I have no idea yet where to take this, or where I will end up. I am going to end up with a good room either done by myself or done by an professional.
At the moment I have started taking measurement with REW, which is confusing and satisfying at the same time. It is confusing as I haven't made much progress in taming the real problems but satisfying as I do discover things that I would not have picked up by ear, even knowing they possibly exist.
To name a a few things that I discovered in the impulse graph, is that Martin Logan's have a very controlled mid-high frequency dispersion pattern with no early reflections on side walls, ceilings or floor. That the back wall early reflection point is producing the most early reflections, simply due to the fact I am sitting closer to this early reflection point than any other inside the room. In my case it also reflects the first front wall early reflection point, and di-pole wave early reflection point. Another eye opener is that opening the door in the back of the room is also eliminating a peak in the impulse graph. Confusing as I don't know yet why this is happening nearly 5ms after the first back wall early reflection point.
Another thing that I discovered what kind of impact a window can have on the speaker graph. I have a window in the right wall of the room and not in the left and the right subwoofer and main speaker measure different in a specific region, which seem to be related to room nodes.
Both interesting discoveries for a newby, but hardly useful. I rather avoid damping the early reflection points as they make the sound more lively. Another thing is that my Martin Logan's aren't very energetic in the HF. So damping the room isn't going to improve this, even when I might need to take a look at this, as the T30 time  is above 0.5. Confused again! How am I going to lower the reflection decay time without killing all the HF.
One thing is very clear,  that my room needs a lot off Bass management. The thing that isn't completely clear to me is that if EQ-ing an SPL graph fall's in the same category as acoustics? a SPL graph is only a single point in the room, but room nodes exist through out the room. But I have tweaked the SPL graph into a flatter response, and room node peaks are contained and I can no longer hear them. But acoustic treatment is also handling decay time of reflections which is a different aspect than an SPL graph. Argh, confused again!
Now after reading into what types of bass traps are available, things get difficult. As broadband absorbers are the first go to, but what if you don't want to dampen the room so much? 3 out of the 4 corners of my room aren't suitable for these type, as the front 2 corners are "needed" to keep my speakers "alive", and 1 corner in the back of the room has a door opening. A bulkhead trap all around the room would be a better option.
Membrane traps would be the alternative option, but these can be hard to build.
Then there is the anti mode DSP, which is basically a real live anti wave producer which requires an additional sub. But this comes down to a type of EQ again.
Slowly making my way, but creating more confusion than progress at the time.
867153d44783562197d0ae7cad775975.jpg21407b94fd478fe205a3dde91b316019.jpg73e809a665877550f31c22fa8f49d68b.jpg
To end with a few first questions.
Can EQ be considered acoustics?
Can you lower decay times using diffusion?
Can you lower decay times by using EQ?
Are there broadband bass traps that don't trap mid or high frequency?
Can room nodes being EQ, or do you need traps?
Hi PK,
getting a measurement rig is one thing - as you've worked out, properly understanding the results is another...
I think your learning curve would accelerate if you found the right professional who could measure your room, recommend treatments and explain why those treatments will work and you track the changes they make to your measurements.
Applying acoustic treatment successfully tends to be an iterative process..
EQ changes the sound, so yes I consider EQ as part of room acoustics
depends on the diffusion - QRDs (for example) won't change decay times, but 1D and 2D BAD panels diffuse using absorption and reflection, so they will tend to lower decay times
Yes - with caveats
If you identify a room mode that creates a peak in frequency response that has a long tail in the Cumulative Spectral Decay (CSD) graph, then implementing an EQ cut of that peak will remove energy of the peak and lower the decay time at that position, and any other room position that had the same peak. This may make things worse elsewhere in the room - but generally I've found using EQ to tame peaks (ie EQ cut) to be quite effective below 150Hz or so, and especially effective below 100Hz where absorption treatment simply gets too large.
Yes - the easiest approach is to cover the absorption with a membrane (eg builders plastic) that reflects the higher frequencies, but lets the bass through - the membrane can actually improve bass performance.
