Music2496
Advice for fixed screen for daylight viewing and projector
Hi all
Just looking for advice / recommendations for fixed screens that perform well in daylight viewing, but also good for night viewing too.
Is there a high quality recommendation within a budget <$2k for the screen?
And does it need a specific type of projector? Projector budget < $3k.
Or to put it better, budget is $5k for projector and screen.
Size of 100 inches (or larger if budget allows).
I'm not too fussed on 4K right now, but really good quality full HD 1080 is a must for the projector. 4K is a bonus for future proofing.
I don't really know much about either, so I'm happy to get advice from your experiences and knowledge out there.
Cheers!
You really need to get light control in your room during daylight hours, or spend megabucks on a specialty daylight screen that may still have issues with hotspots or poor off-axis viewing due to the highly reflective finish used. Start with the room, not the projector or screen.
Speaking of room, can't tell whether you need a short, medium or long throw projector without knowing room dimensions, any limits on projector mounting and which wall you're projecting on to.
Some of the expensive daytime screens work quite well.
Even with that, if you cant attenuate light in the roim - image quality will suffer greatly and looked washed out. A 1080i CRT from almost 20 years ago will look better.
I would suggest looking at a 75 inch oled if primarily viewing in daylight.
Thanks Quark!
This isn’t for a dedicated room. It’s for an open space living room with the fixed projector screen to be in there.
Seating is ~ 4-5m from the wall and the projector can be an distance less than that (doesn’t need to be above seating position), ceiling mounted.
I should add daytime viewing is mostly for sport in full HD - maybe 4K if content moves in that direction over the next 2-3 years.
Daytime viewing would never really be for movies.
I really want 100 inches minimum if the $5k budget allows.
Fixed screen is preferred.
Appreciate any advice / recommendations
Edited by Sean84
Moderator
Sean I run a screen in what is a open plan layout that can be closed off it’s surrounded by windows 7 in all around the room and s light filled staircase behind. But with pelmet and block out blinds and doors closing off the room I get pretty Good elimination of light during the day with one more opportunity to improve which been on plan fir years done nothing as happy enough
with light if it’s direct on screen it will be a killer. If indirect depending on tolerance you might find fine. With cricket for instance I don’t bother closing off room at rear which opens to dining kitchen abd staircase as light is indirect and be surprised how good
if can’t do anything about direct light one of those daylight screens is possible but cost ridiculously is amounts and not without their issues and limitations
projectors have come s long way and as long as don’t go too huge even with decent calibration running at typical suggested  14FL luminesce it will look like a big plasma even with some light in the room. Ie back lighting or indirect light
its hard to know what your room looks like without pictures or what efforts needed to get conducive for projection. Without this makes very difficult  fir people to suggest anything bar go to flat screen panel instead
Thanks Al.
Definitely will have direct light blocked because I've seen what direct light can do with washing out the picture during day time. Looks horrible.
I know those black screens are expensive - are they grey screens a good 'in between' for daylight viewing?
The problem with flat screen panel is I've seen sport on 100 inches and anything less now looks bad :-)
I guess if I wait 3 years we will probably have a 100 inch flat panel screen within the $5k budget.
Still, if anyone can give a recommendation of projector and screen for $5k, happy to look into it.
As Al mentioned, with some curtains and pelmets you should be able to get your room reasonably dark in daylight you'll be good to go with a normal screen up around 120". Don't go too small - what seems large at first will look smaller after a few weeks.
If your budget can stretch a little past $5K, contact Rich at Oz Theatre Screens to see what package deal can be done for a JVC X5900 , mount and 120" 16:9 screen. You'll also need cables - I'd suggest the Ruipro cables here if you have a run of over 10m.
If your budget is tight Sony HW45 will be on sale here tomorrow at current price less 20% discount using code PCTECH, plus grab a 120" 16:9 screen from Selby Acoustics.
4 minutes ago, Quark said:
20" 16:9 screen
Do grey screens give better daytime performance than white?
Moderator
36 minutes ago, Sean84 said:
Thanks Al.
