It has been a whiles since my last post, and a lot has happened in the mean time.
I have had an acoustical consult and done a few THX courses as well in the mean time. Most of the time I have spend on the planing, budgeting and designing the acoustical treatment as it is going to be large scale.
The major plan is to build an acoustical front wall 500mm out from the existing front wall and turn this into a large bass trap. Hang up an AT screen and use the area behind the screen for acoustic treatment as well. (nearly all front wall first reflection points end up on screen). I am currently looking for different products to use as porous absorbers. Polymax is one candidate, simply because of the known flow resistance, but the price of it is putting me off. I am currently trying to find out the flow resistance data of the Greenstuff AAB products as these are much cheaper in price.
I have been doing a lot of reading/research into helmholz resonators and panel resonators, as the limit of the Polymax porous material isn’t going to solve all my nodal problems. But the potential shear size of these units and their effect on the rooms volume, and their effect on the effeciency (air gap) of the porous traps, has put things on hold. Theoretical, when using a low flow resistance of 3000 over 500mm I could theoretical effectively reach into the 35Hz region. But as I found out reading a bit more, these models/calculators don’t necessarily produce a predictable outcome.
In other words, I just been going around in circles, that every time I found an answer, something else pops up and put a dent into it. The consensus on Gearslutz seems to be (also by Ethan Winner) that in small rooms it is better to work with porous absorption. The biggest issue with online research about this subject seems to be, that everyone who seems to know a good deal about the subject, keeps his cards close to his chest. If this is due to, competition, the amount of time and energy invested needed to grasp the subject, or simply due to many variables effecting the outcome I don’t know.
Once the front wall trap has been made I will need to put in reflection panels to balance the room. I am looking at a MLS hole sequence like the RPG BAD pattern. Ideally I would need to come up with a custom sequence as I need custom sizes to fit around the screen. I have calculate the % of wholes for the RPG BAD (25%), Artnovion(21%) and Vicoutic (30%) patterns, as this will be useful to balance the absorbtion rastio of max 25% total surfarce area, between front and back wall.
Does anyone know how to create/program your own MLS sequence? As I believe there are some people on the forum who have done this and can help with the CNC production of the panels.
The second trap will be the ceiling trap with bulk heads along the length of the room. I am planing of using a MLS sequence I found generated on Gearslutz with 18mm thick mdf as reflection slats, to balance the reflection/absorbtion area to +/-40% wich comes down to less than 25% between (timber) floor and ceiling, which allows for the placement of a fabric sofa in the room. I have made the slats out of 5 different heights (11, 18, 30, 42, 66mm) mostly for ecstatic reasons.
Obviously everything is theoretical, and most likely is going to need adjustments in real life. I am still toying with the idea of building a riser as this could potential hide a subwoofer for clean looks and will rise the seating area in a better pressure zone. (0.2, 0.32, 0.45, 0.55, 0.68, 0.8 x room dimension)
As I have access to advanced 3D modeling software I have build and rigged the room in 3D so that it can visualize, room nodes areas based upon dimensions, best out of the box pressure area’s, early reflection points based upon listen position and speaker placement.
One thing that I need to test before starting this build is the influence of the acoustic wall on my speakers. With the wall in place, the speakers will be sitting 55cm from the acoustic wall, which doesn’t sound to pleasing to me if you consider the advise of min distance of 100cm on the Martin Logan forum. Having some BAD panels to play with would be nice.
I might have to simplify my setup as well in the end, as I might have to much equipment to access in a tight space.
Just look at density for the insulation. Its your best guide for fliw resistivity.
Ultratel is super ezy to work with and can be cheap.
Quest's Q-perf can be cut easily into whatever shape you need.
for 1D you could just use the sequence on Gearslutz (I think Boggy generated it), or I'm sure lots of other options on the googlwebs
for 2D it was @hochopeper on here that was clever enough to generate it
Mike
@Primare Knob, I feel for you mate.  Like me, you would prefer to do it once and do it right but there are few hard and fast rules with room treatment so it may pay to do some experimenting in order to get the best results for the budget.
Myself, I am interested in the VPR/CBA absorbers.  Apparently they can be made to be effective from 40Hz to as high as you like, depending on configuration and should not take up much more than 100mm off the wall.  I have some samples of a few types of Australian foam to use in VPR's (the foam is the trickiest design criteria with them) and I also have been lucky enough to find a consultant that has built and tested and installed them in the real world in Brisbane.  He even gave some frames to duplicate when it comes time for me to start building.  I plan to make some one day this year and play around with them in my room to see how useful they are for regulating the decay rate and treating room nodes, but first I have some other stuff to finish building.
I'd be very interesting in your progress with this. So far, reading about them on Gearslutz, no-one really has been able to make a proper one with good (and tested) results.  I thought that the minimum dimensions of these units need to be at least 1m by 1.5m.
