11 minutes ago, Primare Knob said:
Yes, that is correct. I have a small gap between the wall and the sub, and placed the mike there close to the floor.
There will be variations between the same positions, as I did it by hand. My intentions are to find possible locations to place pressure based traps.
So, the highlighted results on your charts, are not the ideal places for traps.... They're just higher because they are very close to the source.
You don't need to measure anything to know where to place it.    If you are targeting (for example) 100Hz.... then you work out which path lengths in the room correspond to the 100Hz mode .... and then you put that trap where it will be in that path.
http://www.hunecke.de/en/calculators/room-eigenmodes.html
5 hours ago, davewantsmoore said:
but you also have a quite low decay time now (how much absorption surface area is there in the room now?) .... and so I would probably want to put something in front of them to prevent non-bass frequencies from being absorbed so much  (although that is personal test to some degree).
I just went back and looked more closely at the RT times posted earlier - I hadn't taken enough notice of the "Y" axis - I agree with Dave - any more absorption needs something in front to reflect higher frequencies...
...but IMHO based on that RT graph the low bass is "nearly there" also! if not good enough already
I take back my comments above regarding the need to clip/channel/gyprock!
As an experiment I would wrap your existing Superchunks in builders' plastic (ugly but cheap and quick).
The low frequency performance should improve and reduce high frequency absorption.
You want to get the RT times a bit more consistent across the frequency bands - and a small increase below 50Hz or so is expected.
Note sure if I've posted the Acoustic Frontiers "Measurement Standards for 2 Ch Rooms" in this thread already?
http://www.acousticfrontiers.com/wp-content/uploads/2011/10/acoustic_measurement_standards.pdf
You may get to sufficient low freq absorption just with the plastic on your existing traps, but some more "similarly" sized absorption traps (also wrapped in plastic) should get there.
You can always put some slats over the plastic later in a 1D BAD pattern to get some diffusion (or fancy 2D masks).
Muck with speaker/sub position/EQ from there...are you trying to get smooth bass across multiple seating positions? Something like Multi Sub Optimiser (MSO) may assist (a free tool) if you have the ability with DSP to apply delay and EQ individually to subs.
mike
The chart doesn't show below 60, and is 1/3 smoothed  ;)
Quote
Maybe, but I would like to see the before/after data for the 'superchunks'.... I know whether it was them which made the decay so low .... or what is going on.    I just can't say anything useful without more info.
Judging my the excess group delay.... I'd just be using EQ only  .... or at least I would be forcing the response to be flat with EQ, before I looked at any decay charts, or distortion charts, or anything.
http://www.acousticfrontiers.com/201163hard-proof-that-equalization-kills-room-modes-html/
Then you will get a clear idea of what room effects need to be solved.
1.  Put subwoofers in their places, selected by the flattest measured response (if you have multiple subs, then the flattest sum)
2.  EQ the subwoofers to be flat (and then apply low pass filter)
3.  Look at the decay of the woofers ..... and perhaps install bass traps to fix it
4.  Repeat
... by doing the above, you do certain things:
  • You only look at solving room issues, which need to be solved  (ie. after the speaker is setup properly)
  • You are never comparing A and B, where they have different frequency responses.    Every single chart you ever produce will be a "flat" (or close enough to) frequency response.    (This is really really important)
20 minutes ago, davewantsmoore said:
great link - I'd not read that before - I need to spend more time surfing their site!
I've never doubted EQ fixes both the FR and ringing for "minimum phase" regions - although I'd be wary of such narrow/hi Q cut described.
Applying narrow EQ works if the region is "minimum phase", but generally the higher the Q/narrower the EQ cut, the more position dependent it becomes.
As you already know, DSP and the EQ capability it brings can be used for good and evil - well implemented it is very good -  when poorly implemented EQ has the ability to make things much worse.
It's fantastic we have free tools like REW that show us things like "regions of minimum phase" - in these regions EQ will fix both FR and ringing in the room's response.
Outside of these "minimum phase" regions, I wouldn't use any EQ at all for room issues.
I bolded room issues - I still use EQ to fix the FR of a speaker (which is typically "minimum phase"), or apply broad EQ "shelves" to taste such as a room curve, or bass/treble "tone" controls.
