lonewolf Posted February 6, 2018 Share Posted February 6, 2018 (edited) Item: Cary Cinema 11 Location: Sydney Price: $950 Item Condition: Excellent 9/10 (Never really used it) Reason for selling: Too many unused Processors Payment Method: Pickup - Cash, Paypal, COD Only Extra Info: I was told it has been used for 20-40 hours as a demo model i believe. Condition is still excellent. I havent personally used it yet. More than just an audio control center, the Cinema 11 features the latest version of CES 7.1 decoding, which derives 7.1 channel output from stereo, 5.1 and 6.1 channel sources. Unlike other decoders, CES 7.1 is compatible with all input sources and requires no special encoding. Because the improvement it provides is clearly audible, CES 7.1 decoding is widely regarded as the finest available. In addition to CES 7.1, the Cinema 11 is also equipped with Dolby Digital Surround EX, Dolby Pro Logic II, Dolby Pro Logic IIx, dts 96/24, dts NEO:6, and dts-ES decoding. With 32-bit audio digital signal processing (DSP) engines, the Cinema 11 offers unparalleled processing power. These DSP engines perform custom Cary Audio processing such as auto sound setup system, CES 7.1 decoding, bass enhancement, dialog enhancement, bass management, high-precision digital crossover, and room EQ. This processing is available at sample rates up to 192 kHz, with 24-bit resolution to retain top performance from all input sources and listening modes. A DSP engine is dedicated to decoding multi-channel compressed audio sources. 10 channels 24-bit/96 kHz A/D converters can be used to convert stereo analog audio input and 7.1 analog audio input signals to digital signals, allowing the Cinema 11 to provide the benefits of precise digital signal processing without sacrificing signal integrity. Alternatively, stereo analog XLR or 7.1 bypass signals and 7.1 analog signals can bypass A/D conversion and internal processing to remain in the analog domain straight to the output connectors. The Cinema 11 offers: • 8 inputs; one balanced and seven single ended with RCA connectors; including S/PDIF coaxial, S/PDIF optical, and analog pairs • 7.1 channel analog audio input connections • Analog bypass option for stereo and 7.1 channel analog audio input connectors • Auto switching between digital and analog audio input connectors • 24-bit/192 kHz D/A converters for all Main Zone audio channels • Automatic and manual calibration of speaker distances and output levels • 32-bit DSP engines • CES 7.1 decoding • Dolby Digital Surround EX, Dolby Pro Logic IIx and Dolby Pro Logic II decoding • dts 96/24, dts-NEO:6 and dts-EX (discrete and matrix) decoding • RS-232 connector for flash memory software upgrades and configuration tool downloads • Optical digital audio output connector for Zone 2 (Toslink) • 3 12 volt output connections with 1/8†mini plug connectors • 2 IR input connections • XLR microphone input connections • 7.1 Balanced audio output connectors for Main Zone http://caryaudio.com/pdfs/manuals/Cinema11.pdf Reviews: http://www.hometheatershack.com/forums/home-theater-receivers-processors-amps/5400-cary-audio-design-cinema-11-new-preamp.html http://www.cepro.com/article/cary_audios_cinema_11_impossible_to_pass_up/ Pictures: Edited February 6, 2018 by lonewolf Link to comment Share on other sites More sharing options...
srms Posted February 6, 2018 Share Posted February 6, 2018 Link to the manual https://www.caryaudio.com/product-support/cinema-11/ GLWTS 1 Link to comment Share on other sites More sharing options...
lonewolf Posted February 6, 2018 Author Share Posted February 6, 2018 Thanks for the link. Link to comment Share on other sites More sharing options...
