andyr
A different DAC now gives me sound from my digital flat-creen TV?
Hoping to get advice from the AV experts around these parts.  :)
Perhaps you can explain to me why this works:
  • 6 months ago, we bought a Samsung digital flat-screen TV - to replace the old analogue flat-screen TV.
  • I have been using an optical cable out from the TV ... into a noname DAC purchased from Jaycar and then an analogue interconnect into my preamp.
  • So we were able to listen to TV through the speakers (& sub).
  • However, this didn't work for HD programs!  :(  We had to use the TV's sound.
  • I've just replaced the noname DAC with a FiiO D07 - and, lo and behold ... HD program sound now comes through the hifi!  Yay!!  :thumb:
  • Is it as simple as ... the FiiO D07 (which runs at 96kHz) is compatible with HD, whereas the other one was running at 48kHz - so wasn't?
Thanks,
Edited by andyr
I believe it is either the sample rate or file format. I know my LH DAC wouldn't work from the TV on HD channels if it said Dolby Audio.
Aah, OK - thanks, Bunno.
Let's see if suddenly I get no sound on HD ... and I'l look to see if it's Dolby!  Netflix is the next test!  :)
The SD channels using MPEG2 will send MPEG 1 layer 2 audio.
The SD channels using MPEG4 will send HE-AAC audio.
The HD channels using MPEG4 will send AC3 Dolby Digital (previously MPEG2 with AC3).
Any receiving device must be able to decode the AC3.
JSmith :ninja:
JSmith :ninja:
So this is what the Fiio D07 supports.
PRODUCT HIGHLIGHTS
  • Supports Dolby Digital/DTS/AC-3/MPEG-2
  • S/PDIF Sample Rates up to 96kHz
  • Coaxial and Optical Inputs
  • Dual RCA Phono and 3.5mm Stereo Mini Out
The OP didn't specify which no name dac he bought from Jaycar.  Jaycar do sell DACs supporting all this.
@andyr I had the same issue. I went into the TV audio settings and changed digital output from Dolby digital to PCM- works on my DAC now.
You should still be able to adjust the audio output settings on the TV to output as PCM though, surely?
Yes you can, and I have the basic cheap LED 55" Samsung....:D:hyper:
Thanks very much, guys!  :thumb:
So it looks like the FiiO D07 accepts Dolby - which I'm pretty sure I remember the first one didn't.
Hence I now get sound on HD channels.
@Addicted to music ... why would I have a reason to change the audio output on the TV away from Dolby to PCM?
So you're no name dac from Jaycar may work!  :)
Stereo DACs typically can’t decode a Dolby Digital bitstream, so often you need to allow for the TV to do the decoding.
Yeah, sure, Peter - but since I've got the FiiO ... I may as well keep on using it!  :)
