jkn
Satori 2018
What about the woofer and mid.
Very interested in trying some satori drivers. Have recently done a 2 way with vifa ne drivers and like it a lot. Wondering for my next (3 way) if I should go for the vifa ne series or sb satori???
I like the mid/bass satori series no issues at all
J
Been checking your site, interested to know what the new project will be?
Hi Lusk,
A lot is happening actually, I’m in the process of modifying my 3 way to probably 4 way but unsure at this stage.
I have replaced my T34A Bliesma tweeter with T34B model.
I have purchased 10"volt B2500.1 drivers to replace my SB acoustic 8.5". At this stage I will try 1 pair of volt on the top and see how it is going to work in 4 way with some of 18” bass driver. I will also try 2 10” per side.
I do also have, as mentioned in my previous post, some Apogee ribbon driver (600hz-20000hz) which I will be implementing in OB sometime in the future. I just had a look over the weekend and they look impressive.
I 'm working bit by bit on sound treatment . I have made some panels from perforated board which is hanging from the ceiling on springs, not quite happy yet it’s still a working progress.
Edited by jkn
This Project is a continuation/upgrade of my previous project BPS which I have done last year, nevertheless I thought to give it a new name. In this project I have changed the tweeters and bass drivers. The Tweeters have been changed from BLiesma T34A to BliesmaT34B and the bass drivers from SB Acoustic (Satori) 9 1/2" WO24P-8 Bass to Volt Loudspeaker B2500.1.
Reason for changing theses drivers is in regard of the Tweeter I. Basically I wanted to hear what the differences are between 34A & 34B. Now I can say both drivers are extremely good, I cannot say which is better as they both perform differently, however, I could use any of them and be happy.
(NOTE: all info below is based on sealed box application)
In regards of the bass drivers I'm aiming at very tight and detail bass between the frequency of 80hz-350hz .I have used PHL10"3020 and it was exactly what I was looking, except the low extension as they do roll off at about 150hz . There are many drivers which I have tried and some I haven't tried that would do the job but they were design to go low, however, the texture and detail in that particular region (80-350) is lost.PLS note that all the drivers I have used are exceptionally good including the satori that I'm replacing, but my main objective is to have a particular driver which will cover 80hz-350hz extremely well in regards of texture and detail. The Volt driver is a driver which is extremely good for this application, the magnet of those drivers are bigger then some of my 18" drivers. The detail and speed is really what I'm looking for.
Edited by jkn
Temporally setup
Edited by jkn
Few updates
propose_finish_narowsideconcretebps_2.jp
It's due to the strong motor force.
You can use EQ to have the driver play flat to your 80Hz target.... no problem, except it will depend what SPL you expect as the movement is only 5mm xmax (12mm limit).
Hmmm .... interesting driver.  Very low Cms, and high Rms.
On 08/08/2019 at 5:09 PM, jkn said:
Few updates
Love it mate. Really great work. 👍
@jkn that speaker system is really kick-ass and quite elegantly put together!
Well done!
Well done!
Thanks appreciated here is the final product
Bass is impressive 13-15Hz in sealed box with 6db boost I have never hear better bass driver and I went through a few in last 15 years
Edited by jkn
On 08/08/2019 at 7:09 PM, jkn said:
Few updates
WOW!  Very nicely matched veneering!  :thumb:
5 hours ago, jkn said:
Bass is impressive 13-15Hz in sealed box with 6db boost I have never hear better bass driver and I went through a few in 15 last years
Wow! High praise indeed. I've been wanting to hear them since I saw Quested started using them. Very cool.
What's the laundry list? I's pretty sure you've used PHL. What about Acoustic Elegance?
Edited by Peter the Greek
I have use AE 15TH+ and 18TH+ in the past  > recently I got pair of 18TH+ for another project still I think the Volt is much better sounding driver in (my place and application) > sealed working 15Hz up to 120HZ > TH+ is great if you want to /need to cross a bit higher > 250 even 350
Edited by jkn
2 hours ago, Wozza_Lee said:
Which 18"sub are you using?
Volt Studio 4564
3 hours ago, jkn said:
I have use AE 15TH+ and 18TH+ in the past  > recently I got pair 18TH+ for another project still I think the Volt is much better sounding driver in sealed Enclosure working up to 120HZ (TO MY EARS) anyway TH+ is great if you want to /need to cross a bit higher > 250 even 350 maybe even more
Nice. Very cool.
What amps and dsp are you using?
11 hours ago, Peter the Greek said:
Nice. Very cool.
AMPS
Tweeters
Nuforce R9 V2 190W@8Ohms
Mid range
Wyred 4 Sound M500 250W@8Ohms
Bass
Wyred 4 Sound M1000 500W@8Ohms
Lower bass
SAE TX (Bridge) 1800W@8Ohms
DSP:
DEQX x2 HDP3,HDP4
Edited by jkn
15 hours ago, jkn said:
Volt Studio 4564
Wow.   Another unusual driver.
Very stiff mechanical system, with a super strong motor.... not normally the "done thing".
OMG $$$$  ;):hyper:
Some close measurements of the drivers I'm using
Lately I have been playing a bit with Speaker placement /driver arrangement
and it is real eyeopener every arrangement/position has been fully measure and
and calibrated including a room eq .
So far the single driver arrangement sound the best (by far) Including 18"bass underneath as per last picture
That is what I would generally expect.
Can you let us know reasoning why would you expect that? Is it the removal of the 2 way MTM section?
That last pic makes me want to go large bass drivers, setup looks awesome.
Edited by lusk
Yes, the MTM needs to be designed very carefully to work... otherwise it will be overall a negative.
I kinda becomes a difficult proposition as to whether to use a steep or shallow rolloff in the crossover region.   Like I said, I'm not surpised it sounded better.