THE main problem with grey screens you there and there give away the possibility to do pure whites... I know some will say oh its a touch grey and still look white, but sorry for serious viewing i for one wouldn't want to give up ability to do whites.
below are a couple of shots of the cricket, with my rear doors open, ie some light in the room, indirect
though your set up is likely quite different to mine and in my setup have blocked out all direct light. and above is ok for me watching cricket, i wouldn't watch a movie this way as there is still some contrast loss and loss of punch to picture.
below is a shot showing some ambient light in the room eg two lamps we have behind line of the screen, again indirect light, not direct on screen. in this case picture was via old epson 9000 series,
id go with quarks suggestion re pelmets and make the efforts to control light its well worth it. for not most critical viewing some ambient light in the room likely will be able to get away with
another choice is also as we do which is a drop down screen in front of smaller flat panel which is fine for day to day tv and viewing and we leave the large screen for movies sport, concerts big events  etc
Moderator
oz theatre suggestions a good one, as can get a good package. also check out cleff hifi if in melb. as they sell both jvc and epson. if jvc cant fit budget one of the better epson units might :)
ps apart from screen also have to factor in a hdmi cable and decent mount ie the peerless for projectors like the epson/jvc i wouldn't use anything less. installation also if need someone to do all for you.
I agree with Al. The only time I'd consider a grey screen nowadays would be if using a cheaper DLP projector with their inherently poorer contrast. For your budget, you're better going for a better projector like the JVC or Sony.
    • By jif
      Item: JVC X500 Projector
      Price: $1999
      Item Condition: Very Good
      Reason for selling: Changing to a different set-up
      Extra Info: Projector is in very good condition.
      Warranty until Dec 2018 (balance of 3yr factory warranty)
      Calibrated and provides a sensational picture.
      Comes with original box, manuals (unopened), unused 3D glasses (still in new packaging).
      Will also include your choice of 5m, 7m or 10m HDMI cable
      Smoke free and pet free home
      Basic Specs
      Contrast Ratio: Native 60,000:1
      Light Output: 1300 lumens
      Lamp life: 4,000 hours (currently 820 hrs use)
      HDMI 1.4: Uses 4k eshift to accept 4k image
      3D ready
      Lens Shift: 80% vertical, 34% horizontal
      Lens Control: Zoom, Focus, Lens shift via remote
    • By killa
      Item: JVC DLA-X30B Projector - Black
      Price: $850
      Reason for selling: Upgraded and no longer used
      Extra Info: Very good projector and a great start into true HD projection with the great native contract that the JVC DILA projectors are known for.  On second lamp with approx 1400 hours on it.
      Comes with 3D Transmitter and three pairs of JVC 3D Glasses.  Original shipping box and Remote.
      Would prefer local pickup but open to shipping if required.
    • By The Audio Experts
      Item: Sony VPL-HW550ES $11900 .
      Price:  $11900.  (RRP $15999)
      Item Condition: Like New, Only 120 hrs comes with full manufacturer’s warranty and all packaging and accessories.
      Reason for selling: Display Model.
      Payment Method: Eftpos, Cash, PayPal (+3%) or Direct Deposit
      Cinematic 4K clarity with four times the detail of Full HD
      SXRD panel technology featured in our professional cinema projectors delivers native 4K (4096 x 2160) resolution images, with no artificial pixel enhancement. Every detail is clear and natural, without jagged edges or visible pixels.
      Very high brightness and contrast
      With an impressive 1,800 lumens brightness and spectacular 350,000:1 dynamic contrast range, 4K images are clear with bright highlights and rich, deep blacks – even in well-lit rooms.
      Premium white finish
      The projector is also available in a stunning premium white finish that works well in any contemporary or traditional décor.
      Smooth, fluid on-screen action
      Coupled with the panel's super-fast response rate, Motionflow technology means you’ll see every detail with minimal blur - no matter how fast the action.
      TRILUMINOS™ Display for wider, more natural colours
      Sony's TRILUMINOS™ Display technology accurately reproduces a much broader range of colours than a standard projector system. You'll see the difference with finely-reproduced tones and textures plus greater colour purity, depth and realism.
      HDR Compatible
      Take full advantage of the latest content produced with HDR (High Dynamic Range) for extremely wide contrast with an even higher range of brightness levels.