There are a few that have done well with them on GS...but there are lots that don't "follow the recipe" or even bother trying to find the "recipe" for themselves.  Fuchs gives out the "recipe" in his book and the consultant that built them here in Qld followed it and used melamine foam, 1mm steel plate, some folded 1mm steel frames, a soft glue and had them lab tested.  They worked exactly according to the results in the book.  Exactly:  an absorption coefficient of 1.0 down to about 65Hz and 0.4 at 40Hz.  For a 2.5mm thick steel plate,  the book shows an absorption coefficient of about 1.0 at 40Hz:  you need some really thick porous to get to that sort of bass performance.
There are all kinds of variables, but basically 1.5m x 1m is the "standard" size.  I would build them bigger than that...floor to ceiling.  There is a mob in Melbourne that has some nice polyester fibre foam (they also have melamine) and I can get Basotect melamine foam in Brisbane.  Steel is cheap to get laser cut and folded for the frames.  I plan to put some kind of diffusion on the front of my VPR's.
I should get my hands on some books. I got the general idea that on Gearslutz, not many are following the design principle of the VPR. My understanding so far is that you need a free "floating"/vibrating plate and a foam with a rigid backing that can work as a spring. The function of the frame to me seems more related to a way of hanging the unit, although it does seem to help extending the broadband effectiveness due to edge diffraction.
Which kind of idea are you playing with when it comes to diffusion. There seems to be some designs with a foam mounted on the front of the plate, but not sure if you mount a BAD type panel onto that, that it might start to act as a (second) leaf.
It will be nice if the two can be combined successfully within a 100mm unit depth.
@Primare Knob, you basically have a decent understanding of the concept.
The steel plate is slightly smaller than the foam and the foam is attached to the steel plate with a soft glue and it is also attached to a backing sheet with a glue (not necessarily soft though, it does not matter).  The foam acts as the spring and damper for the vibrations in the steel plate.  The steel plate  should not be square and generally needs to be 1m x 1.5m or larger.  Smaller plates will work but are not as effective because they have fewer eigenmodes (resonant frequencies - the more frequencies as which the plate vibrates the better).  The thickness of the steel plate can be 1mm - 3mm with thicker plates more effective lower in frequency.
The perimeter frames can be open or fully closed depending on how much edge diffraction you want to take advantage of for further absorption.  The foam is not connected to the perimeter frame and must be free to move.  The benefit of the frames though is that they can wrap around the front of the steel plate (not touching it of course) and you can attach a nice surface covering such as BAD panels or whatever you like really.  You can add foam in front of the steel plate to absorb higher frequencies if that is required.  Personally, I would use some sort of wood grain diffusion panel (such as a BAD) to give the room a really nice feel but there is almost no limit to what you could do.
I think these VPR's are so flexible.  They can attack low frequencies without using too much room and you can add stuff to them or use them in a slightly different way if you need to attack different frequencies.  I can't see a way that I am going to find time to start on mine until next summer, but am happy to help out in any way I can if you want to have a crack at them.
Anthony
Books will only confuse you further.     Build the VPR to the recipie.   Don't over think it too much ... but be prepared to build a few, as your materials may not be quite the same.   ie.  build a prototype first.
There is really only one book that is required...
https://www.springer.com/gp/book/9783642293665
...but that one is very expensive.  I purchased a download of the chapter on "Panel Absorbers" for about $20 from memory and it gives out the recipe in detail as well as the mathematics.  Good value.
    • By Snoopy8
      Introduction
      The purpose of this post is to re-introduce a software tool that configures multiple subwoofers (subs) to produce smooth bass in a room and at the same time, make it even across sitting positions.  A common misconception of adding subs for music is that they will artificially boost the bass.  Well integrated subs help restore the missing bass caused by the room and brings the body back to music.
      The usual approach to managing bass was room treatment first, followed by careful placement of speakers & subs. Hardware and/or software, often expensive, were also used. This case study shows why MSO is a good cost-effective software option.
      What is MSO?
      Multi-Sub Optimiser (MSO) is a FREE software tool to optimize multiple sub woofers by integrating the subs with main speakers and improving the evenness of bass response across the whole listening area. MSO is especially useful in non-dedicated rooms where there is limited (or no?) room treatment and WAF considerations dictate sub size, number and placements.  MSO also solves the difficult task of getting even bass across seating positions e.g. in multi row home theatres.
      MSO runs on a Windows laptop and requires a digital signal processor (DSP) and a calibrated microphone for use with REW (Room Equalisation Wizard) measurement software. There is some learning effort and time required to understand the concepts and set up the optimisation, but the results are worth it!  There is excellent documentation and a good tutorial.
      The program was written by AndyC on AVS Forum (discussion thread hosts all discussions, support, bugs etc.). Andy @andyc56 specifically joined SNA to support MSO.
