I'm also thinking to place the mid/midrange next to the ribbon (centre) so the ribbon/mid are in ear height.
Edited by jkn
18/15 are both sealed these ports on the pict. are blocked
both drivers are very good the 15 can be cross higher then the 18
j
Quote
What makes you say this?
Is it just the frequency response? (roll off) .... Don't be fooled by that.   It is a dipole with the natural extra rolloff.   In theory, the rolloff is actually the area where you WANT to use the driver (where it has constant directivity, below the dipole peak).
However, what WILL limit where they can be used is excursion.   There is no point using them flat out down to 200Hz (for example) if that's going to cause too much distortion at your playback levels.
Tough one to call.   I wouldn't.
... but I'd also, use a larger "mid" driver.... and use a narrower baffle for the ribbon....  So I'd just be tellig you "do the whole thing different" .... so don't listen to me, LOL  ;)
Funny thing is that when I asked 10 people for potential OB baffle design/ideas, I did get 10 completely different opinions/designs so it is hard to follow/choose one. In regards my idea to lower the Ribbon to ear height, placing the mid/bass next to the ribbon in the centre was after seeing Apogee Centaurus slant 6 which has Mid/bass next to the ribbon > nevertheless I'm trying to do 3 way and Centaurus is 2 way, so anyway I will have to try it and see how it goes.
STILL wondering if it would be better to have 15"on axis with the 6.5"mid/bass or with the Ribbon (using Centaurus speaker arrangement)
How do they sound?!  :)
I think it has great potential as they are already sounding pretty good in temporally baffle.
Edited by jkn
Quote
how low does the 15 go sealed? are you boosting the low end to compensate or rolling off to sub?
Hi Murrmax
I have always use the 15" PHL down  to  90Hz only   in 4 way where the volts takes over .
Nevertheless I have burned some resistors (my fault )on my DEQX4  so I"m sending my deqx to Sydney for repair.
However I'm thinking to try (over the weekend) 3 way only as I do have another 2 deqx3 which I would like to test anyway,
So back to your question I will set  couple of profiles one as 3 way >with 15" PHL sealed and also >one as 15" ported to see how it all performs I will post the measurements  if you interested
J
yes that would be interesting 😁
15"bass . measurements
Does it sound good enough for you without the subs? ported and sealed?
Yes it does
I'm currently listening to the ported option and it does sound very good.I believe this bass box was designed by Pat (war audio)  and he did really good job.
Note:
I could also re - position the speakers to reduce the suck out  - 30-50Hz that is If I was settling on 3 way only.
Anyway very good outcome I'll be working on final OB design using these drivers
J
Hola jiri, en el proyecto Satori 2018. ¿Puedes decirme el volumen neto de las cabinas centrales MR16?
9 l for mid is correct (sealed)
35l = 45Hz in  sealed box
I made sealed enclosures because I was always going to use it in 4 way if I was targeting 3way only I would place the bass in ported design.
Again  you will get better result if you use:
1)MTW design
2)MT in one box only (sealed) don’t worry about the volume much 10-15l
3)Tweeter and mid as close as possible (1 box)
4) 3 way woofer in separate box -ported  (calculated the box height feet and so on so you end up with the tweeter at your ear height)
For design have a look at the internet  or ask some guys at DIY audio.com)
Basically you need box volume number and size of the port s
