Paul_B
WITHDRAWN OR RELISTED: FS: AudioQuest Aspen 3m speaker cables pair
Item:  AudioQuest, Aspen, Speaker Cables price drop
3m / 10ft pair
Price:  $1700 price drop
Item Condition: Used but in excellent condition
Reason for selling: Not suitable for new speakers
Payment Method: Pickup - Cash, direct deposit, COD Only
SOLID PERFECT-SURFACE COPPER+/PERFECT-SURFACE COPPER (PSC+/PSC) CONDUCTORS:
Aspen uses a carefully finessed combination of high-purity Perfect-Surface Copper (PSC), and extreme high-purity Perfect-Surface Copper+ (PSC+) conductors in a Self-Shielding Double Counter-Spiral HyperLitz design. Solid conductors prevent strand interaction, a major source of distortion. Surface quality is critical because a conductor can be considered as a rail-guide for both the electric fields within a conductor, and for the magnetic fields outside the conductor. The astonishingly smooth and pure Perfect-Surface nearly eliminates harshness and greatly increases clarity compared to OFHC, OCC, 8N and other coppers. The superior purity of PSC+ further minimizes distortion caused by grain boundaries, which exist within any metal conductor.
DIELECTRIC-BIAS SYSTEM (DBS, US PAT #S 7,126,055 & 7,872,195 B1):
Insulation is an electrical barrier, and also a “dielectric” because it is inside the conductor’s magnetic field. All insulation slows down and smears the signal inside. When insulation is unbiased, it causes different amounts of delay for different frequencies and energy levels, a real problem for very time-sensitive multi-octave audio. AudioQuest’s DBS creates a strong, stable electrostatic field which saturates and polarizes (organizes) the molecules of the insulation. Saturated (full) insulation absorbs less and therefore releases less out-of-phase energy. Minimizing nonlinear time delays results in clearer sound emerging from a “blacker” background. The DBS battery packs will last for years. A test button and LED allow for the occasional battery check.
DOUBLE COUNTER-SPIRAL GEOMETRY:
Aspen and the other AQ “Tree” Series cables have an inner circular array of positive conductors spiraling in one direction. Around this inner group, the negative conductors spiral in the opposite direction, which makes possible the significant performance advantage of the positive and negative conductors crossing each other instead of being parallel. However, the critical need for positive and negative to have a fixed non-changing relationship is ensured as the negative and positive groups are in fact two tubes with a perfectly consistent relationship. The result is an astonishing clarity, like focusing a camera lens you had no idea was so far out of focus.
CARBON-BASED NOISE-DISSIPATION AND CROSSTALK-DISSIPATION SYSTEM (INSULATION):
The negative conductors in Aspen are covered with partially conductive Carbon-Loaded Polyethylene. This remarkable material damps radio-frequency garbage from being fed back into the amplifier. The sonic benefit is exactly the same reduction in “hash” and improved dimensionality that comes whenever RF interference is reduced in an audio circuit. Another carbon layer also damps interaction between positive and negative conductors, and an external 3-layer carbon-based NDS System additionally absorbs external interference.
SPREAD-SPECTRUM TECHNOLOGY (SST):
Any single size or shape of conductor has a specific distortion profile. Even though radially symmetrical conductors (solid or tubular) have the fewest discontinuities, any particular size still has a sonic signature. SST is a method for significantly reducing the awareness of these character flaws by using a precise combination of different size conductors. The different SST-determined conductor sizes used in Aspen allow an exceptionally clear, clean and dynamic sound.
BIWIRING:
When possible, running separate conductors or separate cables to the treble and bass halves of a speaker will considerably reduce distortion. BiWiring helps by keeping the large magnetic fields associated with bass energy out of the treble cable, allowing the delicate upper frequencies to travel a less disturbed path, like keeping the big waves out of the water when you swim. Although Aspen is an ideal Full-Range cable, it has also been designed to make it possible to truly Single-BiWire. Many multi-conductor cables claim to be good for BiWiring, but unless there is real magnetic isolation between the bass and treble conductor groups, dividing such cables into bass and treble can actually be worse than keeping them together.
