Mike13 Posted March 23, 2018 Share Posted March 23, 2018 Hi. Can anyone help explain what the difference is. Higher is more expensive. Does it have to match your system? Also, is mixing and matching AudioQuest RCA cables a bad idea? Link to comment Share on other sites More sharing options...
Neo Posted March 29, 2018 Share Posted March 29, 2018 This may be of interest and explain what the DBS pack do in general. Going from 48v to 72v will improve that effect on the cables you have. It was a long while ago but my Audioquest Cheetah came with 36v packs, upgrading to 72v was inexpensive and very worthwhile. In in regard to mix and match, what cables in Audioquest range do you have? What they connect? Link to comment Share on other sites More sharing options...
Mike13 Posted March 29, 2018 Author Share Posted March 29, 2018 Hi @Neo, thanks for the reply. I just re-read that. I suppose I can’t tell when my cable is ‘misbehaving’ as he article puts it (a bit technical for me). I have the Water cable from my Bluesound Node 2 into an Integra Pre/Pro and some of @Bill125812‘s XLRs to two Nord monos. Other than that I have two subwoofer cables (RCA shape) from Integra to minidsp and then two other sub woofer cables out of that to two subs. I did see you can just buy the gadget separately. I just found one of the batteries in mine must be dead because there is no test light. Link to comment Share on other sites More sharing options...
Neo Posted March 29, 2018 Share Posted March 29, 2018 Water should have came with 72v DBS pack Link to comment Share on other sites More sharing options...
