georgehifi 1,530 Posted January 11, 2018 Share Posted January 11, 2018 Only interested in "free to air" HD picture. After looking at free to air and adjusting them all to the best for me, all the new stuff including O'Led I just can't/don't want to change from >2012 Panasonic Plasma VT or GT models, some Samsung Plasma's as well. I'm interested it what you guys think. Cheers George Link to post Share on other sites
JSmith 1,949 Posted January 11, 2018 Share Posted January 11, 2018 1 minute ago, georgehifi said: I'm interested it what you guys think. Coming from plasma, I would strongly suggest OLED otherwise you will miss those blacks, which will be better again with an OLED; https://www.rtings.com/tv/reviews/best/by-usage/tv-shows If you want to try polishing the turd that is SD FTA, an STB and external video processor may be best if you find you are unhappy with internal VP of the TV. JSmith Link to post Share on other sites
georgehifi 1,530 Posted January 11, 2018 Author Share Posted January 11, 2018 23 minutes ago, JSmith said: I would strongly suggest OLED otherwise you will miss those blacks, which will be better again with an OLED; Yes the big dollar Oled's I saw, equalled the plasma's I mentioned on detail and motion blur for HD free to air, but still the colours on the Oled's weren't as natural, say when watching HD test cricket, they were too stark and skin tones were off, and no amount of tweaking would fix either. And yes the blacks were a bit better on Oled. Cheers George Link to post Share on other sites
JSmith 1,949 Posted January 11, 2018 Share Posted January 11, 2018 16 minutes ago, georgehifi said: no amount of tweaking would fix either. I'd be very surprised if after proper calibration that was still the case. I just think you'll notice the lighter black level at night with an LED LCD. If you go LED LCD, get a FALD model that is well regarded. JSmith 2 Link to post Share on other sites
Moderators betty boop 15,742 Posted January 11, 2018 Moderators Share Posted January 11, 2018 the thing to keep in mind is the larger the tv you go for the more obvious the quality (poor) of broadcast and also the quality of the set. ie faults either with display capability or broadcast is just more apparent as you go bigger. or sit closer. we use a 50" set now watching at 2.8m and thats OK for fta TV. up on the projector at a 92" screen is passable for good broadcasts eg cricket and other key events concerts etc in HDTV. poor SD and sub SD will just look and be more apparent as sub standard. re the oleds you saw being off in colours ? which ones. some are limited in calibration capability many are often in shop mode ie out of box with retina blinding output and colours pumped to the max to attract ! Link to post Share on other sites
georgehifi 1,530 Posted January 11, 2018 Author Share Posted January 11, 2018 12 minutes ago, al said: the thing to keep in mind is the larger the tv you go for the more obvious the quality (poor) That is also very correct, the free to air SD on a Panasonic GT 55" I have at the moment looks much worse than the HD free to air which is absolutely pristine . But on the O'led's it was not such a yawing chasm on the same size set. O'leds seem to be a better equaliser for SD V HD. Cheers George 1 Link to post Share on other sites
johndee 3 Posted January 11, 2018 Share Posted January 11, 2018 It's not just size and colours, have a good look at all TV's before you decide I was thinking of demoting and replacing my 50"Samsung C series with a larger display, though I can't get anything much bigger than 65" in the available space. I spent some time in one shop and got them to put free to air (The test match) on. The result ? I am sticking with the plasma. In comparison with my plasma, even the best were blurry and not as sharp, and seeing the ball as a comet and not a dot when it was hit put me off. JB Link to post Share on other sites
JSmith 1,949 Posted January 11, 2018 Share Posted January 11, 2018 1 minute ago, johndee said: I spent some time in one shop The thing is one can't really compare or test various TV's properly in a bright store and with settings applied to steer people towards one or away from another. There are many settings that may actually create what you describe with the ball that once disabled may yield a better result. Then there are just crap panels with rubbish processing too... Pick a few TV's based on top rated professional and user reviews, take some content in on a USB you are familiar with and/or test patterns. Ask for the remote and bring some "recommended settings" with you to apply. Stand an appropriate distance back relative to your viewing distance and old TV's size. If they won't let you do all this... go elsewhere. Even with the above though, the bright white strobing fluro tubes in a store still make it difficult to judge black levels. JSmith 1 Link to post Share on other sites