Mike
Yes, you'd want to make sure you'd checked the accuracy of the measurements, and all listening positions.
FTR, I wouldn't be boosting any dips.... as they're total cancellations.
That's no difference from the crossover filter inside any speaker ...... "DSP" lets you have sharper filters, but I think they are rarely required.
PKs data, if correct,  shows it is entirely minimum phase.
    • By Rori
      Item: Martin Logan Balanced Force 212 Subwoofer with Martin Logan PBK kit -
      Price: $4.2k
      Item Condition: Excellent 9/10
      Reason for selling: Not using atm and taking up space
      Extra Info: Plenty of reviews online about this subwoofer. It has 2 x 12" drivers opposing each other to cancel out vibrations so all you get is clear, low distortion, clean bass. Can go to 16hz in room.
      The customization for best in room response from the amp is second to none with low pass filtering, phase alignment, gain and when measuring with the PBK kit can give close to perfectly flat frequency response.
      This sub looks amazing especially in piano gloss black. You could brush your teeth and do your hair in the high gloss finish. Can ship however it does weigh 65kg's... I have all boxes and accessories for it.
      See specs and pics below.
      Specs:
      BalancedForce 212
      System Frequency Response 18–120 Hz ±3dB; Anechoic through LFE effects input 20–120 Hz ±3dB;
      Low Pass Filter Frequencies 30 - 80Hz
      Phase 0°, 90°, 180°, 270° 0°
      25Hz Level Control ±10dB at 25Hz ±10dB at 25Hz
      Power Control On, Auto (12V Trigger), Off On, Auto (12V Trigger), Off
      Room Correction Perfect Bass Kit (PBK) Ready (Sold Separately)
      Woofers Two 12" (30.5cm) cast-basket, highexcursion, aluminum cone with extended throw driver assembly, sealed non-resonant asymmetrical chamber format
      Amplifiers 2 x 850 watts
      (3,400 watts peak system total) 850 watts
      (1,700 watts peak)
      Inputs RCA: Left, Right and LFE.
      XLR: Left, Right and LFE.
      Speaker Level: Left and Right banana jacks.
      12V Trigger: 3.5mm
      Mini USB (for PBK)
      USB (for crossover & firmware updates) RCA: Left, Right and LFE.
      12V Trigger: 3.5mm
      Mini USB (for PBK)
      Output (RCA) Multi Out (for multi-sub connection) Multi Out (for multi-sub connection)
      Input Impedance RCA: 10,000 Ohms
      XLR: 15,000 Ohms per phase
      Speaker Level: 10,000 Ohms per phase (20,000 Ohms red to black)
      Power Draw Typical: 250 Watts
      Idle: 30 Watts Typical: 125 Watts
      Idle: 15 Watts
      Weight 140lbs. (63.5kg) each 96lbs. (43.5kg) each
      Overall Dimensions
      HxWxD  ( 57.4cm x 57.4cm x 58.2cm)
    • By Snoopy8
      Introduction
      The purpose of this post is to re-introduce a software tool that configures multiple subwoofers (subs) to produce smooth bass in a room and at the same time, make it even across sitting positions.  A common misconception of adding subs for music is that they will artificially boost the bass.  Well integrated subs help restore the missing bass caused by the room and brings the body back to music.
      The usual approach to managing bass was room treatment first, followed by careful placement of speakers & subs. Hardware and/or software, often expensive, were also used. This case study shows why MSO is a good cost-effective software option.
      What is MSO?
      Multi-Sub Optimiser (MSO) is a FREE software tool to optimize multiple sub woofers by integrating the subs with main speakers and improving the evenness of bass response across the whole listening area. MSO is especially useful in non-dedicated rooms where there is limited (or no?) room treatment and WAF considerations dictate sub size, number and placements.  MSO also solves the difficult task of getting even bass across seating positions e.g. in multi row home theatres.
      MSO runs on a Windows laptop and requires a digital signal processor (DSP) and a calibrated microphone for use with REW (Room Equalisation Wizard) measurement software. There is some learning effort and time required to understand the concepts and set up the optimisation, but the results are worth it!  There is excellent documentation and a good tutorial.