      Why MSO? – A Case Study
      2 channel system was located in a non-dedicated open plan family room with high ceiling, hardwood floor on slab, blank wall in front, large windows with blinds on right, sliding glass doors with heavy curtains behind, left side opened to kitchen.  Thick rug, cushions and sofas (with some sound absorbing foam underneath) completed the “room treatment”.
      Main speakers were a pair of active SGR CX3Bs (Mk 1) and the measurements showed how good the speakers were by themselves. However, the room muddied the bass and there was less body in the music.
      Listening positions were in a single row with the main listening position (MLP) in the centre. Right4 was better half’s favourite spot and depending on how far she stretched her legs on the sofa, Left2 became a regular listening spot!   Left1 opened out to kitchen. The middle positions Left 2 and Right 3 graphs were offset -15 dB to improve readability.  Similarly,  outside positions Left 1 & Right4 offset -30 dB for readability.
      Subs were SVS SB13U and SB2000, located using “thirds criteria” in the front.  The room had limited options for subs placement and WAF considerations further restricted things. The unintegrated subs  (no adjustments to phasing, no eq, no cross over etc.)  made things  worse between 65 and 90 Hz.
      MSO used gains, delays, cross overs and PEQs to optimise the subs. Weightings for seating positions were Left1=0.5, Left2=0.9, MLP=1.0, Right4=0.8, Right5=0.5.  A target curve was used to lift the bass and compensate for large and open room.
      Bass was even across 20 to 90 Hz and the dips were removed.  More impressive was the evenness across listening positions, even in Left1.  Right4’s improvement was under appreciated (everything was treated as muzak! SIGH!).  The graphs showed that excellent results could be achieved with dual subs and MSO, but what about listening tests?
      Using a SoTM SMS-200 Ultra network player and a Gieseler Groß DAC, Diana Krall’s My Love (double bass), Bach’s Tocatta & Fugue (organ) and Fleetwood Mac’s Dreams (drums) showed how good the bass was.  MSO brought the body back to the music and was probably the key enabler for further improving the 2 channel setup. Without MSO, I doubt I would have appreciated and enjoyed the Groß DAC as much.
      While this was 2 channel focused, MSO was also good for the home theatre. Using a different subs-only configuration, MSO took movies up a notch with additional slam on Anthem MRX 710 setup in same room. It made my favourite movie opening scene in Fellowship of the Rings superb. Was (and still am) no bass head, but understood why so many pursue this!
      SNA Reviews & Impressions
      There were at least 2 threads on MSO in the Room Acoustics, Construction and Design sub-forum.  Below were the reviews and impressions posted by members (will update if there are more posts):
      baMarek  8 Sep 16
      BradC 22 Nov 16
      mcb 23 Apr 17
      Snoopy8 5 Jun 17
      Conclusion
      This case study has shown that MSO is a good cost-effective software option to overcome the bass issues brought about by the room.  Hopefully, some here will try it for your setup.  And more than happy to assist you in your journey.
    • By Alpine Electrocats
      Item: Richard Allen bass drivers
      Price: $200
      Item Condition: great
      Reason for selling: no longer needed
      Extra Info: I can post for $20. I bought these years ago thinking they were full range drivers- there are lots of jerks on eBay selling them as that, so not needed
      Price: $200
    • By baMarek
      Item: Tesla ARO 942 bass drivers
      Price: $700 ono
      Item Condition: very good (for vintage gear)
      Reason for selling: Moving
      Highly sought after and rare, the first edition of the iconic vintage bass drivers from Tesla. Paper cone, huge magnet, very high sensitivity. I had many drivers including Altecs and nothing in my experience came close in terms of quality of bass. This is the driver Lampizator used in his reference system.
      They are 30 Ohm. I have never had problems driving them but it's worth noting. One has a slight tear on the suspension part seen on the photo but it does not affect sound and stays covered behind the metal grill (included in price).
      Each speaker weighs 10kg.
    • By Halfcast
      Near new, perfect condition and ready for Jaw dropping Hifi reproduction in your home are my Black
      Definitive Technology BP7001SC speakers (pair) which feature 1500 Watt Powered built in 10 inch subwoofers,
      Bi-polar design for the Ultimate Soundstage and Huge performance from a pair of floorstanding speakers that truly do not require a separate subwoofer.
      I will sell them for $2000 (Half of what I paid a year ago) including the boxes etc. RRP is $7999.
      Local pick up from Parklea NSW or Shipping Australia wide can be arranged at buyers expense.
      Please let me know if interested and come over for a demonstration.
      I'm selling the speakers way too cheap (losing $2000) in the hope that one of you guys will jump on it.
      The speakers are very efficient and will work with any amp with power output as little as 15W up to 500W RMS, They're 8ohm and a very healthy 92db.
      www.definitivetech.com/products/bp7001sc
      I'm happy to answer any enquiries..
