Domino23 Posted February 8, 2018 Share Posted February 8, 2018 Hi Guys, So...have just finished owner build on our new house and ready to setup our home theatre. I have picked up the following: * Optoma HD36 * Dali Concept 10s * REL T7i * 2x Monitor Audio CT165 * Monitor Audio Silver Surround * Monitor Audio Silver Centre * Yamaha RXV1800 Looking at picking up a 120" Oz Theatre Screen next. What I am stuck on is Bluray choice. I need a tv tuner as well, so do I go for a Bluray/tuner in one or spend extra for a dedicated bluray and dedicated tuner? OR buy say XBOX One with tv tuner adapted? Really a noob starting out. Any advice is appreciated. Link to comment Share on other sites More sharing options...
pond44 Posted February 9, 2018 Share Posted February 9, 2018 When building did you soundproof the room and allow access for wiring etc.? Link to comment Share on other sites More sharing options...
Domino23 Posted February 9, 2018 Author Share Posted February 9, 2018 The room is soundproofed, but mainly just insulation. I decided not to continue down the path of thicker gyprock etc. As for access, I have added a 20mm and 50mm conduit behind the AV gear. Extra CAT 6 cable also installed. Link to comment Share on other sites More sharing options...
pond44 Posted February 9, 2018 Share Posted February 9, 2018 best of luck with the project. And go OPPO. Link to comment Share on other sites More sharing options...
Guest Prof. Posted February 9, 2018 Share Posted February 9, 2018 I would definitely get a good blu-ray player separate from a tuner.. You don't have to spend a lot of money to get a good player and one of the Panasonic players will give you all you need for the time being.. Link to comment Share on other sites More sharing options...
