jkn
Satori 2018
Bliesma T34A - Tweeter
SB Acoustic (Satori) -2 of 6 1/2" MR16 PNW-8 Midrange
SB Acoustic (Satori) -2 of 9 1/2" WO24P-8 Bass
propose_finish_narowsideconcretebps_2.jp
propose_finish_narowsideconcretebps_1.jp
Edited by jkn
Looking good. Are you going to port the WO24P’s and seal the mids? Are you designing your own crossover. I have been looking at the Satori for my next project. The specs and build quality look impressive. Will be interested how you go...
Hi Mike.. all enclosures will be sealed incl.WO24P Eventually It will be used in 4 way active. Drivers build looks impressive
I am building something similar except with the sub in the same enclosure at the bottom. I ended up dropping out the bottom 24P (equivalent) as it all started to get too tall. Are you getting around this by putting the sub/lower base in a different box?
I will use my existing set up for the bass
HF enclosures
Bass enclosures
Mid Range Enclosures
Edited by jkn
Watching with interest as I'm about to attempt my first build. What sort of ply are you using? Is that just form ply? ta
Hi Cam
yes, it is 17mm form ply I decided to use it as HF/MF and Stand is fully or partly filled with concrete there is another 18mm ply going to be fit all over so the form ply is used for an Internal enclosure only
J
Mid Range enclosures
Stand & feets
Edited by jkn
Looking good J. Can I come and have a listen when they're done?
13 hours ago, jkn said:
Hi Cam
J
I was wondering what you were filling that enclosure up with, now that's mass loading.
Hi, Simon, I'll be hosting gtg when they are done will let you know The other layer of 18 Ply is around 4 weeks away !!
J
Always been very curious about the larger Satori drivers. Would be nice to build a small 2 way with the 9.5"driver. Your designs always seem to be very fun and interesting.
Hi the biggest Satori midbass driver is 7½" MW19PNW-8 for 2way .I'm thinking to build a bookshelf similar to M8audio maxwell model I think they look awesome https://m8audio.com/product/sweet-maxwell/
You'll need a horn to meet it, or a 3way.
What is the highest the 9.5" can be used?
I thought the 9.5" you had shown was usuable. I dont know very much on the Satori brand. Been wanting to build a small design using Satori drivers and possibly a Beyma TPL150H
That's a complex question.   Depends on what shape coverage pattern you want ....  it would be hard to balance with a typical 1" dome tweeter (hence the 'horn' comment).
That could work.
If 3 way I do have some PHL 3451 mids that are sitting on a shelf. But may try and use those 10" mids for another build. 2 way sounds like a nice starting plan.
JKN where do you buy your Satori and PHL drivers from?
Beyma TPL150H usable FR 800HZ
I don't think that will work properly with the 10" drivers I'm using
I usually get  PHL from PAT war audio  and Satori from WES
Bass Enclosures
Midrange
Stand
Edited by jkn
More detials about the boxes?
It looks like in some of the pics they have multiple chambers
Steel/bolts in the last pic, etc?
Hi Dave here are the updated sketches the grey areas represent concrete fill
The bolts are for support of the threaded inserts inside the concrete box (stand)
Edited by jkn
Edited by jkn
