KenTripp
QEOS II by Perfect 8 Technologies
8pm Wednesday 17th January, visitors welcome.
Willis Room, City of Whitehorse Offices
Maroondah Highway (Whitehorse Road), Nunawading
Melway Map 48 Ref G9
Contact: 9437 1249
When it comes to cabinet construction, many speaker designers will traditionally use some type of wood to produce a finished product. In the past, unconventional material like concrete has been tried. Today, everything from 'high-density polyurethane' to aluminium is in use. Glass would be the most unique and challenging material for any speaker designer.
In 2016 the Australian Hi-Fi & AV Show hosted the world premiere of the QEOS II. These new glass speakers are designed in Sweden, produced in Germany by the renowned glass furniture manufacturer Dreieck Design, while the crossover filters are made in Australia by Spuncsound founder Roland Boitor. This new model is inspired by Perfect 8 Technologies earlier 'Cube' speaker but with increased inner volume that delivers enriched sound. This team of specialists believe glass has become the ideal structural material for a new revolutionary high-end audio solution. One key technology used in the QEOS II speaker, is the proprietary Super Silent Glass (SSG) "SSG is a special glass type which virtually eliminates all vibrations there is no ringing."
The new stand mount speaker is fabricated from 12mm thick glass panels. The sealed glass enclosure houses two 7-inch aluminium drivers and a 35mm fabric dome tweeter. The mid/bass drivers are mounted on opposite sides of the cabinet, thereby delivering a virtually omni directional radiation pattern throughout the heart of the music, up to 900Hz. The tweeter which faces the listener delivers its sonic signature from 700Hz (!) and looks after the high frequencies.
Roland Boitor from Spuncsound, will be presenting a program of music to demonstrate the sonic attributes of these speakers, as well as their technical highlights. Loudspeakers are often described as being a window on the performance; with this new revolutionary material, we get to see and hear the results.
Nick Karayanis
Program Co-ordinator
Ken Tripp
Wise and Wonderful Webmaster
Melbourne Audio Club, Inc.
http://www.melbourneaudioclub.org.au
Edited by KenTripp
    • By KenTripp
      Lucie Audio
      8pm Wednesday 18th July, visitors welcome.
      Contact: 9437 1249
      When it comes to choosing or designing a loudspeaker there are two rules to consider: Rule #1; There is no such thing as a perfect loudspeaker. Every design is a series of compromises. Rule #2; One has to accept that there will be compromises and decide on a design which reduces these compromises.
      This month's presenter has developed a speaker system which further reduces the compromises associated with the conventional passive loudspeaker. Rick Bond from Lucie Audio will be demonstrating his speaker system which utilises active crossovers with room equalisation by means of his DSP pre-amplifier. "Our pre-amp is built around the capabilities and feature set of the MiniDSP 2x4HD processor board. This gives us the power to process the stereo audio stream in real time to perform room corrections and digital crossover functions. Correction technology is powered by Dirac Research AB, world leaders in this field".
      The process maps out the frequency and impulse response characteristics of the speakers in the room in a 3D grid around the listening position. After completing a frequency sweep with a microphone connected to the computer, a desired frequency response curve and an optimised impulse response are measured; the data and a set of filters are generated to map the two together. This data is then uploaded to the unit and stored in one of four configuration slots. This provides great flexibility in that up to four combinations of tonal response, crossover parameters and optimal listening position can be stored and readily recalled via the unit's remote control.
      "To get the best from the MiniDSP hardware, we developed an active analogue volume control board. Maintaining volume control in the analogue domain provides the best approach to the gain structure".
      Rick will be demonstrating his system with two sets of book shelf speakers and a matching subwoofer. He has developed these two distinct speakers to cater for the tastes of the listener. The Lucie Model One Loudspeaker is a 6.5" Point Source design. The full range driver is sourced from Dayton Audio for its zero crossover distortion. Excelling at delivering the nuances in the midrange, this design is recommended where primarily acoustic music is appreciated in a small to medium, focused listening environment.
      The Lucie Model Two Loudspeaker is a traditional two-way compact speaker with drivers from SB Acoustics and Scan-Speak. Recommended and pre-set crossover slopes from the DSP Pre-Amp are set at 6db per octave and centred at a fairly high 4kHz. First-order crossover slopes are chosen for their phase neutrality, made possible by the smooth and extended response of both drivers. This bass reflex (ported) design has a greater power handling and more driver excursion, better suited to bass-heavy music. The system extends the response well below the frequency of the cabinet, giving exceptional performance for a fairly compact enclosure.
      Cabinet materials are chosen for their high density and sustainability. Narrow grain carbonised Bamboo or Baltic Birch ply are laminated, no veneers are used, precision CNC cut then hand assembled and finished. Due to the laminar sheet construction inner wall profiles are able to be uniquely contoured to minimise internal reflections and cabinet resonances.
      This will be Rick Bonds first public presentation at an audio event. A relative new-comer to the HiFi scene, this young man has developed a complete active system that puts DSP technology within the reach of many audiophiles.
      Nick Karayanis
      Ken Tripp
    • By KenTripp
      Convenors Request Night with gear by Ray Goh
      8pm Wednesday 16th May, visitors welcome.
      Contact: 9437 1249
      This month's meeting will be a music request night with the club Convenors providing the musical program. Each Convenor will present to the club a selection of music from their favourite CDs. It could be a track from one of their 'desert island discs' or a recent purchase.
      To ensure that we get through as many different tracks as possible, I've requested that each piece of music be no more than 5 minutes long. This will get us through plenty of CDs before the coffee break.