      Future-proofed support for latest standards
      The VPL-VW550ES can project content at up to 60 frames per second (fps) in 4K (at colour signal YCbCr 4:2:0 / 10 bit) for even smoother images with superior colour and realism. Support for HDCP 2.2 lets you enjoy the latest 4K content services.
      Reality Creation upscales movies to 4K
      As well as projecting native 4K content, the VPL-VW550ES upscales your Full HD Blu-ray™ or DVD movie collection to 4K with Reality Creation - Sony's Super Resolution processing technology that enhances lower-resolution content, and even upscales 3D movies to 4K resolution.
      Compatible with ‘Mastered in 4K’ Blu-ray™
      Enjoy a near-native 4K experience with discs ‘Mastered in 4K’. It’s as close as you can get to the 4K-pixel resolution and expanded colour range of the original.
      Long-lasting lamp
      6000 hour* rated lamp operating life (in Low mode) means simpler maintenance, with fewer lamp swaps and reduced running costs.
      * The figures are expected maintenance time and not guaranteed. They will depend on the environment or how the projector is used.
      Picture position memories
      Memorises up to five zoom lens positions for future viewing. Stored settings can be matched to a movie’s aspect ratio, including 16:9 and Cinemascope.
      Flexible home installation with wide zoom and shift lens
      The powered zoom lens with a 2.06x zoom ratio and wide lens shift range gives greater installation flexibility in any room size, even with high ceilings.
      Front-facing fan
      With the fan exhaust positioned at the front of the projector, you don’t need to worry about wall clearance and room for air inhale/exhaust when installing. This helps maximise throw distance, for the biggest possible projected images.
      Built-in auto calibration
      Set-up is quick and easy: auto calibration ensures superb pictures without effort.
      Industry standard RF 3D compatible
      The projector's built-in RF transmitter synchronises with any RF 3D glasses for wider coverage and greater stability, so there’s no need for an external transmitter.
      The Images are displayed on a Cinema Scope 166” Screen
      Item: Sony VPL-HW65ES $3888.
      Price:  $3888. (RRP $5999)
      Item Condition: Like New, Only 274 hrs comes with full manufacturer’s warranty and all packaging and accessories.
      Spectacular Full HD pictures with Reality Creation
      Advanced SXRD panel technology is teamed with Reality Creation - Sony's Super Resolution processing technology that refines subtle details, colours and textures. You'll see the difference with crisp, sharp Full HD pictures that take you closer than ever to the original 1080p source.
      High brightness and contrast
      With an impressive 1,800 lumens brightness and high 120,000:1 dynamic contrast range, Full HD images are clear and with bright highlights and rich, deep blacks – even in well-lit rooms.
      White finish
      The projector is also available in a stunning new white finish that looks beautiful in any contemporary or traditional décor.
      Long-lasting lamp
      6000 hour rated lamp operating life (in Low mode) means simpler maintenance, with fewer lamp swaps and reduced running costs.
      The manual zoom lens with a 1.6x zoom ratio and wide lens shift range gives greater installation flexibility in any room size, even with high ceilings.
      Front-facing fan
      Home automation with IP control
      The VPL-HW65ES is compatible with a wide range of home automation systems via an RJ45(IP), RS-232C, TRIGGER and IR IN interfaces.
      USB updates
      You're always up to date with the latest features and firmware updates via the projector's USB port.
      The Images are displayed on a 16:9 102” Screen
    • By br0d0
      Thought I'd carry on this thread with the remainder of my build. My plan is to build a dedicated HT in a new house build some day. In the meantime I thought I'd build one in my current house as I've never used a projector before. In the thread I linked to I decided to get a JVC X7900. The idea was to experiment with screen size to see what sort of viewing angle I would like. From my research I thought I'd like a 45 degree viewing angle. So to keep things flexible I decided I was going to paint the wall with Black Widow or some sort of screen paint. This meant the doorway had to go.
      This is the room in its original state, just as we were moving in actually which is why it's so messy. It's about 6.3m L x 4.2m W x 2.4m H.
       Replaced the oyster lights with 6 of these down lights from Bunnings.
      And closed up the wall; tradies did at least.