metal beat 19,291 Posted January 11, 2018 Share Posted January 11, 2018 I have 75 inch Sony 940C. over the past week watching test cricket on 90, Hopman cup on 70 and T20 on 13. It does not get much better than this. SD can look quite good to absolute rubbish - but my Sony beats my Pioneer Kuro in EVERY respect. Go 75 inch - get a Sony FALD LCD. 55 or 65 inch - OLED. 1 Link to post Share on other sites
georgehifi 1,530 Posted January 11, 2018 Author Share Posted January 11, 2018 What I did notice with the Panasonic 55" GT Plasma even though it is just full HD, I gave it a 4k demo via Chromecast ultra, and it improved even more again, alarmingly so. So to me they had more definition to give above full HD. And you can prove this by giving it a BluRay dvd. I wish Panasonic or Samsung would bring back just one model of hi-end plasma with 4k ability, just for those who want it, don't care about extra power consumption. Cheers George Link to post Share on other sites
JSmith 1,949 Posted January 11, 2018 Share Posted January 11, 2018 10 minutes ago, georgehifi said: hi-end plasma with 4k ability 4K+ resolution and larger sizes demanded by the market meant plasma had to go. They never really consumed much more power... maybe a few dollars more a month at most. If your plasma still works, you're happy with the size and you don't want to get into UHD yet... maybe just hang onto it for now until it pops. JSmith Link to post Share on other sites
Moderators betty boop 15,742 Posted January 11, 2018 Moderators Share Posted January 11, 2018 1 hour ago, JSmith said: maybe just hang onto it for now until it pops. currently am happy to keep sticking it out with our pio kuro (last and best) for every day FTA HD TV. I do have the projector for a larger screen experience for 4K UHD though. there is a lot of flux right now with displays as well. OLED seems to be settling in. there seem to be a few HDR standards and am sure there will be a bit of a shake out at some stage. there is also a new hdmi 2.1 coming. likely displays will have it next year. so if something you need (i think mainly its gaming that might want it) then best hanging out as long as can. the 4k aspect is least benefit with displays. its the other elements of uhd ie wcg and HDR that bring the key gains and this is regardless of size. Link to post Share on other sites
georgehifi 1,530 Posted January 11, 2018 Author Share Posted January 11, 2018 (edited) 9 hours ago, JSmith said: 4K+ resolution and larger sizes demanded by the market meant plasma had to go. Does that mean if Panasonic or Samsung were to reintroduce Plasma they couldn't make a 4K version now with the technology that's around?? As for the power consumption, the Panasonic top ones VT and GT models have 4 x extraction fans on the back and I believe they consume at least twice what equivalent led does, that doesn't worry me, because of the FTA HD picture quality, and they can be got s/h if you look for a good one (low screen hours) at 1/10th the price of similar size new O'led. Here's something from a TV tech that good to watch. Cheers George Edited January 11, 2018 by georgehifi Link to post Share on other sites
JSmith 1,949 Posted January 11, 2018 Share Posted January 11, 2018 2 hours ago, georgehifi said: Does that mean if Panasonic or Samsung were to reintroduce Plasma they couldn't make a 4K version now with the technology that's around?? Here's something from a TV tech that good to watch. I believe there was an issue with the size of pixels for a 4K panel from a technical standpoint making it completely impractical to build. Also happened because no one was buying plasma much anymore, plus the bigger they got the more power they used compared to other tech. 55/65" sizes were only about 30% more power, but the bigger would have been more. Cost wise per household not much, but the increased usage over populations would be large. The demand for bigger screens would have meant a knock on the environment too if the market did continue to embrace plasma. Shame the "tech" couldn't spell Vizio properly... Not to mention why he's comparing one of the best plasma's made with a substandard LED LCD; https://www.rtings.com/tv/reviews/vizio/e-series-2017 You may find the below interesting; https://www.forbes.com/sites/johnarcher/2015/11/10/oled-tv-beats-plasma-tv-in-new-public-shoot-out/#7e70edd41df4 https://www.cnet.com/news/i-still-watch-my-plasma-tv-even-though-my-oled-is-better/ "The biggest difference between the OLED and the plasma is that the OLED is brighter and the colors pop more." https://www.lifewire.com/oled-vs-plasma-3276234 http://www.hdtvtest.co.uk/news/shootout-results-201708224491.htm https://www.flatpanelshd.com/news.php?subaction=showfull&id=1500009337 JSmith Link to post Share on other sites
