wooferocau
Oppo 203 HDR Tone Mapping.
I'm having trouble avoiding the lure of Mode 2. It's a sickness...
It's just looks so good until you come across one of these sky shots that quite honestly all of the modes mangle a bit unless you really increase the nits slider beyond what a projector can handle.
I'm fine with the compromise. It's just a beta after all.
Although I did chase my tail a bit this weekend pursuing good results in scenes that are probably extreme cases.  I tried to capture all the highlight detail I could without losing too much brightness before doing some direct comparisons with Blu-ray and realising Blu-ray clips most of the highlight detail too.
And I'm still seeing some very dark scenes that are too dark.
On the bright side... literally...during a brief test Arrival is now watchable if I put the nits slider all the way down to 50!
Does anyone know if SDR BT2020 tone mapping will work with an Epson LS10000 (no HDR BT2020 but DCI P3 color)?
This will make those LS10000s a bargain if it did
I read that the LS10500 ( current model)  does  SDR BT2020  but not sure about LS10000
Nice thought . Just need a hd fury linker etc to strip the HDR :) If using that method rather than the oppo ?
http://www.avsforum.com/forum/24-digital-hi-end-projectors-3-000-usd-msrp/2657593-epson-ls10000-any-point-buying-uhd-player.html#post48567073
Edited by cwt
Stripping out HDR is only one part of the solution - it is the tone mapping of HDR to SDR on the 203/5 that is what makes it so impressive.
Yes I know that one does - but just curious what could be done for the older unit.
33 minutes ago, DoggieHowser said:
...it is the tone mapping of HDR to SDR on the 203/5 that is what makes it so impressive.
I wonder how it compares to tone-mapping via MadVR which is a GPU based renderer available only on Microsoft Windows. I'm yet to try it.
Edited by Satanica
@Javs has all but given up on Tone Mapping using MadVR...  and he has been working directly with the creator of MadVR..:)
Hmmm, that doesn't really tell me anything. :)
EDIT: But thanks for dobbing Javs in. :thumb:
Edited by Satanica
You end up with a colour gamut much smaller than p3 right now, it's not working with highlights properly it turns them white.
Its no good right now. With a bit of work it will get better which is what we are hoping to do. But it's tough to get things across to madshi at times.
I've given up for now, I provided a lot of solid photos and feedback on an avs thread perhaps woofer can link since I'm out right now.
HDR curves look way better on my JVC anyway. And the saturation in highlights i.e. explosions, has correct colour on my Samsung uhd tv and my JVC when I use real HDR.
@Javs custom curves look "Excellent" on my Z1/RS4500  :) MUCH MUCH better than any amount of tweaking the default HDR profile with the standard controls.
I have been doing alot of comparisons with @Javs curves and the Oppo,s Tone Mapping.....both are Excellent . Each has its own small benefits over the other.
This is a link to the MadVR Tone mapping Thread on AVS......take a GOOD look at the pictures/Examples that @Javs posted..
http://www.avsforum.com/forum/24-digital-hi-end-projectors-3-000-usd-msrp/2954506-improving-madvr-hdr-sdr-mapping-projector.html
On 06/02/2018 at 9:40 PM, :) al said:
thanks for the nutshell dave, as in typically manni fashion theres a lot there he has posted but nothing specific he helps with. its a kind of heres a nibble you figure out the rest because I have :D
so not sure if can help but any thoughts ? what preset do we put our x7000 into.
do I leave it in my uhd preset. or simply r709 calibrated pre set ?.
or am wondering if I need to create a new preset, leave in bt2020 but without gamma D ? would i re calibrate re do the clipping point fro contrast and brightness or leave as is. a bit confused to be honest !
haha so apt.