Another approach is to cover parts of the absorption (as suggested by @Peter the Greek ) in simple strips of masking tape to reflect some higher frequencies, or go a bit further and apply the masking tape or say wooden slats in a 1D BAD panel sequence generating some diffusion at the same time as keeping higher frequencies inside the room.
I've seen 2D BAD diffusion masks available made from perforated metal to go over absorption also.
Yes  room modes can be EQ'd, but best to target peaks, not troughs with EQ, and the same caveat applies as above. EQ is position dependent  - you can make things worse elsewhere in the room.
Mike
Edited by almikel
typo
I'd be filling that ceiling with rock wool and covering in slats as a starting point....
Considered carpet?
Cover the back wall in absorbers. With something like a BAD 300mm around all 4 sides of the surrounds.
If the ceiling trap doesn't sort out the bass, I'd build a riser trap
Hi PK,
I wouldn't regard the 2 front corners as "off limits" for absorption - many owners of open baffle speakers damp the back wave, and you'll still have plenty of treble spraying around if you used the 3 vertical wall/wall corners available for absorption traps targeted at lower frequencies (ie floor to ceiling straddling the corners, as wide and deep as you can get away with - say 600mm wide and 200mm deep)
and expensive - but you're thinking on the right track - there are 20 corners in a rectangular room to consider for treatment - floor/wall corners are just as good for bass traps if you can yield the space - even just to experiment.
Normal fluffy poly batts will freestand on their long edge - but they need to straddle the corner to get an air gap to work lower.
This is a bit left field, but with your exposed rafters, you could turn your whole ceiling into a massive membrane bass trap.
Assuming you were prepared to lose that height, attach vinyl flooring (lino) across the entire ceiling with fluffy above for a huge limp mass membrane  trap...bass management likely done.
cheers,
Mike
Lol - not so left field - PtG's suggestion would also work well.
Mike
The above would help lots...
But IMHO, any time you deploy slats, I would go that extra step and deploy them in a 1D BAD panel sequence - a bit more work, and on a ceiling you may need something to support the absorption across the gaps (eg fishing line), but you get diffusion, not just scattering, which is worthwhile (again just IMO).
Mike
Edited by almikel
Considered carpet?
Thanks Peter,
What are slats? BAD, are these the same kind of panels as @almikel it talking about?
I do like the riser idea. I could potential build a riser on top of the floor at the front of the room. Max 25cm high, max 337cm wide, min 85cm deep or deeper with a cutout for the front speakers.
What is the basic principle for the workings of the riser, as it seems to be a combination of an absorption and helmholz trap.
On 1/12/2018 at 10:36 PM, almikel said:
Hi PK,
cheers,
Mike
Thanks Mike,
I have tested with absorbing the the early reflection points and back wave reflection, and it would not be my preferred option, as it makes it sound rather uninteresting. I would prefer to dampen decay times while keeping the early and back wave reflections "alive". I haven't tested this with diffusion, or a combination of absorption and reflection as I do not have this option at this time.
Not ruling it out, but I prefer to keep the ceiling as much as it is. As covering it, will lower it an internal ceiling height of 220cm.
Edited by Primare Knob
Mike
Could you show me a picture of these BAD panel sequence? When I google it, I find these panels with a specific pattern of holes.
Here are some graphs of my room node problems.
I would like to setup the subs for LFE movies, and my main speakers for full range Music to keep things simple. The subwoofer graph is made with an xover setting of 80Hz in the PrePro. The speakers graph is made with the speakers set to large, ignoring the xover setting in the PrePro
Do Bass traps also help in reducing the dips in the response?
Measurements are made with a -20dBu setting at 85dB at the LP
I can adjust the LF gain (x - 100Hz) for my front speakers to +10, which does raise the dip between 50Hz-65Hz to around 80-85dB.