georgehifi 1,530 Posted January 12, 2018 Author Share Posted January 12, 2018 20 minutes ago, JSmith said: OLED colors pop more." I also find this unnatural compared to good plasma, as the green colour of forests or grass on football or cricket, takes on an almost fluro effect compared to plasma, which has more natural green, but you are right O'led is much brighter and better for brightly lit viewing rooms. Cheers George Link to post Share on other sites
Benje 818 Posted January 12, 2018 Share Posted January 12, 2018 (edited) Just converted this week from a great Panasonic V10 58" Plasma to a Panasonic EX950 65" OLED The Plasma was 50 kg, the OLED 23 kg. The plasma was 3 cm narrower, but about 10 cm or more higher, because of the frame surrounding the panel. We haven't adjusted any settings yet, so take my comments with a grain of salt. "The biggest difference between the OLED and the Plasma is that the OLED is brighter and the colours pop more". That is true, but I think it underplays the improvement in clarity/definition that the OLED provides vs a V10 plasma (circa 2009, with 'black-retaining chip fitted). That might be a V10 issue - I don't know. I don't have a more recent plasma to compare. We were watching the news the other night, and the face of one of the male presenters looked more pasty (pale) than I recall. Whether this is reality, or is an issue with the picture adjustments is an unknown. Later, I'll look at calibration and that might clarify the issue. It is difficult to discuss skin tones when you don't actually know what 'reality' is actually like. As for UHD (and Free to Air, and HD Foxtel) - the thing that has surprised me is that with the OLED, you actually want to sit closer to the TV. We are about 3.5 m from the TV (room layout, WAF issues etc) and I hope to get the lounge moved to 3.0m (closer would be great, but will never be an option that will get approved). I never wanted to sit closer with our V10 plasma. Benje Edited January 12, 2018 by Benje spelling 1 Link to post Share on other sites
Moderators betty boop 15,742 Posted January 12, 2018 Moderators Share Posted January 12, 2018 Nice tv benje keep us posted re how pana goes not many comments about the their sets with people mostly buying lg few buying Sony 1 Link to post Share on other sites
georgehifi 1,530 Posted January 12, 2018 Author Share Posted January 12, 2018 33 minutes ago, Benje said: Panasonic V10 58" Plasma Very old ones, the VT's and GT's were considerably better sets. Cheers George Link to post Share on other sites
JSmith 1,949 Posted January 12, 2018 Share Posted January 12, 2018 40 minutes ago, georgehifi said: I also find this unnatural compared to good plasma As mentioned, once calibrated the colours will be absolutely spot on for the appropriate source. JSmith Link to post Share on other sites
georgehifi 1,530 Posted January 12, 2018 Author Share Posted January 12, 2018 1 hour ago, JSmith said: As mentioned, once calibrated the colours will be absolutely spot on for the appropriate source. On FTA HD. No mater how long I spent doing just that with the o'led, I just couldn't get it as natural as I could with the Panasonic plasma. Get the grass/forests looking the right shades of green without them being highlighted fluro ("popping more") looking and the skin tones were off as Benje explained " We were watching the news the other night, and the face of one of the male presenters looked more pasty (pale) than I recall." I call it the mannequin effect. And he experienced this with an O'led compared to even a very old plamsa. Cheers George Link to post Share on other sites
Benje 818 Posted January 12, 2018 Share Posted January 12, 2018 georgehifi careful - the V10 wasn't a 'very old plasma'. The 50" plasma TH-PX70A (1080i) that preceded it was 'very old'. That went as a result of the OLED buy. Now that you are quoting what I found, perhaps you'll also believe all of the fantastic things I noted about the Panasonic OLED (which I did point out is pre-calibration, and has no real reference point apart from a V10 plasma and a more recent 44" LCD). As for 'the mannequin effect' - it may be that is what the intended outcome was from the make-up room at the news studio. How would we know what the skin tone actually was on set? Make-up is unnatural - it removes natural skin tones. Benje 1 Link to post Share on other sites
