M5SRT
MultEQ results
Just playing with 3.1 at the moment, any idea if these results are generally ok or not? :-)
Thank you
On ‎22‎/‎03‎/‎2018 at 5:55 PM, M5SRT said:
Thank you
Hi
Which flavour of Audyssey do you have?
The results seem ok to me, how does it sound?
The After graph for the 5 speakers looks like you may benefit from some reasonably thick (10-20cm) acoustic treatments. I added a bunch of panels and it helped my response above 150hz a lot.
The After graph for the sub looks much better, most people bump their AVR Sub level up a few dB after Audyssey. Using REW and a U-mik1 I've found Audyssey (XT and XT32) set my subs around 74dB and my speakers around 76-77dB. So I manually reduce my speakers till they all measure 75dB and set the to 77dB.
Please have a read of this guide at Hometheatershack to help get the most out of Audyssey.
Thanks a lot for the help. :-)
This is using Marantz MultEq. Sound seems ok but vocal sometimes not that great.
I will try the tweaks you mentioned and look at the guide.
Thanks again :-)
Are those all generated from the Audyssey MultEQ Editor app?
Looks like it has helped smooth out the subwoofer, but can't say the same for L/C/R.
Yes. Generated by the app. Not sure why it can’t improve them further. May its just what the receiver/app tuning can do or the room?
Thanks again :-)
Which model Marantz?
 So its just MultEQ - or is it MultEQ XT or MultEQ XT32? Looking at the big gains in the SW FR compared to the LCR I'm guessing it's either just the base  MultEQ - or if it's XT or XT32 there may have have been a *less than ideal* calibration
I have found these positions to work well (positions 3 and 4 are raised 3")
Thanks a lot jamiebosco.
It’s an NR1607. It would be just the MultEQ. It’s a bit limited. I will try those placements you mentioned asap. :-)
Thanks again.
@M5SRT, any updates after trying those placements? I've just recently started playing around with the MultiEQ app myself so would be interested in your findings.