      Equipment on the night will be provided by Ray Goh from the Hi Fi Exchange. At the time of this write-up, Ray was still finalising the equipment selection. With so much gear to choose from, his new shop is an Aladdin's cave of classic old gear looking for a new home. Whatever gear he puts together for the night, I'm sure it will be a thoroughly satisfying musical presentation.
      This would be a good opportunity for all members to discover some new music at this meeting. I'm sure your music Convenors will do their best to present a most enjoyable night.
      Nick Karayanis
      Ken Tripp
    • By KenTripp
      Redgum Audio the Black Series
      8pm Wednesday 18th April, visitors welcome.
      Contact: 9437 1249
      This month we welcome back Ian Robinson and Lindy Gerber from Redgum Audio. The last time we had them present at the club, they had just celebrated an audio milestone - 21 years in the Hi Fi Industry. Since then a number of new components has been developed, thus the product theme for the night: All things black and (mostly) small.
      The Redgum Black Series of components will comprise of the RGMP8 Media Player - $990, the RGDAC8 DAC - $990 and the RGi35ENR amplifier - $2000. All designed in Melbourne and assembled in China. To complete the system a pair of Axis VoiceBox S Mini-Monitors - $2500 - in a glossy black finish.
      The Media Player and DAC are designed to be hidden or stacked together on a hi-fi rack; they share the same size chassis and footprint. The RGMP8 Media Player is perfect for those who just want to play their files. This stand-alone media player automatically creates its own wi-fi hotspot, no internet connection or network required. It is designed to be used by someone who has little computer knowledge.
      Long before the term "Asynchronous" became widely used, Redgum CD players and DACs have been asynchronous from the first model. The RGDAC8 has been ear-tuned to be at least the match of the sonic quality of their top-line DAC. This 3rd generation model has become a Multi-format Hi-res Asynchronous USB DAC.
      The Black Series RGi35ENR is the 65wpc Integrated amplifier, purpose designed to power ultra-low speaker impedances, 95 WRMS into 2ohms with short term transients of 560watts.
      The Axis VoiceBox S Mini-Monitor with its 50mm Metal Ribbon tweeter has the sonic virtues to bring out the quality of the electronic components. This system has been presented in the U.S. at the Newport Show and AXPONA, receiving an Audio Oasis Award.
      Sounds like we will get to hear an all Australian quality system that won't put you in the black.
      Nick Karayanis Program Co-ordinator
      Ken Tripp
    • By KenTripp
      Melody Valve Ltd
      8pm Wednesday 21st March, visitors welcome.
      Contact: 9437 1249
      2016 was a landmark year for Melbourne audiophiles, for it was a year when two International Hi Fi Shows came to town. Not only was it a first time for the StereoNet group to organise a very successful show, it was a first for Melody Valve Ltd to exhibit all of their new amplifiers. This month we are very lucky to have Melody present at the club.
      Established in Melbourne by the founder and chief designer Mr Allen Wang, the company has grown by investing in their own factory in Shenzhen China. It features a modern assembly line, a transformer production line, a vacuum processing plant and a variety of self-built high-end testing equipment. Their current line of amplifiers consists of eight models.
      Melody will be demonstrating two systems from their Everest amplifier range. The equipment will consist of a 28watt Class A Integrated amplifier, and a Pre/ Power combination. The first model the "Everest 845", uses a Western Electric 845 tube per channel, as well as a pair of 300B driver tubes. The second system will be a pair of mono blocks - "PM 845 EVO" -- each running a pair of 845 valves in Class A mode with a combined output of 70 watts each. The "WE2688 Signature Pre", is a real highlight with its implementation of a WE 416 tube; planar triode, used for microwave telephone systems, that looks like a round metal relay.
      The two systems will use the same pair of speakers, the Harbeth 40.2. This reference monitor is a 3-way stand mount model that houses a 12" Bass driver with 6.5" Mid and matching 1" Tweeter. Harpeth's top of the range speaker is modified for the domestic audio market with a different bass driver, but still retains the same mid that is used in their studio monitors.
      If you haven't experienced Melody's presentations at the past Hi Fi Shows, you will see why they get the award for "Exhibitor who tried the hardest to impress". Sounds like we're in for a sonic spectacular.
      Ken Tripp
    • By KenTripp
      DIY Night
      8pm Wednesday 13th December, visitors welcome.
      Contact: 9437 1249
      It's that time of year again when the DIY group get to show off their Hi Fi projects at the December General Meeting. It looks like another busy year for the group as they have managed to put together three systems for the night's presentation.
      This year we are lucky to have a wide range of equipment on show, everything from vinyl to a music server, and both Class-D and Valve amplification. The Audio Action group will be demonstrating their finished project, a Phono Preamp designed and built by a team of MAC members.
      The first system will be playing music from a DIY "Raspberry Pi" music server. Based on a low cost but very powerful computer board aimed at the educational department. This same system will feature a 250W Class D amplifier powering a pair of 2-way stand mount speakers.
      The second system will showcase the MAC Phono Preamp, designed with two 'best in class' head-stage amplifiers, one for MC and one for MM cartridges. The rest of the system will have an opamp based preamp running into another Class-D power amp. A pair of 3-way speakers with American 12" bass drivers, Scandinavian 5"mid's and 'Raal' ribbon tweeters, will be providing the sound for the night.
      The final system will feature a valve amplifier with a modest 15 Watts. The design is a hybrid of Dynaudio ST70 and Alan Wright's ideas using EL34's in ultra-linear mode. The amp will be partnered with equipment from the other two systems.
      As in previous years, each system will be allotted 30 minutes. Each presenter will get to explain their gear as well as play some music. This should see us finish the session by 10:00pm, allowing the members on the night to hear all the systems. Its going to be a cracker of a night.
      Ken Tripp
