SMARTPLAY Posted April 13, 2018 Share Posted April 13, 2018 They are in a diy folded horn - but they didn’t work with the time machine I have. Link to comment Share on other sites More sharing options...
soundfan Posted April 13, 2018 Share Posted April 13, 2018 Well for starters you can tell us what those drivers are? Link to comment Share on other sites More sharing options...
SMARTPLAY Posted April 13, 2018 Author Share Posted April 13, 2018 Love to! I haven’t a clue - should I take them out (is there a model no. located at the rear?) Link to comment Share on other sites More sharing options...
JSmith Posted April 13, 2018 Share Posted April 13, 2018 3 minutes ago, SMARTPLAY said: should I take them out Is there are rear port at all that you can shine a torch into? JSmith Link to comment Share on other sites More sharing options...
SMARTPLAY Posted April 14, 2018 Author Share Posted April 14, 2018 They look a bit like these: https://goo.gl/images/k5rwcC so so I think I need to get the screwdrivers out to see what they are Link to comment Share on other sites More sharing options...
Full Range Posted April 14, 2018 Share Posted April 14, 2018 On 13/04/2018 at 7:23 PM, SMARTPLAY said: They are in a diy folded horn - but they didn’t work with the time machine I have. They look like a Sonido brand model SFR 200 8” driver If that is so they would have about 95 dB So a low wattage amp will drive them If you are expecting big powerful sound with heavy bass you will be disappointed, but if you want to listen to intricate jazz and classical then you will hear sounds not noticed before Anyway get back to us if I’m correct on the driver guesstimate ? Link to comment Share on other sites More sharing options...