Satanica 1,540 Posted January 12, 2018 Share Posted January 12, 2018 1 hour ago, georgehifi said: On FTA HD. No mater how long I spent doing just that with the o'led, I just couldn't get it as natural as I could with the Panasonic plasma. What methods did you use for calibration? 1 Link to post Share on other sites
Grumpy 2,669 Posted January 12, 2018 Share Posted January 12, 2018 l don't have oled or plasma, but l do have a 55inch 4K Panasonic Viera LED from 2015 and a hell of a lot of FTA looks crap. What does look amazing on FTA at the moment is the re-runs of Dr Who with David Tenant - check it out and please tell me if l'm wrong. 1 Link to post Share on other sites
JSmith 1,949 Posted January 12, 2018 Share Posted January 12, 2018 2 hours ago, georgehifi said: No mater how long I spent doing just that with the o'led, I just couldn't get it as natural as I could with the Panasonic plasma Unless you were in dark room conditions rather than a bright store, the process is pointless... especially if you can't adjust the 2/10 point grey-scale and gamma. The new OLED panels can reach colour space that plasma cannot, but that doesn't mean it applied to a standard once calibrated properly. As mentioned, if all this is too daunting (understandable), just stick with what you have until picture becomes clearer so to speak. JSmith Link to post Share on other sites
georgehifi 1,530 Posted January 12, 2018 Author Share Posted January 12, 2018 1 hour ago, Satanica said: What methods did you use for calibration? At friend place who's a TV tech also on his O'led, all of them using test pattern generator, and on another one, even into the service menu and tried doing some adjustments from there also with him. On FTA HD just couldn't get O'led to equal the VT or GT plasma. Sure it was brighter and had better blacks, but nothing else, the plasma was just more natural and watchable. Cheers George Link to post Share on other sites
Satanica 1,540 Posted January 12, 2018 Share Posted January 12, 2018 Just now, georgehifi said: At friend place who's a TV tech also on his O'led, all of them using test pattern generator, and on another one, even into the service menu and tried doing some adjustments from there also with him. Correct me know if this is wrong, but this does not appear to be a full, proper calibration. If not, it could really be worth it. What TV do you have? 1 Link to post Share on other sites
JSmith 1,949 Posted January 12, 2018 Share Posted January 12, 2018 37 minutes ago, Satanica said: Correct me know if this is wrong, but this does not appear to be a full, proper calibration. I posted for George links to various professional test review calibration and colour space results... which I'd be relying on much more than a mate's un-calibrated setup. JSmith 1 Link to post Share on other sites
georgehifi 1,530 Posted January 12, 2018 Author Share Posted January 12, 2018 1 hour ago, Satanica said: What TV do you have? My own is the Pansonic 55' GT before that I had the Panasonic 50" VT. Cheers George Link to post Share on other sites
georgehifi 1,530 Posted January 12, 2018 Author Share Posted January 12, 2018 33 minutes ago, JSmith said: I posted for George links to various professional test review calibration I also could have this done by a calibration tech in Melbourne, but he wanted air fare and taxi and $200 per hr to do it. Then when I asked him if he could calibrate via the the service menu to get the tuner section 100% properly calibrated to that panel, he had no idea about it, dare say he wasn't used. Cheers George Link to post Share on other sites
JSmith 1,949 Posted January 12, 2018 Share Posted January 12, 2018 1 hour ago, georgehifi said: air fare and taxi and $200 per hr to do it. Bit OTT... there are people in Sydney that offer an ISF calibration. You could also purchase a 2nd hand colorimeter and get into adjusting your own set. Best of luck with the decision making there George. JSmith Link to post Share on other sites
JSmith 1,949 Posted January 12, 2018 Share Posted January 12, 2018 (edited) @georgehifi, this may be something you're interested in! JSmith Edited January 12, 2018 by JSmith ' Link to post Share on other sites
georgehifi 1,530 Posted January 12, 2018 Author Share Posted January 12, 2018 (edited) 7 minutes ago, JSmith said: Best of luck with the decision making there George He was recommended by a few guru's here and on Whirlpool, like I said, he wasn't used, especially when he had no idea about calibrating the tv's tuner to the panel via the service menu. Cheers George Edited January 12, 2018 by georgehifi Link to post Share on other sites
Please sign in to comment
You will be able to leave a comment after signing in
