tooncam
Recommendations for budget dual output receiver
I'm looking to replace my Yamaha RX-V2065 receiver with an updated equivalent - i need 2 outputs for TV and projector - as a concession to the missus i haven't turned the lounge into a man cave so am running a 5.1 set-up with small Mordaunt Short book shelf speakers as front and rear surrounds with MS center speaker & sub in a medium sized room.
Have between $1k-$2k to spend - have no make preference although i have had a couple of Yamaha's that have served me well so have looked at the RX-A870 and the RX-V1083 as options.
Any suggestions/recommendations?
Edited by tooncam