      The program was written by AndyC on AVS Forum (discussion thread hosts all discussions, support, bugs etc.). Andy @andyc56 specifically joined SNA to support MSO.
      Why MSO? – A Case Study
      2 channel system was located in a non-dedicated open plan family room with high ceiling, hardwood floor on slab, blank wall in front, large windows with blinds on right, sliding glass doors with heavy curtains behind, left side opened to kitchen.  Thick rug, cushions and sofas (with some sound absorbing foam underneath) completed the “room treatment”.
      Main speakers were a pair of active SGR CX3Bs (Mk 1) and the measurements showed how good the speakers were by themselves. However, the room muddied the bass and there was less body in the music.
      Listening positions were in a single row with the main listening position (MLP) in the centre. Right4 was better half’s favourite spot and depending on how far she stretched her legs on the sofa, Left2 became a regular listening spot!   Left1 opened out to kitchen. The middle positions Left 2 and Right 3 graphs were offset -15 dB to improve readability.  Similarly,  outside positions Left 1 & Right4 offset -30 dB for readability.
      Subs were SVS SB13U and SB2000, located using “thirds criteria” in the front.  The room had limited options for subs placement and WAF considerations further restricted things. The unintegrated subs  (no adjustments to phasing, no eq, no cross over etc.)  made things  worse between 65 and 90 Hz.
      MSO used gains, delays, cross overs and PEQs to optimise the subs. Weightings for seating positions were Left1=0.5, Left2=0.9, MLP=1.0, Right4=0.8, Right5=0.5.  A target curve was used to lift the bass and compensate for large and open room.
      Bass was even across 20 to 90 Hz and the dips were removed.  More impressive was the evenness across listening positions, even in Left1.  Right4’s improvement was under appreciated (everything was treated as muzak! SIGH!).  The graphs showed that excellent results could be achieved with dual subs and MSO, but what about listening tests?
      Using a SoTM SMS-200 Ultra network player and a Gieseler Groß DAC, Diana Krall’s My Love (double bass), Bach’s Tocatta & Fugue (organ) and Fleetwood Mac’s Dreams (drums) showed how good the bass was.  MSO brought the body back to the music and was probably the key enabler for further improving the 2 channel setup. Without MSO, I doubt I would have appreciated and enjoyed the Groß DAC as much.
      While this was 2 channel focused, MSO was also good for the home theatre. Using a different subs-only configuration, MSO took movies up a notch with additional slam on Anthem MRX 710 setup in same room. It made my favourite movie opening scene in Fellowship of the Rings superb. Was (and still am) no bass head, but understood why so many pursue this!
      SNA Reviews & Impressions
      There were at least 2 threads on MSO in the Room Acoustics, Construction and Design sub-forum.  Below were the reviews and impressions posted by members (will update if there are more posts):
      baMarek  8 Sep 16
      BradC 22 Nov 16
      mcb 23 Apr 17
      Snoopy8 5 Jun 17
      Conclusion
      This case study has shown that MSO is a good cost-effective software option to overcome the bass issues brought about by the room.  Hopefully, some here will try it for your setup.  And more than happy to assist you in your journey.
    • By Alpine Electrocats
      Item: Richard Allen bass drivers
      Price: $200
      Item Condition: great
      Reason for selling: no longer needed
      Extra Info: I can post for $20. I bought these years ago thinking they were full range drivers- there are lots of jerks on eBay selling them as that, so not needed
      Price: $200
    • By baMarek
      Item: Tesla ARO 942 bass drivers
      Price: $700 ono
      Item Condition: very good (for vintage gear)
      Reason for selling: Moving
      Highly sought after and rare, the first edition of the iconic vintage bass drivers from Tesla. Paper cone, huge magnet, very high sensitivity. I had many drivers including Altecs and nothing in my experience came close in terms of quality of bass. This is the driver Lampizator used in his reference system.
      They are 30 Ohm. I have never had problems driving them but it's worth noting. One has a slight tear on the suspension part seen on the photo but it does not affect sound and stays covered behind the metal grill (included in price).
      Each speaker weighs 10kg.
