Steam
Marantz AV8805. Worth waiting for?
Finally some details on the 8805.
Any 8801 or 8802 users think it worth the upgrade?
8805
What 8805
Edited by Steam
Guest Sime
Yup, I’ll be getting one to replace my 8801.
Will you be adding extra channels?  Which extra feeatures make it worthwhile as an upgrade?   Are you switching 4K? Or ?
I would get the 8802A on run out
the 8805 only adds middle height to enable 6 heights, which unless have very large room with height speakers front of room and back and needing heights in middle, then will be bit much. Also all the studios according to filmmixer an insider on avs actually only use 4 heights to mix.
the 8805 can also not be used with the audyssey pro calibrated mic which i see as backward step from 8802
price I’ve read also is wait for this $7500 !!
only other thing 8805 adds is heos which could always add afterwards
there is a hdmi 2.1 update coming but then I can’t think of anything now or future I need that for. Certainly have no source or displays to support
8802a on run out should be markedly cheaper and it gets an update to bring things like Dolby vision and hlg etc the 8805 has
so in other words if need middle heights, heos or 2.1 down track buy 8805 otherwise don’t wait save bucks and get 8802a now :)
Guest Sime
Truth be told, apart from the convenience of it being 4k, I’ve been waiting for this particular model to replace mine simply because it’s up to date and further more, my current one has has A LOT of use and it’s a machine that gets rather warm, so starting from scratch to last me another 3 years is worth the cost. And I’m not overly concerned with the price of the 8805.
Yes true if wanting latest greatest then certainly another reason to buy the 8805
Guest Sime
Not that there’s anything wrong with that either ;)
I pre ordered my 8802 and there are usually some good pre order deals about. So worth seeking out if planning to buy on release
Guest Sime
@:) al it’ll have to be later in the year, getting the new Chord Qutest if first cab off the rank.
Plus with my shoulder issue, I’ll have to see where that leads me before I fully commit to the 8805, but it’s hopefully going to happen at some point this year.
Thanks Al
thats kind of what I was thinking.  The 8802a in runout would be a good buy.
Guest Sime
But the question will always remain with me, that is between the 8801-8802 and 8805, is their a noticeable difference between the 3 in regards to their analog audio. I’ve never had a confidant confirmed opinion between the 01-02, so I’ll guess I won’t find out till I upgrade.
Sime there were claims from marantz re analog audio I saw 8801 to 8802 with slide power point pres etc however have not seen anything in regards analog difference from marantz 8802 to 8805 if see anything I’ll post. All difference have seen been with regards extra height. Future 2.1 , heos and audyssey app. The rest the 8802 gets updated to in May ? I think it is. But I understand still getting latest. In anycase if leaving buying to later chances are all 8802 be cleared by then in a case making decision easier for you :)
Guest Sime
Well firstly I’ll investigate what the fazing out prices for the 8802 will be, I got my 8801 for $3300 before the new 8802 was announced.
Ridiculous, IMHO.  That doesn't make any sense...
Really?  My 8801 stays cool...I wouldn't have thought they'd warm up that much unless you're stacking your amp/s.
Guest Sime
Stacked yes
caravan bathroom only 2x2 meters, yes ;)
Yes this has me interested too.
As I don't have to have the latest , just needs to do everything I need.
i have been looking at a Yam 3083 at a good price but could be swayed by one of these on runout.
Most anecdotal reading says the 8802a is better Sime ; Kal Rubinson lists the improvements :)
https://www.stereophile.com/content/music-round-75#v5SZ2bTXv3z9msZm.97
Guest Sime
Ok, my arm is officially twisted, but one more question.
Now with the 8801, If i watch an Atmos movie, of course it’s gets played at the highest standard the 8801 can do, but considering I only have a 5.1 system, if I play an Atmos movie on a 5.1 setup, will the Atmos capable 8802 be better in 5.1 than the 8801?
Huh??
@joz If you are wanting a pre, the marantz is miles ahead of the yamaha avr range. I know having made the switch. The yamaha preouts have a ridiculously high impedance combined with a terribly low voltage - and sounds horrible.
I still dont get it. I also dont think there is much point for you to upgrade, but thats just me
Guest Sime
@AudioGeek ok. You have Atmos, and standard pre-Atmos or, 8802 to 8801.
If you have an atmos soundtrack playing on both systems, but both are playing 5.1, would the atmos 5.1 be better than the standard hd audio varient 5.1
Is atmos a better decoder or is it simply adding channels, so once the atmos soundtrack on the atmos processor has been down converted to 5.1, is it better or worse than the HD audio that’s on the 8801.
Guest Sime
Just the the same as Dolby digital is compared DTS master soundtracks.
Ah, ok get it now. Dont know the answer though.
For what you want to do I still think an 8801 to 8802 upgrade is questionable.
I wonder if you add a high quality pre with HT bypass for 2 channel music, wether you would get a more noticeable benefit.