I can adjust the gain of the subwoofers as well as their output level is +/- at 25%
The difference between L-R or A-B, in the 50Hz-65Hz has to do with the large window sitting halfway the right wall.
    • By Sound_addict
      I have a Paradigm Ultracube 12 + Perfect Base Kit -1 for sale. Purchased brand-new from Eastwood Hifi around August 2015 so about or just under 1 year's old. Took it out of a box and been sitting in a corner unmoved so not a single scratch on it. Pretty good sub but I think it's time for an upgrade. Retail is $2,148 for both. I can do both for $900. I threw the box away but has all the manuals etc. Pick up or I can deliver around the metro Brisbane area (if not too far). Didn't have time to post a picture but since it's like new condition, there's really no need. Pls ask if you have any questions.
      Thanks.
    • By Rori
      Item: Martin Logan Balanced Force 212 Subwoofer with Martin Logan PBK kit -
      Price: $4.2k
      Item Condition: Excellent 9/10
      Reason for selling: Not using atm and taking up space
      Extra Info: Plenty of reviews online about this subwoofer. It has 2 x 12" drivers opposing each other to cancel out vibrations so all you get is clear, low distortion, clean bass. Can go to 16hz in room.
      The customization for best in room response from the amp is second to none with low pass filtering, phase alignment, gain and when measuring with the PBK kit can give close to perfectly flat frequency response.
      This sub looks amazing especially in piano gloss black. You could brush your teeth and do your hair in the high gloss finish. Can ship however it does weigh 65kg's... I have all boxes and accessories for it.
      See specs and pics below.
      Specs:
      BalancedForce 212
      System Frequency Response 18–120 Hz ±3dB; Anechoic through LFE effects input 20–120 Hz ±3dB;
      Low Pass Filter Frequencies 30 - 80Hz
      Phase 0°, 90°, 180°, 270° 0°
      25Hz Level Control ±10dB at 25Hz ±10dB at 25Hz
      Power Control On, Auto (12V Trigger), Off On, Auto (12V Trigger), Off
      Room Correction Perfect Bass Kit (PBK) Ready (Sold Separately)
      Woofers Two 12" (30.5cm) cast-basket, highexcursion, aluminum cone with extended throw driver assembly, sealed non-resonant asymmetrical chamber format
      Amplifiers 2 x 850 watts
      (3,400 watts peak system total) 850 watts
      (1,700 watts peak)
      Inputs RCA: Left, Right and LFE.
      XLR: Left, Right and LFE.
      Speaker Level: Left and Right banana jacks.
      12V Trigger: 3.5mm
      Mini USB (for PBK)
      USB (for crossover & firmware updates) RCA: Left, Right and LFE.
      12V Trigger: 3.5mm
      Mini USB (for PBK)
      Output (RCA) Multi Out (for multi-sub connection) Multi Out (for multi-sub connection)
      Input Impedance RCA: 10,000 Ohms
      XLR: 15,000 Ohms per phase
      Speaker Level: 10,000 Ohms per phase (20,000 Ohms red to black)
      Power Draw Typical: 250 Watts
      Idle: 30 Watts Typical: 125 Watts
      Idle: 15 Watts
      Weight 140lbs. (63.5kg) each 96lbs. (43.5kg) each
      Overall Dimensions
      HxWxD  ( 57.4cm x 57.4cm x 58.2cm)
    • By Snoopy8
      Introduction
      The purpose of this post is to re-introduce a software tool that configures multiple subwoofers (subs) to produce smooth bass in a room and at the same time, make it even across sitting positions.  A common misconception of adding subs for music is that they will artificially boost the bass.  Well integrated subs help restore the missing bass caused by the room and brings the body back to music.
      The usual approach to managing bass was room treatment first, followed by careful placement of speakers & subs. Hardware and/or software, often expensive, were also used. This case study shows why MSO is a good cost-effective software option.
      What is MSO?