TERMINATIONS:
Aspen is prepared by Cold-Welding AudioQuest’s 1000 Series Hanging-Silver Multi-Spades or Bananas. The plugs are plated directly over pure Red Copper by submerging (hanging) the spades and bananas into a vat of extreme-purity silver, resulting in a very thick Direct-Silver Plate. There are no intermediary performance degrading materials. Aspen’s breakouts (where the cable divides into positive and negative legs) are also special: Because a metal breakout would disrupt the cable’s magnetic fields, Aspen’s breakouts are magnetically invisible ABS.
DIRECTIONS:
Because all drawn metal is directional, all audio cables are directional. AudioQuest analog and digital audio cables are all controlled for correct directionality. The best sound is made possible by following the “Amp” and “Speaker” labels on Aspen’s breakouts.09602840-96E0-4905-A130-50B3B3FCEA87.thumb.jpeg.ea6865d0bc19e8a4e80a25ee45fc509c.jpeg4452C91E-5F64-4E1E-A106-0637FEABC9B3.thumb.jpeg.fc0d324760ee323e70c86e775ca71d49.jpegA2D16B23-2978-442F-B0F6-7E67D7EC818D.thumb.jpeg.f6eb7559c0b9dc186559d561f7084f86.jpeg81FC103A-1D0C-4113-92F5-F53704513FA7.thumb.jpeg.efb5132dc4c12b2094ddd3a1020c3c51.jpeg58B8C5EE-F2AD-4391-A28D-36C6BD8A0682.thumb.jpeg.234412bf76005d959f00d700665f5ea6.jpeg
PRICE DROP TO $1700 open to offers.
This item has been withdrawn from sale or relisted.
    • By Gregory13
      Item: Audioquest Wind Balanced XLR Cable
      Price: $1500
      Item Condition: Like New (9.9/10)
      Reason for selling: No longer used.
      Extra Info: RRP $2280 used for a couple of months. Approximately 100 hours of burn in time so more than ready to go. Super high end upgrade for your system with a nice discount off the retail price. $780 off the retail.
    • By migasson
      Item: Black Rhodium coax, Audioquest Forest USB, and Wireworld RCA’s
      Price: $100 plus $25 postage
      Item Condition: very good
      Reason for selling: not needed
      yes, I’m clearing out all my cables (and there’s a bonus Wacom stylus. Not sure if it’s working!)
      Black Rhodium coaxial
      Wireworld Luna short RCA’s x 2
      Tara Labs RCA’s
      Belkin and Vention optical cables
      Mogami instrument cables
      Wacom stylus
      HDMI cable from Kmart
      USB dock
    • By woogie59
      Item: Audioquest Gilbraltar, 2m single speaker cable, bi-wire,  bananas, 72DBS
      Price: Reduced to $180 including postage. Cost me over $600 when new!
      Item Condition: 7/10
      Reason for selling: Excess
      Payment Method: Post/Pickup - Cash/Direct Credit
      Bought this new from Len Wallis audio over five years ago.
      I think RRP was about $800.
      Normal wear and tear from use, ie. a bit of pilling of the outside brand, some scratches on one of the end cables covers.
      The DBS unit is 72v but is one of those older ones that were rubbery so has become "sticky".
      Gilbraltar was one of the more popular Audioquest speaker cables due to it's bang for buck performance.
    • By Brenden_G
      Item: Audioquest Dragonfly Red DAC/Pre Amp/Headphone Amp
      Price: $140 + Postage (if postage required)
      Item Condition: Brand New, unused, unopened
      Reason for selling: Came bundled with a set of headphones and as I already have a headphone amp, the Dragonfly is not required.
      Payment Method: Pickup - Cash, Paypal (send to a friend), Postage a buyers expense.
