Sponsor
Item: Marantz CD6006
Location: Len Wallis Audio HQ, 64 Burns Bay Road, Lane Cove, NSW
Price: $550
Item Condition: As good as new
Payment Method: Cash, Credit Cards, PayPal, Bank Transfer
Extra Info: In excellent as new condition, unmarked example, with box and all accessories. (Current model RPP was $1060).
An evolution of the 6005 model. The 6006 brings a high spec of components, including an improved circuit layout, greater rigidity, bigger power supply, , gold-plated synch outputs and Marantz's own small signal amplifier, the HDAM-SA2.
The CD 6006 features high-resolution D/A conversion and is equipped with the reference class CS4398 D/A converter, which provides up to 192KHz/24 bit resolution for optimum fidelity with high-resolution audio file types.
High slew rate op-amp + HDAM-SA2 headphone amplifier with headphone amp gain setting (Low/Mid/High) for a wider range of headphones.The CD 6006 can play back MP3, WMA, WAV and AAC files from a connected USB storage device. It is also specifically "Made for iPod/iPhone", to directly play back your iDevice music through the CD Player's high-quality D/A converters.
Pictures
Edited by LWA Staff
A quick google reveals that this model has an improved layout (which knowledge should help with the sale of this item). GLWTS
    • By SonicArt
      Item: Onkyo R1 DX-703 CD player
      Price: $150.00
      Item Condition: Near new
      Reason for selling: Surplus gear
      Payment Method: Pickup - Cash,  EFT if shipped.
      Up for sale is an Onkyo R1 DX-703 CD player,  in excellent condition, only mark is a scrape across the plastic front of the drawer. Has had limited use and been in storage for 7-8 years. Plugged in it fired up perfectly, I ran a few CD's through it and it reads the TOC instantly, plays perfectly. I loaded some burnt compilation CD's and they read instantly and played no problem. Comes with original remote! Some info:
      Disc format: CD
      Digital converter: SM5861AP, 1 bit accupulse
      CD Mechanism: KSS-210A
      Frequency response: 5Hz to 20kHz
      Dynamic range: 96dB
      Signal to Noise Ratio: 100dB
      Channel separation: 90dB
      Total harmonic distortion: 0.004%
      Line output: 2V
      Digital outputs: optical
      Dimensions: 455 x 110 x 306mm
      Weight: 5kg
      Accessories: remote control
      Happy to meet up with Melbourne buyer to hand over, cash on pickup please. I have a box and can ship it but I would expect it to be around $30.00 for signature post to neighboring states, could be a lot more to QLD/NT/WA etc.
    • By TheOnlyGirl_InSight
      Item: FS: Marantz AV1040 Slimline AV Surround Processor
      Price: $150
      Item Condition: Great condition, minor usage wear / scuffing to the casing.
      Reason for selling: Doesn't suit my setup requirements.
      Payment Method: Pickup - Cash. Will ship with bank deposit payment.
      Extra Info: A beautiful analog surround sound integrated amplifier / AV processor. Designed to run rear and centre speakers when fed any stereo input.
      From the very stylish Slimline range, featuring a sleek metal finish and touch sensitive electronic cover for the front controls.
      Great for Laser Disc & Old film  lovers. features fully analog centre speaker and surround speaker audio matrixing. For full effect, run with a universal remote.
    • By LWA Staff
      Item: Marantz PM8005
      Price: Was $2495 Now $1495
      Item Condition: Brand new
      We normally use the Commercial Classified Section on StereoNET for interesting Second hand items or one off demonstration units that we think would be of interest to members.
      However we a great deal on a new product, so we thought we’d share.
      We have (at the time of the writing) a limited number of Marantz PM8005 2-channel Integrated Amplifiers in our warehouse that we are willing to let go at $1495 each or $1000 off the normal RRP $2495.
      From the PM 8005 you can expect accurate music delivery, with lifelike stereo imaging and lots of clean power. Although it’s rated at 70 watts per channel driving 8 ohm loads (we reckon this is on the conservative side). This amp has a robust power supply, employing a redesigned double-shielded toroidal power transformer rated at 625VA; and an output stage with high-speed high-current output devices. It can also deliver 100 watts per channel into 4 ohms make for compatibility with a broad range of loudspeakers.
      It has a comprehensive range of input jacks, including one for MM (moving magnet) phono, and two sets of audiophile-grade gold-plated speaker terminals. In addition to familiar bass and treble controls, the amplifier also has a mid-range control. It also has a Source Direct function that bypasses all these controls. Selecting the Source Direct option resulted in greater clarity and solidity.
      You can read more about it here and if you’re interested drop us a note or give us a call.
      Specifications
      Number of Channels      2
      Output power   70W (8 ohms), 100W (4 ohms)
      Frequency response      5Hz – 100kHz ±3dB (CD, 1W, 8 ohms load)
      Input Sensitivity/Impeance         PHONO:MM:2mV/47k ohms, LINE:200mV/20k ohms
      Dimensions (cm)              44 W x 13 H x 38 D
      Weight 12 Kgs
      Colour :  Sliver only
    • By myryad
      Item: Astin Trew AT3000 CD Player
      Price: $450
      Item Condition: Excellent
      Reason for selling: Reducing box count
      Superb build quality The unit is in excellent condition as seen from the photos. Includes original remote
      This is an interesting player due to the fact that it utilises a tube buffer (6922 Electro Harmonix).
      Official Product page: https://astintrew.co.uk/products/at3000/
      Specs: https://astintrew.co.uk/wp-content/uploads/2016/10/at3000.pdf
      Owners Manual: https://astintrew.co.uk/wp-content/uploads/2016/10/at3000_manual.pdf
    • By [email protected]
      Item: Esoteric KO3 CD/SACD Player and DAC
      Price: $4950
      Payment Method: Pickup - Cash, Bank Transfer,Paypal
      Extra Info: The Esoteric K 03 is an outstanding CD/SACD player and DAC. It accepts Coaxial, Toslink and USB inputs. It provide asynchronous clocking and supports high bit rates. It has a range of filters and oversampling options and has dual power supplies. The unit is in excellent condition. Potential buyers are welcome to inspect and listen to unit. Unit can be freighted using original boxing. Seller will pay freight to Sydney or Adelaide