      Multi-Sub Optimiser (MSO) is a FREE software tool to optimize multiple sub woofers by integrating the subs with main speakers and improving the evenness of bass response across the whole listening area. MSO is especially useful in non-dedicated rooms where there is limited (or no?) room treatment and WAF considerations dictate sub size, number and placements.  MSO also solves the difficult task of getting even bass across seating positions e.g. in multi row home theatres.
      MSO runs on a Windows laptop and requires a digital signal processor (DSP) and a calibrated microphone for use with REW (Room Equalisation Wizard) measurement software. There is some learning effort and time required to understand the concepts and set up the optimisation, but the results are worth it!  There is excellent documentation and a good tutorial.
      The program was written by AndyC on AVS Forum (discussion thread hosts all discussions, support, bugs etc.). Andy @andyc56 specifically joined SNA to support MSO.
      Why MSO? – A Case Study
      2 channel system was located in a non-dedicated open plan family room with high ceiling, hardwood floor on slab, blank wall in front, large windows with blinds on right, sliding glass doors with heavy curtains behind, left side opened to kitchen.  Thick rug, cushions and sofas (with some sound absorbing foam underneath) completed the “room treatment”.
      Main speakers were a pair of active SGR CX3Bs (Mk 1) and the measurements showed how good the speakers were by themselves. However, the room muddied the bass and there was less body in the music.
      Listening positions were in a single row with the main listening position (MLP) in the centre. Right4 was better half’s favourite spot and depending on how far she stretched her legs on the sofa, Left2 became a regular listening spot!   Left1 opened out to kitchen. The middle positions Left 2 and Right 3 graphs were offset -15 dB to improve readability.  Similarly,  outside positions Left 1 & Right4 offset -30 dB for readability.
      Subs were SVS SB13U and SB2000, located using “thirds criteria” in the front.  The room had limited options for subs placement and WAF considerations further restricted things. The unintegrated subs  (no adjustments to phasing, no eq, no cross over etc.)  made things  worse between 65 and 90 Hz.
      MSO used gains, delays, cross overs and PEQs to optimise the subs. Weightings for seating positions were Left1=0.5, Left2=0.9, MLP=1.0, Right4=0.8, Right5=0.5.  A target curve was used to lift the bass and compensate for large and open room.
      Bass was even across 20 to 90 Hz and the dips were removed.  More impressive was the evenness across listening positions, even in Left1.  Right4’s improvement was under appreciated (everything was treated as muzak! SIGH!).  The graphs showed that excellent results could be achieved with dual subs and MSO, but what about listening tests?
      Using a SoTM SMS-200 Ultra network player and a Gieseler Groß DAC, Diana Krall’s My Love (double bass), Bach’s Tocatta & Fugue (organ) and Fleetwood Mac’s Dreams (drums) showed how good the bass was.  MSO brought the body back to the music and was probably the key enabler for further improving the 2 channel setup. Without MSO, I doubt I would have appreciated and enjoyed the Groß DAC as much.
      While this was 2 channel focused, MSO was also good for the home theatre. Using a different subs-only configuration, MSO took movies up a notch with additional slam on Anthem MRX 710 setup in same room. It made my favourite movie opening scene in Fellowship of the Rings superb. Was (and still am) no bass head, but understood why so many pursue this!
      SNA Reviews & Impressions
      There were at least 2 threads on MSO in the Room Acoustics, Construction and Design sub-forum.  Below were the reviews and impressions posted by members (will update if there are more posts):
      baMarek  8 Sep 16
      BradC 22 Nov 16
      mcb 23 Apr 17
      Snoopy8 5 Jun 17
      Conclusion
      This case study has shown that MSO is a good cost-effective software option to overcome the bass issues brought about by the room.  Hopefully, some here will try it for your setup.  And more than happy to assist you in your journey.
    • By Alpine Electrocats
      Item: Richard Allen bass drivers
      Price: $200
      Item Condition: great
      Reason for selling: no longer needed
      Extra Info: I can post for $20. I bought these years ago thinking they were full range drivers- there are lots of jerks on eBay selling them as that, so not needed
