Al.M
VAF DC X63 Speakers
Has anyone bought or listened to these they look interesting, time aligned and multidriver.
Whats the deal with twin tweeters, they seem to feature a little more these days in some speaker lines.
https://vaf.com.au/collections/dc-series-speakers/products/dc-x63
Edited by Al.M
Twin tweeters would give better high frequency dispersion and greater power handling.
I haven’t had a good listen to them, but Simon did mention once that with the X-63 he felt that he had reached the performance limit of the drivers, i.e. there was not much room for further improvement, this being a good thing.
SS
I have 11 VAF speakers and sub in my ht/music room with 63's as mains. Have been very happy with both music and movies. VAF really are great to deal with as well.
I can't tell you about the technical side of it all, but they sound good.
I'm hoping to get a set of X63s  late this year / early next year,  will have hands full buying house first. dedicated listening area mandatory :thumbsup:
the spec's state for power "up to 200W," any idea of the lower range? my current amp cam comfortably do 50-60W  into 2 channels. they have good efficiency so hoping it will be right
Speaker power rating are usually just a general guide and there’s nothing stopping you from using much more powerful amps. Even if you had a 400w amp you would generally never turn volume up to full volume to get past 200w. A 20w amp could blow the speaker up more than a higher power amp. One should generally never go above about 1-3pm on volume knob.
The DC-X63 is rated at 94dB (at 6ohms) efficiency which is about twice that of many common speakers around 88-90dB so any amp can potentially sound about twice as loud in comparison so your 50w amp should be ok. It is more complicated than that in reality and there other posts debating that.
What amp have you got?
See also
They look to be a very high value speaker.
The high sensitivity is interesting but you would need to see an impedance curve.I suspect it might dip well below the nominal 6 ohm if they are using 8 ohm drivers wired in parallel so might not suit low /medium powered amps.
ALL decent amplifiers will deal with 4 Ohm loads easily. Just a nit: It's not the "power" per se that may be a problem with speakers that exhibit low(ish) impedance curves. It is the CURRENT that can be an issue. With 94dB/2.83VRMS/M sensitivity, I would expect that a decent, 50 Watt amplifier is all these puppies need to sing. Obviously, I would need to see the impedance curve, but I would think that any amplifier rated to operate with 4 Ohm loads should work just fine.
Not so sure about that.I have owned speakers with similar configurations of two woofers and two midranges using 8 ohm drivers and found them pigs of things to drive.Even more difficult that the Gale 401s.
You can't tell be just looking at the driver line-up. You can only tell by examining the impedance curve.
Here is the impedance curve of the DC-X63. As you can see, any decent amplifier, with 4 Ohm capability can deal with these puppies. NAD, Marantz, etc. The list of suitable amps is very broad. And with 94dB sensitivity, 50 Watts should be ample.
Thanks to Simon from VAF for providing this information in a very timely manner.
Yes I agree.That looks fine for most  SS amps.
How they have managed to keep the impedance above 4 ohms is a bit of a mystery but well done them.
Perhaps the drivers are all genuine 8 ohm whereas most that are rated at 8 ohm are really more like 6-7 ohm and before you know it you are looking at 3 ohms when they are paralleled and that gets far more tricky.
Hi Vi drivers?
Looks even more of a bargain for anybody wanting a big easy full range speaker.
As long as the default colours are not Port Adelaide Football Club!
Edited by THOMO
thanks for input chaps, i spent a bit of time last week trying to get around the whole how power and matching amp n speakers.... then there's the marketing hype when they list the specs. figured at some point i'd just put it to the collective for thoughts
I'm running  an Onkyo tx-8150
http://www.eu.onkyo.com/downloads/2/8/7/0/8/ONKYO_TX-8150_datasheet_EN.pdf
https://www.whathifi.com/onkyo/tx-8150/review
GENERAL SPECIFICATIONS (on web and retail sites)
Power Output: 135 W/Ch (6 Ohms, 1 kHz, 1%, 1 Channel Driven, IEC); 140 W/Ch (6 Ohms, 1 kHz, 2 Channels Driven, JEITA)
but from deep in pdf specs -
Dynamic Power 190 W (3 Ω) 170 W (4 Ω) 110 W (8 Ω)
THD+N (Total Harmonic Distortion + Noise) 0.08% (20 Hz–20 kHz, Half Power)
** what exactly is half power?
a few blog type reviews state RMS 55W per ch, and I'd hope that their "high current" WRAT tech delivers
Edited by wasabijim
typo
Some speakers with multiple drivers also use 16 ohm drivers so when hooked up together they present around 8 ohm and the crossover circuit is involved as well.
