trippinonprozac
Arcam P429 4 channel power amp
Item: Arcam P429 4 channel brigable power amp
Price: $2300
Item Condition:  New - purchased 16/12/17
Reason for selling: Monoblocks
Payment Method: Pickup - Cash, Paypal, Direct Bank Deposit
Extra Info: I have only used this amp for about 7 hours in bridged mode to drive a 2 channel setup. Extremely flexible and capable. Provides 270w into 8ohm per channel via class G amplification.
Compact and sounds sensational on my 804 D3s.
Purchased from Arcam dealer for $3550. It will be reboxed and posted in original packaging with invoice.fb61e97160cf10b4cd9b1d8acbc13d8d.jpg
    • By Cnnnnc
      Item: Dynaudio X44 Speakers
      Price: $3500
      Item Condition: Excellent (as new)
      Reason for selling: No Longer Needed
      Extra Info: This pair excellent speakers were purchased from an SNA member few months ago. These have been serving me well but decided to upgrade, and therefore are now available for the new owner. These speakers are just over 1 year old, still the current model and under warranty from a Sydney Audio dealer. Speakers come with original boxes should shipping required. See link below for info about the speakers.
      https://www.lifestylestore.com.au/dynaudio-excite-x44-main-floor-standing-speakers.html
    • By Bruno28
      Item: FIIO X7 MKII with AM3A Audio Player DAP - Under Warranty until 2020
      Price: $850 Retail is $979
      Item Condition: Brand New Sealed in Box
      Reason for selling: Upgraded to A&K
      Got this replacement, so this one is Brand New.
      The old one was a great Digital Audio Player, was able to power LCD-2, HE-500 and P9 with no problem. This is the Mark 2, the latest one.    Item is Brand new as it was sent as a warranty replacement. I will upload photos of the new unit once I get a chance.     Included on this sale: - FIIO X7 MKII with AM3A Amp module - USB charging Cable (no wall charger as it doesn't come with one) - Screw Driver - Spare Screws for Amp Module - Original Box - Manual      Bought locally form Addicted to Audio for $975 in February 2019. Warranty should be until February 2020.   Prefer Pickup in Terrey Hills. 2084
      Can post if needed. Will need to be insured (for the value its sold for) + tracking + signature + express.
          https://addictedtoaudio.com.au/products/fiio-x7-ii-second-generation-digital-audio-player?variant=44303801795&utm_medium=cpc&utm_source=google&utm_campaign=Google Shopping&gclid=CjwKCAjwuqfoBRAEEiwAZErCsuafvOKuuL1ZjpJEmnJjG0bgallG0_H9h4MOj3EC7UwozsTlThXPsBoCRJcQAvD_BwE     Manufacture's Website: https://fiio.com/x7mkii     Photos: Advertisements without photos of the actual item will not be approved.
    • By Bruno28
      Item: HiFiman HE-500 Magnetic Planar Headphones
      Price: $599
      Item Condition: Used - But in very good cosmetic condition and fully working.
      Reason for selling: Reducing amount of headphones. Want to have only 2.
      Please see photos for condition of headphone and what is included. It is operating well as it should and is in good condition cosmetically. Welcome to inspect/demo before purchase.    Includes: - HE-500 - Cable to connect headphone - Case - Soft Black Pouch  - Accessories (Head foam band + extra earcups + some connectors)     Pickup Preferred in Terrey Hills, 2084
    • By Craig_H
      Item: CHORD Clearway RCA Interconnect (3 metre pair)
      Price: $260
      Item Condition: Perfect
      Reason for selling: Change of setup, now using balanced XLR cables
      Extra Info: These are only a month old and after recently adding a new pre-amp and monoblocks to my system I have moved on to using XLR cables. Price includes postage. Current $rrp is $340 (not $500 as per the photo below)
    • By wolfz
      Item: Corda Classic Headphone Amp
      Price: $ 380
      Item Condition: used / excellent
      Reason for selling: using all in one amp/dac
       A few tiny marks (edge), not easy to see, no original box. Normal retail price new is $800.
      A very good neutral sounding amp with two crossfeed stages and two gain settings and two times line in.
      Tech Data copied from Meyer:
      Sure, from the outside the CLASSIC looks very modest and plain. However, technically and sonically this is the best and most advanced amplifier that we've ever build.
      Of course this amplifier also uses the concept of active balanced headphone ground. Within this concept each headphone connection wire carries an additional signal such that the sum of the potentials of the wires equals zero. This strongly minimizes the energies stored and released in the electrical fields inside the headphone cable when an audio-signal is applied. The influence of the wire on the sound is thus reduced.
      Moreover, with active ground pollution of the internal signal ground by strong driving currents is eliminated and the power-supply-rejection-ratio at the output stages is strongly improved. Thus the best conditions are given for a clean and undistorted sound.
      Active balanced headphone ground offers most of the advantages of a true balanced headphone setup without the need of balanced connections. It can be used with any conventional dynamic or magneplanar headphone.
      The volume control is technically very sophisticated. The position of the potentiometer is measured with the use of an AD-converter. The output of this converter is then used to switch a bank of relais to set the proper volume level. There are a total of 64 levels which allows for very small stepsizes and a very analog feeling. The advantages of this concept are strongly reduced channel-imbalances and a much cleaner and more detailed sound. The use of a conventional stereo-potentiometer does add its own sonic signature which is now prevented.
      The amplification section is build around AD797 opamps biased into class-A. For the output stages BUF634 buffer amplifiers are used. These integrated circuits are very fast and thus allows the output signals to follow the input signals very closely. The amp is DC-coupled and any capacitors found in the signal path are of the highest quality polypropylen and polystyrol.
      A very extensive powersupply, a large number of power-regulators, and a total filter capacity of 80.000 microF (!!) assure the best working conditions for any part of the circuitry.
      The built-in crossfeed filter is a frequency-extended version of the natural crossfeed found in previous CORDA amplifiers and provides even better imaging. It also offers three intensity levels (Stereo, medium, high). To compensate for the psycho-acoustic bass-loss a separate switch allows to slightly increase lower-frequencies.
      Technically the CLASSIC is an extremely advanced headphone amplifier and offers excellent value-for-money!
